GPereira
Share Laptop Internet through ethernet
Sun Aug 27, 2017 12:28 pm
I have Arch Linux on my laptop and I would like to share its internet connection through my raspberry which will be under water.
I've assigned a static IP address to both my laptop and raspberry's ethernet interface, this way I don't need a dhcp server, editing my /etc/dhcpcd.conf file with:
interface enxb827eba5a5d4
static ip_address=192.168.0.2/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1 8.8.8.8
Next I've allowed ip forwarding on my laptop using: sysctl net.ipv4.ip_forward=1
So my laptop's ip is: 192.168.0.1
Raspberry's: 192.168.0.2
What am I missing out?
GPereira
Re: Share Laptop Internet through ethernet
Sun Aug 27, 2017 12:33 pm
I've read that to no use, can you explain to me what do I need more? (I've further detailed my post, please read again)
cydz
Sat Sep 02, 2017 1:03 am
After you get this to work you should go 1 step further set an access point on the pi so you can share internet from the pi to the laptop, via wifi :)
https://bbs.archlinux.org/viewtopic.php?id=217363
Return to “Arch”
Who is online
