[Solved] Enable heartbeat LED on Arch
Posted: Wed Feb 01, 2017 1:14 am
by Milliways
I normally use heartbeat on my Pi, set with:-
dtparam=act_led_trigger=heartbeat
This works with my other distributions, but when I tried this with latest Arch with kernel 4.4.44-1-ARCH on my Pi3, but it does not work; the LED remains off.
cat /sys/class/leds/led0/trigger
none kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock usb-gadget usb-host mmc0 mmc1 timer oneshot [heartbeat] backlight gpio cpu0 cpu1 cpu2 cpu3 default-on transient flash torch input rfkill0
seems to show that is has been set.
I thought the code to run this would be in the kernel. Is anything else needed?
Re: Enable heartbeat LED on Arch
Posted: Fri Feb 03, 2017 4:56 am
by Milliways
After receiving no suggestions, I decided to try on a Pi2; the heartbeat worked normally, so I concluded it was a problem with the Pi3.
I updated the software to 4.4.45-1-ARCH and lo and behold it now works.
