cowpat
perl-proc-processtable
Fri Jul 27, 2012 5:18 pm
I'm trying to build the linuxtv 'media_build' drivers.
ERROR: please install "Proc::ProcessTable", otherwise, build won't work.
You should install those package(s) (repository/package):  aur/perl-proc-processtable
Problem is I can't find the perl-proc-processtable package ??
Michael.
ph0ng
Re: perl-proc-processtable
Sat Jul 28, 2012 9:58 am
Since it is in AUR, you will need to build it yourself. This is trivial most of the time, see https://wiki.archlinux.org/index.php/Ar ... Repository for instructions. Grab the tarball from http://aur.archlinux.org/packages.php?ID=10752
Good luck :)
cowpat
Sun Jul 29, 2012 1:48 pm
lovely, I saw that I had some aur repository in pacman.conf... so I thought I ought to check before I got my hands dirty, but the makepkg was relatively painless, and worked a treat. Thanks for the head start on the aur links.
Michael.
Return to “Arch”
