Liam Fraser said:
The latest image is the 29th of april. Pepedog has posted it on the 1st of may (few posts back)
Not sure why it's not on the downloads page yet. Will get onto Liz and Eben.
Yeah, I was wondering that too - the lazy layabouts!
May want to try that
pacman'ing as I type
- nick.mccloud
Re: ArchlinuxARM on Raspberry Pi
Pico/RP2040 ≠ Arduino
Pico = hot rod kit car, Arduino = hot rod kit car wrapped in cotton wool with buoyancy aids & parachute
- Contact: Website
It's on the downloads page now .
Hope it goes well for you!
Thanks Liam... and on a UK Bank Holiday too!
(Mind you with typical English Bank Holiday weather, what else is there to do? )
- Contact: Website
I'm afraid my day is consisting of phone shopping after I found out my old one has been through the wash
well at least it's nice and clean
- nick.mccloud
SUCCESS!
OK, downloaded 29-04-12, 'burnt' to the card, setup, got lxde working WITH mouse!
Got Geany & Python working together. As Dom says, Arch feels more spritely than Debian, looking good.
I'd like to be able to view web pages so I can lookup documentation. However:
1. Netsurf doesn't even put in a showing
2. Midori launches, opens Google (default page) and then crashes out, mostly when I try and click some thing, sometimes just when the pointer is moved over the window.
3. FireFox won't install because pacman is having problems getting hold of XULRunner.
I'll work on figuring out logs and crash info and getting FireFox installed but in the meanwhile ...
... am I expecting too much too soon?
Happy to carry on testing - next I'll look at web serving & some such.
Ok, I"m going to recommend lynx (not the armpit one) for browsing, real fast
- nick.mccloud
lol, too much too soon I guess - lynx it is then! Will I be mobbed by hundreds of women??
xfce works nicely but no joy with:
netsurf - will track down the missing liblcms.
midori - segmentation fault - will try a native compile.
firefox - xulrunner missing from all mirrors - will try to compile.
- Raspberry Pi Engineer & Forum Moderator
Chromium works well under debian - does it work with Arch?
Think chromium might need xulrunner too
I scraped the Debian chromium out of various debs and dependencies. Not a lot of help (slightly more stable on Debian, but that's damning with faint praise). It's too old (chromium 6?) to be useful (ad block won't install). So here also, xulrunner is building. I recall giving up on gentoo many years (>10) ago because of continual firefox rebuilds ... deja vu.
- nick.mccloud
netsurf just needed lcms installing - so I can now graphically surf.
midori's ./waf configure bums out and I'm adding print "you are here" statements to try to find why.
firefox's xulrunner source being downloaded now (it's already built for armv7 but not 5).
midori-git builds just fine. Alas, it is no more stable than community/midori.
With mpthompson building debian for hard float, I am curious if arch would also benefit from being build with hf?
And if so, is someone (considering) working on this?
Nr90, you are welcome to discuss hard float with our builder, biggest hurdle is 6gb server storage, then convince him it"s beneficial, he don"t have a pi
Spennig and nmcc, appreciate help on this
- nick.mccloud
Where and what for?
That may be an easy $35 spend!
Where and what for?
Having started yesterday to build omxplayer on the device (which has a 16G Class 10 SD card), I soon reverted to QEMU (which I can give more memory, plus I think emulated HDD I/O is faster than native SD), even then it took hours. How long does building Arch take? Weeks, months? It looks like a lot of pain for a small gain.
Nmcc, apparently the server(s) the repos on doesn"t have room
As for getting a pi, I think he fell into same trap as me, I delayed ordering, delivery days put me off, and stuck in that loop.
Spennig, well building on pi with distcc to crosstools roars along, only slows down doing LD and packing. Kernel takes about 10 minutes, then 20 minutes doing rest.
No one gets paid on alarm, relies on donations.
Running arch on raspberry pi, open box, tint2.
1.I want running some browser , but midori crashing, firefox (error: failed retrieving file 'xulrunner-1.9.2.15-2-arm.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404).
Which browser recommended? Which is working?
2.want play iptv. Install vlc, and dont play, return some no xvideo driver error.
Which player recommended.
3.alsa sound driver, modprobe snd-bcm2835 is ok.
How install this module automaticly?
Thanx for ideas, recommendation.
- nick.mccloud
For this combo you may want to consider the standard Debian release and check out the OpenELEC & xmbc threads too.
Hey, trn!
3.) Almost everything important can be configured in /etc/rc.conf. Edit this file with an editor of your choice, for beginners nano is recommanded:
nano /etc/rc.conf
(You need to be root or use sudo)
In /etc/rc.conf the is a section called hardware, where you should find
MODULES=()
Just change it to
MODULES=(snd-bcm2835)
and the module will be loaded on every boot. Btw: Most modules are loaded automatically, so put only modules that aren't autodetected in there.
2) As you say VLC does not start because of a missing xvideo driver. This is because there is at the moment no such driver for Raspberry Pi. What happens if you choose the opengl driver? (I don't have I Raspberry Pi, so I can't try.) I think the x11 driver would also work, but it is most likely to be much to slow.
1) The strength of Arch Linux is the ability to write PKGBUILDS. A PKGBUILD is a cooking recipe of building a specifig package. Once you have your PKGBUILD, you can build your package with
makepkg
within the folder of your PKGBUILD. You can install the package after this with "pacman -U".
If you have installed "abs" and you run
abs
in a terminal, you will get PKGBUILDS of all packages that are available in Arch Linux. The PKGBUILDS are located in /var/abs/$repository/$package-name/PKGBUILD. Where $repository is the repository (like core, extra, community, …) and $package-name is the name of the package. Make sure you copy the hole folder containing you PKGBUILD somewhere in your homefolder:
cp /var/abs/extra/xulrunner $HOME -R
You will notice, that the PKGBUILD doesn't compile out of the box, because abs will catch only x86 / x86-64 PKGBUILDS. But in 99% of the cases just adding "arm" to the arch section of the PKGBUILD will work out of the box.
You are also free to use
makepkg -A
because the "-A" will force makepkg to cook your package even if it is not for your architecture.
If you really want to see how linux works I recommend you to keep using Arch Linux instead of Debian. You propably will need a bit more help at the beginning, but it's totally worth the trouble! There are very nice people in the arch forum (both archlinux.org and archlinuxarm.org) who will help you.
Cheers,
Maribu
PS: Sorry for my lack of English
nano /etc/rc.conf
MODULES=()
Just change it to
makepkg
abs
makepkg -A
Cheers,
Maribu
My first touch with arch.
If i dont get raspPi then dont view arch.
And i like arch.
On notebook use crunchbang, i like openbox.
More that package built, i like configure make.
And i like arch.
Why stick with Debian? Arch/OpenBox/tint2 is a pretty lightweight combo, no? However I myself am having a lot of trouble getting SLiM and OpenBox to autostart after editing /rc.conf and /.xinitrc . Is this a ArchArm issue?
3) thanx, i remember now MODULES
2)
now vlc is running, when starting network stream udp://@IP:5000, sound and video starting, but in vlc view error messages:
libdvbpsi error(PSI decoder): TS discotinuity
Pulseaudio server connection failure
no available XVideo adaptor
no matching GLX frame buffer configuration
any ideas for solving this
1) please
someone use arch on raspPi, which browser is working and how to install
2)
1) please
update pacman -Syyu, new kernel 13+, new firmware
After change to 192/64 arch and reboot, rpi is not booting!
