system upgrade: kmod
Posted: Mon Jul 16, 2012 3:26 pm
by hcjlnx
hi guys,
i have got a problem upgrading my system. new kmod requires moving the kernel modules from /lib to /usr/lib. i upgraded kmod ignored the new kernel linux-raspberrypi-3.1.9-29 and moved the whole modules directory to /usr/lib. after that i installed the kernel. i had to do this twice, because after the first run modules directory was again created under /lib.
now rebooting fails. i just get into the rescue system.
any ideas?
hcjl
Re: system upgrade: kmod
Posted: Mon Jul 16, 2012 3:42 pm
by naicheben
Posted: Mon Jul 16, 2012 4:05 pm
by naicheben
Ah, it was an error and will be fixed today/tomorrow.
The solution was to make a symlink after updating and then update the modules:
pacman -Syu
ln -s /lib/modules /usr/lib/modules
depmod -a
But you should remove the symlink before updating again tomorrow!
Posted: Mon Jul 16, 2012 4:24 pm
by hcjlnx
ah, i did it the other way round. symlink first and then the upgrade.
just try it again;-)
Posted: Mon Jul 16, 2012 4:46 pm
by hcjlnx
thx, that did the trick.
Posted: Tue Jul 17, 2012 7:52 pm
by hcjlnx
i restored an image i made before update. now new packages are:
automake-1.12.2-1
bash-4.2.036-1
hwids-20120711-1
initscripts-2012.06.3-2.1
iputils-20101006-4
kmod-9-2
libsystemd-186-2
linux-headers-raspberrypi-3.1.9-30
linux-raspberrypi-3.1.9-30
pcre-8.31-1
pkg-config-0.27-1
procps-ng-3.3.3-3
raspberrypi-firmware-20120714-1
readline-6.2.003-2
syslog-ng-3.3.5-2
systemd-tools-186-2
usbutils-006-1
util-linux-2.21.2-5
just upgrading results in the same error i had before. first upgrading kmod, creating symlink, running depomod -a as well.
do i have to wait for kmod > kmod-9-2?
on my i686 and x86_64 machines kmod and glibc update went fine.
btw ma i the only one with this problem?
thx again & regards
hcjl
Posted: Tue Jul 17, 2012 8:34 pm
by naicheben
I have removed the symlink before upgrading and all went well.
Posted: Wed Jul 18, 2012 11:36 am
by hcjlnx
naicheben wrote:I have removed the symlink before upgrading and all went well.
well, that's good for you;-)
but i now don't know what to do in which order. as i said i restored a backup image, which i created before kmod update.
do i have to
1. upgrade kmod
2. mv /lib/modules /usr/lib/modules
3. upgrade kernel and the rest?
obviously not, because i did it like this and now my system doesn't boot anymore. i just receive the rescue login.
would you please be so kind and assist me again?
thx & rgds
Posted: Wed Jul 18, 2012 11:58 am
by naicheben
To remove the symlink you have to
rm /usr/lib/modules
The command "mv" moves the files from /lib/modules to /usr/lib/modules but you must not do that. I You can make the symlink like described before:
and kmod will look into /usr/lib/modules witch is a redirection to /lib/modules and find the files there.
So as I understand you first have to set the symlink, upgrade kmod, remove the symlink and then update the system?
Posted: Wed Jul 18, 2012 1:57 pm
by pepedog
There is now a newer kernel where modules are in /usr/lib/modules
Not sure if you have to remove symlink first, but pacman -Syu should be ok now.
Watch out for upcoming glibc update, /lib will become a symlink to /usr/lib
Posted: Wed Jul 18, 2012 7:15 pm
by hcjlnx
naicheben wrote:So as I understand you first have to set the symlink, upgrade kmod, remove the symlink and then update the system?
proceeding like this ****ed it up as well.
maybe the problem is something else. i will start from scratch with reinstalling.
thx for your help.
rgds
hcjl
Posted: Thu Jul 19, 2012 6:27 pm
by hcjlnx
the problem wasn't the kmod or kernel update.
it was this https://github.com/archlinuxarm/PKGBUILDs/issues/211
thx again
hcjl
Posted: Thu Jul 19, 2012 6:31 pm
by hcjlnx
how can i mark this thread as solved?
Posted: Sun Jul 22, 2012 11:40 am
by naicheben
Good question. It looks like you can only edit the topic subject if nobody replied and only for a short periode.
But you can reply to this and change the subject to [SOLVED] this appears in the search results (at least). :roll:
[SOLVED] system upgrade: kmod
Posted: Sun Jul 22, 2012 2:28 pm
by hcjlnx
Problem solved. Please read thread.
Posted: Sun Jul 22, 2012 2:42 pm
by naicheben
hcjlnx wrote:how can i mark this thread as solved?
You may have solved the problem upgrading kmod ... but not how to makr the thread subject as [SOLVED]
But ok, never mind.
