ASpotySpot
XBMC
Thu Aug 16, 2012 8:34 pm
I don't have enough space on my sd card to compile xbmc for Arch.
Could someone who's had success please post a completed build? (or link to one)
Jim JKla
Re: XBMC
Thu Aug 16, 2012 8:37 pm
You are going to need to tell people what size card you are working with.
Just a question are you using all of your card?
Images are typically optimized to fit on smaller cards and then expanded once they are on the final destination.
That expansion is a manual process. Semi automatic (script) on wheezy ;)
ASpotySpot
Re: XBMC
Thu Aug 16, 2012 9:12 pm
Yeah using full card, tried building using the PKGBUILD at
https://aur.archlinux.org/packages.php?ID=60530
Jim JKla
Re: XBMC
Thu Aug 16, 2012 9:18 pm
You still don't say what size if you want an image uploaded somewhere torrent would be best but they still need to know if they post a 32gig image and you are using a 8gig card you are going to be just as stuffed as you are now :D
ASpotySpot
Re: XBMC
Thu Aug 16, 2012 9:19 pm
I'm confused, when built won't it be the same size regardless...
I mean the PKGBUILD will just produce a .tar.xz to install with pacman right?
EDIT: I may be completely misunderstanding the error message..
cc1: out of memory allocating 16917208 bytes after total of 76795904 bytes
I just assumed this meant space on sd card but now I'm thinking ram issues?
I'm using the arm240.elf file though?
Jim JKla
Re: XBMC
Thu Aug 16, 2012 9:37 pm
I imaged wheezy onto an 8gig sd card did the startup expanded to use all of the card loaded some stuff not a lot made a backup image and it's big lotts bigger. like circa 7.4gig ;)
So just tell us what size card are you using there is just the posibility that your trying to get a quart into a pint pot. ;)
It's not a difficult question ;)
ASpotySpot
Re: XBMC
Thu Aug 16, 2012 9:41 pm
Its a 4 GB card.
df reports it as 3.6G.
With nothing installed except the xbmc dependencies and base-devel I have 2.4G free may be able to get a few more megabytes out of that.
pepedog
Re: XBMC
Thu Aug 16, 2012 11:26 pm
You would need a swap file, search these forums for swapon
http://archlinuxarm.org/forum/
Swap on an sd card is a bad thing, use sparingly.
Someone has built a package
http://archlinuxarm.org/forum/viewtopic.php?f=31&t=3004
ASpotySpot
Re: XBMC
Fri Aug 17, 2012 11:23 am
Thanks a ton pepedog :)
alias_neo
Re: XBMC
Wed Aug 22, 2012 4:37 pm
So can I install this through pacman yet?
Just wondering if it's worth switching from Raspbmc to Arch with XBMC but I don't have the time or patience to build it myself thee days.
https://2byt.es - Just my two bytes - RPi - Android - Arduino - Blog
pepedog
Re: XBMC
Wed Aug 22, 2012 7:56 pm
Yes, you can
pacman -U http://urlofthefile
Must say it didn't run for me, but has run for others.
I do run xbmc on my spare rpi, but use the openelec version
Return to “Arch”
