skiwithpete
text is too wide
Fri Jul 20, 2012 10:31 am
When I first boot Arch, the text is too wide for the screen.
I see:
"i login:"
"word:"
I'm not even at the point of installing X and the screen is too wide. How can I reduce it in size?
//edit: It's also too tall.
Cheers,
P
Notes:
Raspberry Pi
HDMI -> Panasonic TV
joan
Re: text is too wide
Fri Jul 20, 2012 11:13 am
I use composite output to a TV and had a similar problem.
Create a file called config.txt and put it into the /boot directory.
Mine contains
sdtv_mode=0
overscan_left=24
overscan_right=24
You'll need to experiment with the overscan figures.
config.txt is read during boot. If you search the forums you'll find lots of info.
Edited to add: I don't know if overscan is relevant to hdmi displays.
skiwithpete
Fri Jul 20, 2012 11:39 am
Ok, this is what I had to do:
/boot/config.txt
disable_overscan=0
I was able to open the file, but I couldn't see it. So, I popped out the SD card from the Raspi and stuck it back in my computer and edited it.
Perhaps someone can write a line to enter for users so they don't need to edit the file externally.
Also - it makes sense for future releases to have diasble_overscan=0 as the default setting.
// edit: still need to find a way to make it fit the screen properly, but at least I can see it now.
ph0ng
Fri Jul 20, 2012 11:41 am
Notes:
Raspberry Pi
I use these settings for my Panasonic TX-P50G30Y for perfect screen utilization:
overscan_left=20
overscan_right=20
overscan_top=10
overscan_bottom=10
(source: http://www.raspberrypi.org/phpBB3/viewt ... 244#p66244)
EDIT: you already found the disable_overscan setting
Return to “Arch”
