Multiple issues here, but they are solved:
[am25200@arkos ~]$ sudo tar xz rtl8812au-rpi-dkms-git.tar.gz
tar: Refusing to read archive contents from terminal (missing -f option?)
tar: Error is not recoverable: exiting now
[am25200@arkos rtl8812au-rpi-dkms-git]$ sudo makepkg -Acs
==> ERROR: Running makepkg as root is not allowed as it can cause permanent,
catastrophic damage to your system.
[am25200@arkos rtl8812au-rpi-dkms-git]$ makepkg -Acs
==> ERROR: You do not have write permission to create packages in /home/am25200/rtl8812au-rpi-dkms-git.
Aborting...
==> Entering fakeroot environment...
/usr/bin/makepkg: line 170: fakeroot: command not found
[am25200@arkos rtl8812au-rpi-dkms-git]$ sudo pacman -S fakeroot
Except the next: How can I fix it?
[am25200@arkos rtl8812au-rpi-dkms-git]$ sudo pacman -U rtl8812au-rpi-dkms-git-0.r56.38b565a-1-armv7h.pkg.tar.xz
[sudo] password for am25200:
loading packages...
resolving dependencies...
looking for conflicting packages...
Packages (1) rtl8812au-rpi-dkms-git-0.r56.38b565a-1
Total Installed Size: 7.37 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
:: Processing package changes...
(1/1) installing rtl8812au-rpi-dkms-git [######################] 100%
Creating symlink /var/lib/dkms/rtl8812au/0.r56.38b565a/source ->
/usr/src/rtl8812au-0.r56.38b565a
DKMS: add completed.
Error! echo
Your kernel headers for kernel 4.4.9-1-ARCH cannot be found at
/usr/lib/modules/4.4.9-1-ARCH/build or /usr/lib/modules/4.4.9-1-ARCH/source.
error: command failed to execute correctly
:: Running post-transaction hooks...
(1/1) Install DKMS modules
==> No kernel * modules. You must install them to use DKMS!
[am25200@arkos rtl8812au-rpi-dkms-git]$ cd /usr/lib/modules/4.4.9-1-ARCH
[am25200@arkos 4.4.9-1-ARCH]$ dir
extramodules modules.builtin modules.devname modules.symbols.bin
kernel modules.builtin.bin modules.order
modules.alias modules.dep modules.softdep
modules.alias.bin modules.dep.bin modules.symbols
Full log:
Welcome to Arch Linux ARM
Website: http://archlinuxarm.org
Forum: http://archlinuxarm.org/forum
IRC: #archlinux-arm on irc.Freenode.net
Last login: Mon May 9 23:31:22 2016 from 192.168.1.103
[am25200@arkos ~]$ pacman -Syu
error: you cannot perform this operation unless you are root.
[am25200@arkos ~]$ sudo pacman -Syu
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
:: Synchronizing package databases...
core 209.7 KiB 1104K/s 00:00 [######################] 100%
extra 2.3 MiB 2.36M/s 00:01 [######################] 100%
community 3.7 MiB 2.05M/s 00:02 [######################] 100%
alarm 106.9 KiB 629K/s 00:00 [######################] 100%
aur 30.3 KiB 275K/s 00:00 [######################] 100%
arkos 17.9 KiB 163K/s 00:00 [######################] 100%
:: Starting full system upgrade...
Packages (87) arkos-core-0.7.2-1 arkos-kraken-0.7.2-1 binutils-2.26-4
ca-certificates-mozilla-3.23-3 cracklib-2.9.6-1 curl-7.48.0-1
device-mapper-2.02.150-1 dhcpcd-6.10.2-1 expat-2.1.1-1
fail2ban-0.9.4-2 file-5.26-2 gcc-6.1.1-1 gcc-libs-6.1.1-1
geoip-1.6.6-2 geoip-database-20160301-2 git-2.8.2-1
glib2-2.48.0-2 glibc-2.23-2 gmp-6.1.0-4 gnupg-2.1.12-1
gnutls-3.4.11-2 grep-2.25-1 groff-1.22.3-6 gzip-1.8-1
http-parser-2.7.0-1 icu-57.1-1 iproute2-4.5.0-2
iptables-1.6.0-1 iputils-20160308.0db72a4-1 jemalloc-4.1.1-1
libassuan-2.4.2-2 libelf-0.166-1 libgcrypt-1.7.0-2
libgpg-error-1.22-1 libmnl-1.0.3-2 libmpc-1.0.3-2
libnftnl-1.0.5-1 libnl-3.2.27-1 libtasn1-4.8-2 libtool-2.4.6-5
libutil-linux-2.28-1 libuv-1.9.0-1 linux-api-headers-4.5.2-1
linux-firmware-20160315.deb1d83-1 linux-raspberrypi-4.4.9-1
logrotate-3.9.2-1 lvm2-2.02.150-1 make-4.1-4 mpfr-3.1.4.p1-1
nano-2.5.3-2 nettle-3.2-2 nginx-1.10.0-2 nodejs-6.1.0-1
npm-3.8.9-1 nss-pam-ldapd-0.9.6-3 ntp-4.2.8.p7-1
openssl-1.0.2.h-1 pacman-5.0.1-3 pacman-mirrorlist-20160319-1
parted-3.2-4 perl-5.22.2-1 pinentry-0.9.7-2 python2-2.7.11-3
python2-cffi-1.6.0-1 python2-cryptography-1.3.2-1
python2-idna-2.1-1 python2-packaging-16.7-1 python2-pip-8.1.1-1
python2-psutil-4.1.0-1 python2-pyopenssl-16.0.0-1
python2-pyparsing-2.1.1-1 python2-setuptools-1:21.0.0-1
raspberrypi-firmware-20160506-1
raspberrypi-firmware-bootloader-20160506-1
raspberrypi-firmware-bootloader-x-20160506-1
raspberrypi-firmware-examples-20160506-1
raspberrypi-firmware-tools-20160506-1 redis-3.2.0-1
s-nail-14.8.8-1 sqlite-3.12.2-1 sudo-1.8.16-1
supervisor-3.2.3-1 texinfo-6.1-3 tzdata-2016d-1 unzip-6.0-12
util-linux-2.28-1 wget-1.17.1-2
Total Download Size: 210.97 MiB
Total Installed Size: 739.11 MiB
Net Upgrade Size: 27.43 MiB
:: Retrieving packages...
linux-api-headers-4... 767.9 KiB 545K/s 00:01 [######################] 100%
tzdata-2016d-1-any 218.9 KiB 706K/s 00:00 [######################] 100%
glibc-2.23-2-armv7h 7.7 MiB 353K/s 00:22 [######################] 100%
binutils-2.26-4-armv7h 4.1 MiB 1641K/s 00:03 [######################] 100%
gcc-libs-6.1.1-1-armv7h 10.2 MiB 3.86M/s 00:03 [######################] 100%
perl-5.22.2-1-armv7h 12.2 MiB 884K/s 00:14 [######################] 100%
openssl-1.0.2.h-1-a... 2.3 MiB 2034K/s 00:01 [######################] 100%
expat-2.1.1-1-armv7h 61.0 KiB 381K/s 00:00 [######################] 100%
sqlite-3.12.2-1-armv7h 932.2 KiB 2.02M/s 00:00 [######################] 100%
gzip-1.8-1-armv7h 69.9 KiB 538K/s 00:00 [######################] 100%
texinfo-6.1-3-armv7h 1143.7 KiB 1906K/s 00:01 [######################] 100%
libtasn1-4.8-2-armv7h 99.1 KiB 381K/s 00:00 [######################] 100%
gmp-6.1.0-4-armv7h 326.5 KiB 1209K/s 00:00 [######################] 100%
ca-certificates-moz... 355.7 KiB 827K/s 00:00 [######################] 100%
libutil-linux-2.28-... 251.3 KiB 1323K/s 00:00 [######################] 100%
curl-7.48.0-1-armv7h 769.1 KiB 3.00M/s 00:00 [######################] 100%
iptables-1.6.0-1-armv7h 258.5 KiB 2.52M/s 00:00 [######################] 100%
libgpg-error-1.22-1... 127.4 KiB 708K/s 00:00 [######################] 100%
libgcrypt-1.7.0-2-a... 381.0 KiB 1905K/s 00:00 [######################] 100%
cracklib-2.9.6-1-armv7h 247.9 KiB 1181K/s 00:00 [######################] 100%
libtool-2.4.6-5-armv7h 393.1 KiB 1456K/s 00:00 [######################] 100%
glib2-2.48.0-2-armv7h 1995.5 KiB 1720K/s 00:01 [######################] 100%
libelf-0.166-1-armv7h 329.3 KiB 867K/s 00:00 [######################] 100%
util-linux-2.28-1-a... 1661.5 KiB 348K/s 00:05 [######################] 100%
device-mapper-2.02.... 253.7 KiB 1153K/s 00:00 [######################] 100%
libassuan-2.4.2-2-a... 76.9 KiB 1281K/s 00:00 [######################] 100%
pinentry-0.9.7-2-armv7h 76.5 KiB 1530K/s 00:00 [######################] 100%
nettle-3.2-2-armv7h 323.9 KiB 831K/s 00:00 [######################] 100%
gnutls-3.4.11-2-armv7h 2.0 MiB 313K/s 00:07 [######################] 100%
gnupg-2.1.12-1-armv7h 1580.5 KiB 1129K/s 00:01 [######################] 100%
grep-2.25-1-armv7h 187.4 KiB 986K/s 00:00 [######################] 100%
dhcpcd-6.10.2-1-armv7h 132.1 KiB 0.00B/s 00:00 [######################] 100%
file-5.26-2-armv7h 236.0 KiB 1573K/s 00:00 [######################] 100%
mpfr-3.1.4.p1-1-armv7h 227.5 KiB 2.22M/s 00:00 [######################] 100%
libmpc-1.0.3-2-armv7h 52.7 KiB 439K/s 00:00 [######################] 100%
gcc-6.1.1-1-armv7h 21.5 MiB 1450K/s 00:15 [######################] 100%
groff-1.22.3-6-armv7h 1707.3 KiB 1303K/s 00:01 [######################] 100%
iproute2-4.5.0-2-armv7h 557.1 KiB 1326K/s 00:00 [######################] 100%
iputils-20160308.0d... 66.5 KiB 317K/s 00:00 [######################] 100%
libnl-3.2.27-1-armv7h 277.2 KiB 866K/s 00:00 [######################] 100%
linux-firmware-2016... 36.9 MiB 363K/s 01:44 [######################] 100%
linux-raspberrypi-4... 23.9 MiB 1384K/s 00:18 [######################] 100%
logrotate-3.9.2-1-a... 31.5 KiB 197K/s 00:00 [######################] 100%
lvm2-2.02.150-1-armv7h 908.4 KiB 683K/s 00:01 [######################] 100%
make-4.1-4-armv7h 373.8 KiB 1335K/s 00:00 [######################] 100%
nano-2.5.3-2-armv7h 390.6 KiB 930K/s 00:00 [######################] 100%
pacman-mirrorlist-2... 1652.0 B 0.00B/s 00:00 [######################] 100%
pacman-5.0.1-3-armv7h 712.1 KiB 962K/s 00:01 [######################] 100%
s-nail-14.8.8-1-armv7h 264.3 KiB 911K/s 00:00 [######################] 100%
sudo-1.8.16-1-armv7h 868.1 KiB 1223K/s 00:01 [######################] 100%
python2-2.7.11-3-armv7h 10.5 MiB 950K/s 00:11 [######################] 100%
python2-cffi-1.6.0-... 178.8 KiB 596K/s 00:00 [######################] 100%
python2-idna-2.1-1-any 65.2 KiB 652K/s 00:00 [######################] 100%
python2-cryptograph... 257.2 KiB 804K/s 00:00 [######################] 100%
python2-pyopenssl-1... 64.6 KiB 1292K/s 00:00 [######################] 100%
geoip-database-2016... 799.2 KiB 1402K/s 00:01 [######################] 100%
geoip-1.6.6-2-armv7h 68.9 KiB 313K/s 00:00 [######################] 100%
nginx-1.10.0-2-armv7h 344.4 KiB 662K/s 00:01 [######################] 100%
git-2.8.2-1-armv7h 4.0 MiB 478K/s 00:09 [######################] 100%
libmnl-1.0.3-2-armv7h 7.8 KiB 0.00B/s 00:00 [######################] 100%
libnftnl-1.0.5-1-armv7h 37.8 KiB 629K/s 00:00 [######################] 100%
python2-packaging-1... 28.5 KiB 713K/s 00:00 [######################] 100%
python2-setuptools-... 215.5 KiB 979K/s 00:00 [######################] 100%
parted-3.2-4-armv7h 383.0 KiB 798K/s 00:00 [######################] 100%
jemalloc-4.1.1-1-armv7h 187.4 KiB 781K/s 00:00 [######################] 100%
icu-57.1-1-armv7h 7.7 MiB 1274K/s 00:06 [######################] 100%
ntp-4.2.8.p7-1-armv7h 1664.8 KiB 1224K/s 00:01 [######################] 100%
python2-pip-8.1.1-1-any 1327.7 KiB 2.36M/s 00:01 [######################] 100%
unzip-6.0-12-armv7h 113.3 KiB 324K/s 00:00 [######################] 100%
wget-1.17.1-2-armv7h 504.8 KiB 1122K/s 00:00 [######################] 100%
python2-psutil-4.1.... 201.3 KiB 559K/s 00:00 [######################] 100%
fail2ban-0.9.4-2-any 351.5 KiB 1098K/s 00:00 [######################] 100%
python2-pyparsing-2... 66.2 KiB 6.47M/s 00:00 [######################] 100%
supervisor-3.2.3-1-any 399.4 KiB 1109K/s 00:00 [######################] 100%
nss-pam-ldapd-0.9.6... 77.3 KiB 703K/s 00:00 [######################] 100%
redis-3.2.0-1-armv7h 343.6 KiB 2.24M/s 00:00 [######################] 100%
http-parser-2.7.0-1... 15.8 KiB 143K/s 00:00 [######################] 100%
libuv-1.9.0-1-armv7h 113.5 KiB 473K/s 00:00 [######################] 100%
nodejs-6.1.0-1-armv7h 2.8 MiB 2.99M/s 00:01 [######################] 100%
npm-3.8.9-1-any 2.5 MiB 992K/s 00:03 [######################] 100%
raspberrypi-firmwar... 2.7 MiB 1536K/s 00:02 [######################] 100%
raspberrypi-firmwar... 1743.5 KiB 2.58M/s 00:01 [######################] 100%
raspberrypi-firmwar... 1240.4 KiB 2034K/s 00:01 [######################] 100%
raspberrypi-firmwar... 29.9 MiB 1198K/s 00:26 [######################] 100%
raspberrypi-firmwar... 992.0 B 0.00B/s 00:00 [######################] 100%
arkos-core-0.7.2-1-any 106.0 KiB 331K/s 00:00 [######################] 100%
arkos-kraken-0.7.2-... 57.6 KiB 0.00B/s 00:00 [######################] 100%
(87/87) checking keys in keyring [######################] 100%
(87/87) checking package integrity [######################] 100%
(87/87) loading package files [######################] 100%
(87/87) checking for file conflicts [######################] 100%
(87/87) checking available disk space [######################] 100%
( 1/87) upgrading linux-api-headers [######################] 100%
( 2/87) upgrading tzdata [######################] 100%
( 3/87) upgrading glibc [######################] 100%
Generating locales...
en_US.UTF-8... done
en_US.ISO-8859-1... done
Generation complete.
( 4/87) upgrading binutils [######################] 100%
( 5/87) upgrading gcc-libs [######################] 100%
( 6/87) upgrading perl [######################] 100%
( 7/87) upgrading openssl [######################] 100%
( 8/87) upgrading expat [######################] 100%
( 9/87) upgrading sqlite [######################] 100%
(10/87) upgrading python2 [######################] 100%
(11/87) upgrading python2-cffi [######################] 100%
(12/87) upgrading python2-idna [######################] 100%
(13/87) upgrading python2-cryptography [######################] 100%
(14/87) upgrading python2-pyopenssl [######################] 100%
(15/87) upgrading python2-psutil [######################] 100%
(16/87) upgrading geoip-database [######################] 100%
(17/87) upgrading geoip [######################] 100%
New optional dependencies for geoip
geoip-database-extra: city/ASN databases (not needed for country lookups)
(18/87) upgrading nginx [######################] 100%
(19/87) upgrading gzip [######################] 100%
(20/87) upgrading texinfo [######################] 100%
(21/87) upgrading libtasn1 [######################] 100%
(22/87) upgrading gmp [######################] 100%
(23/87) upgrading ca-certificates-mozilla [######################] 100%
(24/87) upgrading libutil-linux [######################] 100%
(25/87) upgrading curl [######################] 100%
(26/87) upgrading git [######################] 100%
(27/87) installing libmnl [######################] 100%
(28/87) installing libnftnl [######################] 100%
(29/87) upgrading iptables [######################] 100%
(30/87) upgrading libgpg-error [######################] 100%
(31/87) upgrading libgcrypt [######################] 100%
(32/87) upgrading fail2ban [######################] 100%
(33/87) upgrading python2-pyparsing [######################] 100%
(34/87) upgrading python2-packaging [######################] 100%
(35/87) upgrading python2-setuptools [######################] 100%
(36/87) upgrading supervisor [######################] 100%
(37/87) upgrading cracklib [######################] 100%
(38/87) upgrading nss-pam-ldapd [######################] 100%
(39/87) upgrading libtool [######################] 100%
(40/87) upgrading glib2 [######################] 100%
New optional dependencies for glib2
python: for gdbus-codegen and gtester-report [installed]
(41/87) upgrading libelf [######################] 100%
(42/87) upgrading util-linux [######################] 100%
(43/87) upgrading device-mapper [######################] 100%
(44/87) upgrading libassuan [######################] 100%
(45/87) upgrading pinentry [######################] 100%
(46/87) upgrading nettle [######################] 100%
(47/87) upgrading gnutls [######################] 100%
(48/87) upgrading gnupg [######################] 100%
(49/87) upgrading parted [######################] 100%
(50/87) upgrading arkos-core [######################] 100%
warning: /etc/arkos/settings.json installed as /etc/arkos/settings.json.pacnew
(51/87) upgrading jemalloc [######################] 100%
(52/87) upgrading grep [######################] 100%
(53/87) upgrading redis [######################] 100%
(54/87) upgrading http-parser [######################] 100%
(55/87) upgrading icu [######################] 100%
(56/87) upgrading libuv [######################] 100%
(57/87) upgrading nodejs [######################] 100%
(58/87) upgrading npm [######################] 100%
(59/87) upgrading arkos-kraken [######################] 100%
(60/87) upgrading dhcpcd [######################] 100%
(61/87) upgrading file [######################] 100%
(62/87) upgrading mpfr [######################] 100%
(63/87) upgrading libmpc [######################] 100%
(64/87) upgrading gcc [######################] 100%
(65/87) upgrading groff [######################] 100%
(66/87) upgrading iproute2 [######################] 100%
(67/87) upgrading iputils [######################] 100%
(68/87) upgrading libnl [######################] 100%
(69/87) upgrading linux-firmware [######################] 100%
(70/87) upgrading linux-raspberrypi [######################] 100%
warning: /boot/config.txt installed as /boot/config.txt.pacnew
>>> Updating module dependencies. Please wait ...
(71/87) upgrading logrotate [######################] 100%
(72/87) upgrading lvm2 [######################] 100%
(73/87) upgrading make [######################] 100%
(74/87) upgrading nano [######################] 100%
(75/87) upgrading ntp [######################] 100%
(76/87) upgrading pacman-mirrorlist [######################] 100%
(77/87) upgrading pacman [######################] 100%
(78/87) upgrading python2-pip [######################] 100%
(79/87) upgrading raspberrypi-firmware-bootloader [######################] 100%
(80/87) upgrading raspberrypi-firmware-bootloa... [######################] 100%
(81/87) upgrading raspberrypi-firmware-tools [######################] 100%
(82/87) upgrading raspberrypi-firmware-examples [######################] 100%
(83/87) upgrading raspberrypi-firmware [######################] 100%
(84/87) upgrading s-nail [######################] 100%
(85/87) upgrading sudo [######################] 100%
(86/87) upgrading unzip [######################] 100%
(87/87) upgrading wget [######################] 100%
(1/1) Updating the info directory file...
[am25200@arkos ~]$
[am25200@arkos ~]$ sudo wget https://aur.archlinux.org/cgit/aur.git/snapshot/rtl8812au-rpi-dkms-git.tar.gz
--2016-05-10 00:18:12-- https://aur.archlinux.org/cgit/aur.git/snapshot/rtl8812au-rpi-dkms-git.tar.gz
Resolving aur.archlinux.org (aur.archlinux.org)... 5.9.250.164, 2a01:4f8:160:3033::2
Connecting to aur.archlinux.org (aur.archlinux.org)|5.9.250.164|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/x-gzip]
Saving to: 'rtl8812au-rpi-dkms-git.tar.gz'
rtl8812au-rpi-dkms- [ <=> ] 1.52K --.-KB/s in 0s
2016-05-10 00:18:13 (23.7 MB/s) - 'rtl8812au-rpi-dkms-git.tar.gz' saved [1558]
[color=#FF0000]tar: Refusing to read archive contents from terminal (missing -f option?)
tar: Error is not recoverable: exiting now[/color]
[am25200@arkos ~]$
[am25200@arkos ~]$ sudo tar xzf rtl8812au-rpi-dkms-git.tar.gz
[am25200@arkos ~]$ cd rtl8812au-rpi-dkms-git
[color=#FF0000]==> ERROR: Running makepkg as root is not allowed as it can cause permanent,
Aborting...[/color]
[am25200@arkos rtl8812au-rpi-dkms-git]$ sudo su
Password:
[root@arkos rtl8812au-rpi-dkms-git]# makepkg -Acs
==> Making package: rtl8812au-rpi-dkms-git 0.r54.21af4bf-1 (Tue May 10 00:43:29 CEST 2016)
==> Checking runtime dependencies...
==> Installing missing dependencies...
Packages (1) dkms-2.2.0.3+git151023-10
Total Download Size: 0.05 MiB
Total Installed Size: 0.23 MiB
dkms-2.2.0.3+git151... 50.5 KiB 505K/s 00:00 [######################] 100%
(1/1) installing dkms [######################] 100%
Optional dependencies for dkms
linux-headers: build modules against the Arch kernel
linux-lts-headers: build modules against the LTS kernel
linux-zen-headers: build modules against the ZEN kernel
linux-grsec-headers: build modules against the GRSEC kernel
==> Checking buildtime dependencies...
==> Retrieving sources...
-> Cloning rtl8812au git repo...
Cloning into bare repository '/home/am25200/rtl8812au-rpi-dkms-git/rtl8812au'...
remote: Counting objects: 515, done.
remote: Total 515 (delta 0), reused 0 (delta 0), pack-reused 515
Receiving objects: 100% (515/515), 1.56 MiB | 1.33 MiB/s, done.
Resolving deltas: 100% (188/188), done.
Checking connectivity... done.
-> Found rpi.diff
-> Found dkms.conf
==> Validating source files with md5sums...
rtl8812au ... Skipped
rpi.diff ... Passed
dkms.conf ... Passed
==> Extracting sources...
-> Creating working copy of rtl8812au git repo...
Cloning into 'rtl8812au'...
done.
==> Starting prepare()...
patching file Makefile
==> Starting pkgver()...
==> Updated version: rtl8812au-rpi-dkms-git 0.r56.38b565a-1
[color=#FF0000]/usr/bin/makepkg: line 170: fakeroot: command not found[/color]
Packages (1) fakeroot-1.20.2-1
Total Download Size: 0.06 MiB
Total Installed Size: 0.20 MiB
fakeroot-1.20.2-1-a... 62.8 KiB 483K/s 00:00 [######################] 100%
(1/1) installing fakeroot [######################] 100%
==> Making package: rtl8812au-rpi-dkms-git 0.r56.38b565a-1 (Tue May 10 00:51:42 CEST 2016)
-> Updating rtl8812au git repo...
Fetching origin
-> Found rpi.diff
-> Found dkms.conf
rpi.diff ... Passed
Switched to a new branch 'makepkg'
==> Removing existing $pkgdir/ directory...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issue...
==> Creating package "rtl8812au-rpi-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Adding install file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtl8812au-rpi-dkms-git 0.r56.38b565a-1 (Tue May 10 00:52:32 CEST 2016)
==> Cleaning up...
[am25200@arkos rtl8812au-rpi-dkms-git]$ dir
ERROR: rtl8812au
PKGBUILD rtl8812au-rpi-dkms-git-0.r56.38b565a-1-armv7h.pkg.tar.xz
dkms.conf rtl8812au-rpi-dkms-git.install
rpi.diff
loading packages...
[color=#FF0000]Error! echo
==> No kernel * modules. You must install them to use DKMS![/color]
Thank you very much again!
