laughing_octopus
Help connecting to the internet - absolute beginner
Sat Jul 14, 2012 11:03 pm
Hello everyone,
I just got my raspberry pi and installed arch linux but I am unable to connect to the internet. Is there an beginners guide on how to do this?
I have used linux before but not very much and got the rasp in order to learn.
Thanks.
felix123
Re: Help connecting to the internet - absolute beginner
Sat Jul 14, 2012 11:06 pm
How do you usually connect to the internet?
laughing_octopus
Sat Jul 14, 2012 11:15 pm
I live in a university campus so I do not have access to any router.
I simply connect it to the socket.
The connect seems to be up. When I input 'ip address' on the pi eth0 shows as up but it fails to ping and is failing to obtain pacman packages...
It also does not have wireless_tools
Xaero252
Sun Jul 15, 2012 5:18 am
What is the result of the command "ifconfig?"
Psyconaughty
Thu Jul 19, 2012 10:56 pm
Did you do
"ip link set eth0 up"
Then,
"dhcpcd eth0"?
deadgoose
Tue Jul 24, 2012 9:41 pm
laughing_octopus wrote:Hello everyone,
Thanks.
I couldn't get mine to recognize any of my various WiFi adapters. However, my PC running Windows XP works fine on the Internet (WiFi link to router in other part of house). I set up an Ethernet "Bridge," and connected the RPi that way. Works fine.
/paul W3FIS
tniemi
Wed Aug 08, 2012 7:37 am
Hello! An another raspi-newb here...
deadgoose wrote:However, my PC running Windows XP works fine on the Internet (WiFi link to router in other part of house). I set up an Ethernet "Bridge," and connected the RPi that way. Works fine.
May I ask how did you do that?
I have a 3G Internet via USB in my WindowsXP laptop. I tried to share that via ethernet LAN using these instructions:
http://support.microsoft.com/kb/306126
In Pi (wheezy) I changed the ethernet to use a static IP (instead of DHCP):
pi@raspberrypi ~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
# Get IP dynamically via DHCP
#iface eth0 inet dhcp
# Fixed IP
iface eth0 inet static
address 192.168.0.2
netmask 255.255.255.0
gateway 192.168.0.1
After a reboot I am able to connect from WinXP to Pi using SSH:
> putty.exe 192.168.0.2
Pinging 192.168.0.2 works also, no problem.
However, I am unable to ping WinXP (192.168.0.1) from Pi:
pi@raspberrypi ~ $ ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data.
(nothing happens)
No error message, nothing.
At first I suspected firewalls, but I shut down my Comodo and turned off the Windows Firewall to no avail.
Any ideas?
ph0ng
Wed Aug 08, 2012 4:18 pm
First of all, are you able to ping yourself from you Windows machine (i.e. 192.168.0.1)? I have little experience of internet sharing in Windows since I always use a router, but I've read that such problems exist.
tniemi
Thu Aug 09, 2012 8:42 am
ph0ng wrote:First of all, are you able to ping yourself from you Windows machine (i.e. 192.168.0.1)?
Yes. "ping 192.169.0.1" works as expected in WinXP. I checked if I had turned off some essential service but I was unable to find anything relevant.
I guess one way would be to boot my WinXP laptop into some Linux live distro via USB and try to configure that... Unfortunately last time I booted into Linux it did not find my cheap-ass 3G modem (BandLuxe C179).
tniemi
Sat Aug 11, 2012 8:10 pm
PROBLEM SOLVED. Selecting "Exit" from COMODO's menu does not disable it. It just looks like it does.
I uninstalled COMODO and now I can ping both 192.168.0.1 and 8.8.8.8 from my Raspberry Pi.
Unfortunately I messed both my WinXP's and Pi's network settings when debugging. I am going to clean things up and test things again. After that I could write a simple HOWTO to WinXP-ethernet-Pi Internet connection setup.
(Feeling victorious! :mrgreen:)
Return to “Arch”
