cool, I did it and it compiled perfectly.
Doesn't work though! I am playing files of a USB stick that works under rasbian OMXplayer so I know its not the file. It doesn't wish me a nice day it just clears the screen and hangs.
I cant really understand the log file , it doesn't seem to be complaining and states all the libraries its using then opens a stream and ends at the .... audio
thanks very much for updating the repo for me!
00:00:00 T:0 DEBUG: DllBcm: Using omx system library
00:00:00 T:0 DEBUG: DllOMX: Using omx system library
00:00:00 T:0 DEBUG: DllAvFormat: Using libavformat system library
00:00:00 T:0 DEBUG: DllAvUtilBase: Using libavutil system library
00:00:00 T:0 DEBUG: DllAvCodec: Using libavcodec system library
00:00:00 T:0 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81
00:00:00 T:0 DEBUG: Previous line repeats 5 times.
00:00:00 T:0 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_decode input port 130 output port 131
00:00:00 T:0 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_render input port 90 output port 90
00:00:00 T:0 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_scheduler input port 10 output port 11
00:00:00 T:0 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.text_scheduler input port 150 output port 151
00:00:00 T:0 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - iport(130), nBufferCountMin(1), nBufferCountActual(60), nBufferSize(81920), nBufferAlignmen(16)
00:00:00 T:0 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.text_scheduler) - iport(150), nBufferCountMin(1), nBufferCountActual(100), nBufferSize(1024), nBufferAlignmen(16)
00:00:00 T:0 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.text_scheduler) - iport(151), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(1024) nBufferAlignmen(16)
00:00:00 T:0 ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.video_decode - OMX_ErrorInsufficientResources, insufficient resources
00:00:00 T:0 DEBUG: COMXVideo::Open - decoder_component(0x0x1c504c8), input_port(0x82), output_port(0x83) deinterlace 0 hdmiclocksync 0
00:00:00 T:0 DEBUG: OMXThread::Create - Thread with id 1165239392 started
00:00:00 T:0 INFO: COMXAudioCodecOMX::GetChannelMap - FFmpeg reported 1 channels, but the layout contains 0 ignoring
00:00:00 T:0 DEBUG: Previous line repeats 2 times.
00:00:00 T:0 INFO: CPCMRemap: I channel map: CE
00:00:00 T:0 DEBUG: CPCMRemap: Mapping mono audio to front left and front right
00:00:00 T:0 DEBUG: pcm->nPortIndex : 0
00:00:00 T:0 DEBUG: pcm->eNumData : 0
00:00:00 T:0 DEBUG: pcm->eEndian : 1
00:00:00 T:0 DEBUG: pcm->bInterleaved : 1
00:00:00 T:0 DEBUG: pcm->nBitPerSample : 16
00:00:00 T:0 DEBUG: pcm->ePCMMode : 0
00:00:00 T:0 DEBUG: pcm->nChannels : 1
00:00:00 T:0 DEBUG: pcm->nSamplingRate : 48000
00:00:00 T:0 DEBUG: OMX_AUDIO_ChannelCF
00:00:00 T:0 DEBUG: OMX_AUDIO_ChannelRF
00:00:00 T:0 DEBUG: pcm->nChannels : 2
00:00:00 T:0 DEBUG: OMX_AUDIO_ChannelLF
00:00:00 T:0 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100
00:00:00 T:0 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_decode input port 120 output port 121
00:00:00 T:0 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231
00:00:00 T:0 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_decode) - iport(120), nBufferCountMin(4), nBufferCountActual(31), nBufferSize(6144), nBufferAlignmen(16)
00:00:00 T:0 DEBUG: COMXAudio::Initialize Ouput bps 16 samplerate 48000 channels 2 device local buffer size 192000 bytes per second 96000 passthrough 0 hwdecode 0
00:00:00 T:0 DEBUG: COMXAudio::Initialize Input bps 16 samplerate 48000 channels 1 device local buffer size 192000 bytes per second 96000 passthrough 0 hwdecode 0
00:00:00 T:0 DEBUG: OMXThread::Create - Thread with id 1173628000 started
00:00:00 T:0 DEBUG: pcm->nPortIndex : 232
00:00:00 T:0 DEBUG: pcm->nPortIndex : 100
