sunoon9
[Resolved] JVM exit unexpectedly when launch i2p
Sun May 31, 2015 9:47 am
I would like your advise for a problem that i can't resolve. When i try to launch i2p, JVM fails unexpectedly :
# JRE version: OpenJDK Runtime Environment (7.0_79-b14) (build 1.7.0_79-b14)
2015/05/31 11:38:53 | # Java VM: OpenJDK Zero VM (24.79-b02 mixed mode linux-arm )
2015/05/31 11:38:53 | # Derivative: IcedTea 2.5.5
2015/05/31 11:38:53 | # Distribution: Custom build (Thu Apr 16 06:55:03 MDT 2015)
2015/05/31 11:38:53 | # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
2015/05/31 11:38:53 | # An error report file with more information is saved as:
2015/05/31 11:38:53 | # /home/pi/.i2p/hs_err_pid1299.log
2015/05/31 11:38:53 | # If you would like to submit a bug report, please include
2015/05/31 11:38:53 | # instructions on how to reproduce the bug and visit:
2015/05/31 11:38:53 | # http://icedtea.classpath.org/bugzilla
2015/05/31 11:38:53 | # The crash happened outside the Java Virtual Machine in native code.
2015/05/31 11:38:53 | # See problematic frame for where to report the bug.
2015/05/31 11:39:01 | JVM received a signal UNKNOWN (6).
2015/05/31 11:39:01 | JVM process is gone.
2015/05/31 11:39:01 | JVM exited unexpectedly.
2015/05/31 11:39:18 | Launching a JVM...
2015/05/31 11:39:23 | WrapperManager: Initializing...
2015/05/31 11:39:29 | Starting I2P 0.9.19-0
2015/05/31 11:39:30 | WARN: There may be another router already running. Waiting a while to be sure...
2015/05/31 11:39:50 | WARN: Old router was not shut down gracefully, deleting router.ping
2015/05/31 11:39:50 | INFO: No, there wasn't another router already running. Proceeding with startup.
2015/05/31 11:39:57 | #
2015/05/31 11:39:57 | # A fatal error has been detected by the Java Runtime Environment:
2015/05/31 11:39:57 | # Internal Error (os_linux_zero.cpp:285), pid=1343, tid=2793141344
2015/05/31 11:39:57 | # fatal error: caught unhandled signal 4
Any ideas ?
sdjf
Re: JVM exit unexpectedly when launch i2p
Sun May 31, 2015 7:18 pm
Did you read the error report listed in your output? What does it say?
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
sunoon9
Mon Jun 01, 2015 6:12 am
sdjf wrote: Did you read the error report listed in your output? What does it say?
There is the pid_log :
hs_err_pid1299.log.gz
pid_log
(10.92 KiB) Downloaded 101 times
---------------  T H R E A D  ---------------
Current thread (0xa6b25d30):  JavaThread "WrapperSimpleAppMain" [_thread_in_native, id=1311, stack(0xa6620000,0xa67c0000)]
Stack: [0xa6620000,0xa67c0000],  sp=0xa66f145c,  free space=837k
Java frames:
 0xa67be2e0: istate->_thread       = 0xa6b25d30
 0xa67be2e4: istate->_bcp          = 0x00000000
 0xa67be2e8: istate->_locals       = 0xa67be330
 0xa67be2ec: istate->_constants    = 0xb03443a0
 0xa67be2f0: istate->_method       = java.lang.ClassLoader$NativeLibrary.load(Ljava/lang/String;)V
 0xa67be2f4: istate->_mdx          = 0x00000000
 0xa67be2f8: istate->_stack        = 0xa67be2d4
 0xa67be2fc: istate->_msg          = 0x00000000
 0xa67be300: istate->_result       = 0x00000000
 0xa67be304: (istate->_result)     = 0x00000000
 0xa67be308: (istate->_result)     = 0x00000000
 0xa67be30c: istate->_prev_link    = 0xa67be2d8
 0xa67be310: istate->_oop_temp     = 0x00000000
 0xa67be314: istate->_stack_base   = 0xa67be2e0
 0xa67be318: istate->_stack_limit  = 0xa67be2dc
 0xa67be31c: istate->_monitor_base = 0xa67be2e0
 0xa67be320: istate->_self_link    = 0xa67be2e0
 0xa67be324: frame_type            = INTERPRETER_FRAME
 0xa67be328: next_frame            = 0xa67be38c
 0xa67be32c: local[1]              = 0xa821a440
 0xa67be330: local[0]              = 0xa821a4e0
 0xa67be334: monitor[1]->_lock     = 0x00000009
 0xa67be338: monitor[1]->_obj      = 0xaad14918
 0xa67be33c: monitor[0]->_lock     = 0x00000009
 0xa67be340: monitor[0]->_obj      = 0xaad0b538
 0xa67be344: istate->_thread       = 0xa6b25d30
 0xa67be348: istate->_bcp          = 0xb0216e86 (bci 302)
 0xa67be34c: istate->_locals       = 0xa67be3c8
 0xa67be350: istate->_constants    = 0xb02863d8
 0xa67be354: istate->_method       = java.lang.ClassLoader.loadLibrary1(Ljava/lang/Class;Ljava/io/File;)Z
 0xa67be358: istate->_mdx          = 0xa67be31c
 0xa67be35c: istate->_stack        = 0xa67be328
 0xa67be360: istate->_msg          = 0x00000000
 0xa67be364: istate->_result       = 0xa67be3b8
 0xa67be368: (istate->_result)     = 0x0000002f
 0xa67be36c: (istate->_result)     = 0x00000001
 0xa67be370: istate->_prev_link    = 0xa6b25d30
 0xa67be374: istate->_oop_temp     = 0x00000000
 0xa67be378: istate->_stack_base   = 0xa67be334
 0xa67be37c: istate->_stack_limit  = 0xa67be320
 0xa67be380: istate->_monitor_base = 0xa67be344
 0xa67be384: istate->_self_link    = 0xa67be344
 0xa67be388: frame_type            = INTERPRETER_FRAME
 0xa67be38c: next_frame            = 0xa67be414
 0xa67be390: local[14]             = 0x00000000
 0xa67be394: local[13]             = 0x00000000
 0xa67be398: local[12]             = 0x00000000
 0xa67be39c: local[11]             = 0x00000000
 0xa67be3a0: local[10]             = 0xa821a4e0
 0xa67be3a4: local[9]              = 0x00000000
 0xa67be3a8: local[8]              = 0xaad14918
 0xa67be3ac: local[7]              = 0x00000001
 0xa67be3b0: local[6]              = 0xaad0b538
 0xa67be3b4: local[5]              = 0xaad0b538
 0xa67be3b8: local[4]              = 0xaacf6118
 0xa67be3bc: local[3]              = 0xa821a440
 0xa67be3c0: local[2]              = 0x00000001
 0xa67be3c4: local[1]              = 0xa821a218
 0xa67be3c8: local[0]              = 0xa83c0688
 0xa67be3cc: istate->_thread       = 0xa6b25d30
 0xa67be3d0: istate->_bcp          = 0xb0216c8a (bci 2)
 0xa67be3d4: istate->_locals       = 0xa67be420
 0xa67be3d8: istate->_constants    = 0xb02863d8
 0xa67be3dc: istate->_method       = java.lang.ClassLoader.loadLibrary0(Ljava/lang/Class;Ljava/io/File;)Z
 0xa67be3e0: istate->_mdx          = 0xa67be3b8
 0xa67be3e4: istate->_stack        = 0xa67be3c0
 0xa67be3e8: istate->_msg          = 0x00000000
 0xa67be3ec: istate->_result       = 0xa67be434
 0xa67be3f0: (istate->_result)     = 0xb033d588
 0xa67be3f4: (istate->_result)     = 0xb033c220
 0xa67be3f8: istate->_prev_link    = 0x00000000
 0xa67be3fc: istate->_oop_temp     = 0x00000000
 0xa67be400: istate->_stack_base   = 0xa67be3cc
 0xa67be404: istate->_stack_limit  = 0xa67be3c0
 0xa67be408: istate->_monitor_base = 0xa67be3cc
 0xa67be40c: istate->_self_link    = 0xa67be3cc
 0xa67be410: frame_type            = INTERPRETER_FRAME
 0xa67be414: next_frame            = 0xa67be46c
 0xa67be418: local[2]              = 0x00000000
 0xa67be41c: local[1]              = 0xa821a218
 0xa67be420: local[0]              = 0xa83c0688
 0xa67be424: istate->_thread       = 0xa6b25d30
 0xa67be428: istate->_bcp          = 0xb0216a58 (bci 48)
 0xa67be42c: istate->_locals       = 0xa67be484
 0xa67be430: istate->_constants    = 0xb02863d8
 0xa67be434: istate->_method       = java.lang.ClassLoader.loadLibrary(Ljava/lang/Class;Ljava/lang/String;Z)V
 0xa67be438: istate->_mdx          = 0xa6b25d30
 0xa67be43c: istate->_stack        = 0xa67be418
 0xa67be440: istate->_msg          = 0x00000000
 0xa67be444: istate->_result       = 0xb0339618
 0xa67be448: (istate->_result)     = 0xb0336880
 0xa67be44c: (istate->_result)     = 0x00000000
 0xa67be450: istate->_prev_link    = 0xa67be42c
 0xa67be454: istate->_oop_temp     = 0x00000000
 0xa67be458: istate->_stack_base   = 0xa67be424
 0xa67be45c: istate->_stack_limit  = 0xa67be410
 0xa67be460: istate->_monitor_base = 0xa67be424
 0xa67be464: istate->_self_link    = 0xa67be424
 0xa67be468: frame_type            = INTERPRETER_FRAME
 0xa67be46c: next_frame            = 0xa67be4d8
 0xa67be470: local[5]              = 0x00000000
 0xa67be474: local[4]              = 0x00000000
 0xa67be478: local[3]              = 0xaacf6118
 0xa67be47c: local[2]              = 0x00000001
 0xa67be480: local[1]              = 0xa8219080
 0xa67be484: local[0]              = 0xa83c0688
 0xa67be488: monitor[0]->_lock     = 0x00000009
 0xa67be48c: monitor[0]->_obj      = 0xaad14310
 0xa67be490: istate->_thread       = 0xa6b25d30
 0xa67be494: istate->_bcp          = 0xb02f5509 (bci 57)
 0xa67be498: istate->_locals       = 0xa67be4e8
 0xa67be49c: istate->_constants    = 0xb02f5b08
 0xa67be4a0: istate->_method       = java.lang.Runtime.load0(Ljava/lang/Class;Ljava/lang/String;)V
 0xa67be4a4: istate->_mdx          = 0x00000000
 0xa67be4a8: istate->_stack        = 0xa67be478
 0xa67be4ac: istate->_msg          = 0x00000000
 0xa67be4b0: istate->_result       = 0x00000000
 0xa67be4b4: (istate->_result)     = 0x00000000
 0xa67be4b8: (istate->_result)     = 0x00000000
 0xa67be4bc: istate->_prev_link    = 0x00000000
 0xa67be4c0: istate->_oop_temp     = 0x00000000
 0xa67be4c4: istate->_stack_base   = 0xa67be488
 0xa67be4c8: istate->_stack_limit  = 0xa67be474
 0xa67be4cc: istate->_monitor_base = 0xa67be490
 0xa67be4d0: istate->_self_link    = 0xa67be490
 0xa67be4d4: frame_type            = INTERPRETER_FRAME
 0xa67be4d8: next_frame            = 0xa67be534
 0xa67be4dc: local[3]              = 0x00000000
 0xa67be4e0: local[2]              = 0xa8219080
 0xa67be4e4: local[1]              = 0xa83c0688
 0xa67be4e8: local[0]              = 0xaad14310
 0xa67be4ec: istate->_thread       = 0xa6b25d30
 0xa67be4f0: istate->_bcp          = 0xb0219b6f (bci 7)
 0xa67be4f4: istate->_locals       = 0xa67be538
 0xa67be4f8: istate->_constants    = 0xb0289d60
 0xa67be4fc: istate->_method       = java.lang.System.load(Ljava/lang/String;)V
 0xa67be500: istate->_mdx          = 0x00000000
 0xa67be504: istate->_stack        = 0xa67be4dc
 0xa67be508: istate->_msg          = 0x00000000
 0xa67be50c: istate->_result       = 0xa67be4bc
 0xa67be510: (istate->_result)     = 0xa67be4d4
 0xa67be514: (istate->_result)     = 0x00000000
 0xa67be518: istate->_prev_link    = 0xa67be4dc
 0xa67be51c: istate->_oop_temp     = 0x00000000
 0xa67be520: istate->_stack_base   = 0xa67be4ec
 0xa67be524: istate->_stack_limit  = 0xa67be4dc
 0xa67be528: istate->_monitor_base = 0xa67be4ec
 0xa67be52c: istate->_self_link    = 0xa67be4ec
 0xa67be530: frame_type            = INTERPRETER_FRAME
 0xa67be534: next_frame            = 0xa67be584
 0xa67be538: local[0]              = 0xa8219080
 0xa67be53c: istate->_thread       = 0xa6b25d30
 0xa67be540: istate->_bcp          = 0xb0752882 (bci 154)
 0xa67be544: istate->_locals       = 0xa67be5ac
 0xa67be548: istate->_constants    = 0xb0755538
 0xa67be54c: istate->_method       = net.i2p.util.NativeBigInteger.loadFromResource(Ljava/lang/String;)Z
 0xa67be550: istate->_mdx          = 0x00000002
 0xa67be554: istate->_stack        = 0xa67be534
 0xa67be558: istate->_msg          = 0x00000000
 0xa67be55c: istate->_result       = 0xa8202bf8
 0xa67be560: (istate->_result)     = 0xa6b25d30
 0xa67be564: (istate->_result)     = 0xb07522ad
 0xa67be568: istate->_prev_link    = 0xa67be5ac
 0xa67be56c: istate->_oop_temp     = 0x00000000
 0xa67be570: istate->_stack_base   = 0xa67be53c
 0xa67be574: istate->_stack_limit  = 0xa67be528
 0xa67be578: istate->_monitor_base = 0xa67be53c
 0xa67be57c: istate->_self_link    = 0xa67be53c
 0xa67be580: frame_type            = INTERPRETER_FRAME
 0xa67be584: next_frame            = 0xa67be5f8
 0xa67be588: local[9]              = 0x00000000
 0xa67be58c: local[8]              = 0x00000000
 0xa67be590: local[7]              = 0xffffffff
 0xa67be594: local[6]              = 0xa82191f0
 0xa67be598: local[5]              = 0xa820caa8
 0xa67be59c: local[4]              = 0xa820bdf8
 0xa67be5a0: local[3]              = 0x00000000
 0xa67be5a4: local[2]              = 0xa820ef70
 0xa67be5a8: local[1]              = 0xa820b7c8
 0xa67be5ac: local[0]              = 0xa8209b08
 0xa67be5b0: istate->_thread       = 0xa6b25d30
 0xa67be5b4: istate->_bcp          = 0xb0752148 (bci 168)
 0xa67be5b8: istate->_locals       = 0xa67be610
 0xa67be5bc: istate->_constants    = 0xb0755538
 0xa67be5c0: istate->_method       = net.i2p.util.NativeBigInteger.loadNative()V
 0xa67be5c4: istate->_mdx          = 0xb020706f
 0xa67be5c8: istate->_stack        = 0xa67be5a8
 0xa67be5cc: istate->_msg          = 0x00000000
 0xa67be5d0: istate->_result       = 0xb02070a0
 0xa67be5d4: (istate->_result)     = 0xb0653ea8
 0xa67be5d8: (istate->_result)     = 0xa67be5b4
 0xa67be5dc: istate->_prev_link    = 0x00000000
 0xa67be5e0: istate->_oop_temp     = 0x00000000
 0xa67be5e4: istate->_stack_base   = 0xa67be5b0
 0xa67be5e8: istate->_stack_limit  = 0xa67be5a4
 0xa67be5ec: istate->_monitor_base = 0xa67be5b0
 0xa67be5f0: istate->_self_link    = 0xa67be5b0
 0xa67be5f4: frame_type            = INTERPRETER_FRAME
 0xa67be5f8: next_frame            = 0xa67be65c
 0xa67be5fc: local[5]              = 0xa8209b08
 0xa67be600: local[4]              = 0xa820a9c8
 0xa67be604: local[3]              = 0xa82037d0
 0xa67be608: local[2]              = 0x00000000
 0xa67be60c: local[1]              = 0x00000001
 0xa67be610: local[0]              = 0xaacf7a60
 0xa67be614: istate->_thread       = 0xa6b25d30
 0xa67be618: istate->_bcp          = 0xb075388d (bci 349)
 0xa67be61c: istate->_locals       = 0xa67be65c
 0xa67be620: istate->_constants    = 0xb0755538
 0xa67be624: istate->_method       = net.i2p.util.NativeBigInteger.<clinit>()V
 0xa67be628: istate->_mdx          = 0x00000000
 0xa67be62c: istate->_stack        = 0xa67be610
 0xa67be630: istate->_msg          = 0x00000000
 0xa67be634: istate->_result       = 0xa67be5f4
 0xa67be638: (istate->_result)     = 0x00000002
 0xa67be63c: (istate->_result)     = 0x00000000
 0xa67be640: istate->_prev_link    = 0xa67be60c
 0xa67be644: istate->_oop_temp     = 0x00000000
 0xa67be648: istate->_stack_base   = 0xa67be614
 0xa67be64c: istate->_stack_limit  = 0xa67be608
 0xa67be650: istate->_monitor_base = 0xa67be614
 0xa67be654: istate->_self_link    = 0xa67be614
 0xa67be658: frame_type            = INTERPRETER_FRAME
 0xa67be65c: next_frame            = 0xa67be668
 0xa67be660: call_wrapper          = 0xa66f2998
 0xa67be664: frame_type            = ENTRY_FRAME
 0xa67be668: next_frame            = 0xa67be6c8
 0xa67be66c: local[4]              = 0xa6b25d30
 0xa67be670: local[3]              = 0xb0213d13
 0xa67be674: local[2]              = 0xa67be6d4
 0xa67be678: local[1]              = 0xb02863d8
 0xa67be67c: local[0]              = 0xb0213db0
 0xa67be680: istate->_thread       = 0xa6b25d30
 0xa67be684: istate->_bcp          = 0xb0754218 (bci 0)
 0xa67be688: istate->_locals       = 0xa67be6d4
 0xa67be68c: istate->_constants    = 0xb0754668
 0xa67be690: istate->_method       = net.i2p.crypto.CryptoConstants.<clinit>()V
 0xa67be694: istate->_mdx          = 0xb02138e0
 0xa67be698: istate->_stack        = 0xa67be67c
 0xa67be69c: istate->_msg          = 0x00000000
 0xa67be6a0: istate->_result       = 0xa67be66c
 0xa67be6a4: (istate->_result)     = 0xa67be64c
 0xa67be6a8: (istate->_result)     = 0xa67be66c
 0xa67be6ac: istate->_prev_link    = 0xa67be66c
 0xa67be6b0: istate->_oop_temp     = 0x00000000
 0xa67be6b4: istate->_stack_base   = 0xa67be680
 0xa67be6b8: istate->_stack_limit  = 0xa67be668
 0xa67be6bc: istate->_monitor_base = 0xa67be680
 0xa67be6c0: istate->_self_link    = 0xa67be680
 0xa67be6c4: frame_type            = INTERPRETER_FRAME
 0xa67be6c8: next_frame            = 0xa67be6e0
 0xa67be6cc: local[2]              = 0x00000000
 0xa67be6d0: local[1]              = 0x00000000
 0xa67be6d4: local[0]              = 0x00000000
 0xa67be6d8: call_wrapper          = 0xa66f2c48
 0xa67be6dc: frame_type            = ENTRY_FRAME
 0xa67be6e0: next_frame            = 0xa67be734
 0xa67be6e4: local[1]              = 0xa6b25d30
 0xa67be6e8: local[0]              = 0xb02138b3
 0xa67be6ec: istate->_thread       = 0xa6b25d30
 0xa67be6f0: istate->_bcp          = 0xb074f780 (bci 0)
 0xa67be6f4: istate->_locals       = 0xa67be734
 0xa67be6f8: istate->_constants    = 0xb0753b50
 0xa67be6fc: istate->_method       = net.i2p.crypto.ElGamalEngine.<clinit>()V
 0xa67be700: istate->_mdx          = 0x00000000
 0xa67be704: istate->_stack        = 0xa67be6e8
 0xa67be708: istate->_msg          = 0x00000000
 0xa67be70c: istate->_result       = 0xa67be6cc
 0xa67be710: (istate->_result)     = 0x00000002
 0xa67be714: (istate->_result)     = 0x00000000
 0xa67be718: istate->_prev_link    = 0xa67be6e4
 0xa67be71c: istate->_oop_temp     = 0x00000000
 0xa67be720: istate->_stack_base   = 0xa67be6ec
 0xa67be724: istate->_stack_limit  = 0xa67be6e0
 0xa67be728: istate->_monitor_base = 0xa67be6ec
 0xa67be72c: istate->_self_link    = 0xa67be6ec
 0xa67be730: frame_type            = INTERPRETER_FRAME
 0xa67be734: next_frame            = 0xa67be740
 0xa67be738: call_wrapper          = 0xa66f3090
 0xa67be73c: frame_type            = ENTRY_FRAME
 0xa67be740: next_frame            = 0xa67be7a4
 0xa67be744: local[3]              = 0x00000002
 0xa67be748: local[2]              = 0xa67be798
 0xa67be74c: local[1]              = 0x00000018
 0xa67be750: local[0]              = 0xaaec62d0
 0xa67be754: monitor[0]->_lock     = 0x00000009
 0xa67be758: monitor[0]->_obj      = 0xaaec62c8
 0xa67be75c: istate->_thread       = 0xa6b25d30
 0xa67be760: istate->_bcp          = 0xb06072d7 (bci 15)
 0xa67be764: istate->_locals       = 0xa67be7b0
 0xa67be768: istate->_constants    = 0xb0668370
 0xa67be76c: istate->_method       = net.i2p.I2PAppContext.initializeElGamalEngine()V
 0xa67be770: istate->_mdx          = 0xa67be734
 0xa67be774: istate->_stack        = 0xa67be74c
 0xa67be778: istate->_msg          = 0x00000000
 0xa67be77c: istate->_result       = 0xa67be7f0
 0xa67be780: (istate->_result)     = 0x00000000
 0xa67be784: (istate->_result)     = 0xa67be750
 0xa67be788: istate->_prev_link    = 0xa67be744
 0xa67be78c: istate->_oop_temp     = 0x00000000
 0xa67be790: istate->_stack_base   = 0xa67be754
 0xa67be794: istate->_stack_limit  = 0xa67be740
 0xa67be798: istate->_monitor_base = 0xa67be75c
 0xa67be79c: istate->_self_link    = 0xa67be75c
 0xa67be7a0: frame_type            = INTERPRETER_FRAME
 0xa67be7a4: next_frame            = 0xa67be7fc
 0xa67be7a8: local[2]              = 0x00000000
 0xa67be7ac: local[1]              = 0xaaec62c8
 0xa67be7b0: local[0]              = 0xaaec62d0
 0xa67be7b4: istate->_thread       = 0xa6b25d30
 0xa67be7b8: istate->_bcp          = 0xb0607208 (bci 8)
 0xa67be7bc: istate->_locals       = 0xa67be800
 0xa67be7c0: istate->_constants    = 0xb0668370
 0xa67be7c4: istate->_method       = net.i2p.I2PAppContext.elGamalEngine()Lnet/i2p/crypto/ElGamalEngine;
 0xa67be7c8: istate->_mdx          = 0x00000000
 0xa67be7cc: istate->_stack        = 0xa67be7ac
 0xa67be7d0: istate->_msg          = 0x00000000
 0xa67be7d4: istate->_result       = 0x00000000
 0xa67be7d8: (istate->_result)     = 0x00000000
 0xa67be7dc: (istate->_result)     = 0xa67be7a0
 0xa67be7e0: istate->_prev_link    = 0xa67be794
 0xa67be7e4: istate->_oop_temp     = 0x00000000
 0xa67be7e8: istate->_stack_base   = 0xa67be7b4
 0xa67be7ec: istate->_stack_limit  = 0xa67be7ac
 0xa67be7f0: istate->_monitor_base = 0xa67be7b4
 0xa67be7f4: istate->_self_link    = 0xa67be7b4
 0xa67be7f8: frame_type            = INTERPRETER_FRAME
 0xa67be7fc: next_frame            = 0xa67be84c
 0xa67be800: local[0]              = 0xaaec62d0
 0xa67be804: istate->_thread       = 0xa6b25d30
 0xa67be808: istate->_bcp          = 0xb05fd5ff (bci 15)
 0xa67be80c: istate->_locals       = 0xa67be854
 0xa67be810: istate->_constants    = 0xb060cbf0
 0xa67be814: istate->_method       = net.i2p.router.Router.warmupCrypto()V
 0xa67be818: istate->_mdx          = 0xa67be7f8
 0xa67be81c: istate->_stack        = 0xa67be7fc
 0xa67be820: istate->_msg          = 0x00000000
 0xa67be824: istate->_result       = 0xa67be808
 0xa67be828: (istate->_result)     = 0x00000000
 0xa67be82c: (istate->_result)     = 0xa67be88c
 0xa67be830: istate->_prev_link    = 0x00000000
 0xa67be834: istate->_oop_temp     = 0x00000000
 0xa67be838: istate->_stack_base   = 0xa67be804
 0xa67be83c: istate->_stack_limit  = 0xa67be7f4
 0xa67be840: istate->_monitor_base = 0xa67be804
 0xa67be844: istate->_self_link    = 0xa67be804
 0xa67be848: frame_type            = INTERPRETER_FRAME
 0xa67be84c: next_frame            = 0xa67be8a0
 0xa67be850: local[1]              = 0x00000000
 0xa67be854: local[0]              = 0xaadf0fe8
 0xa67be858: istate->_thread       = 0xa6b25d30
 0xa67be85c: istate->_bcp          = 0xb05fb0bb (bci 19)
 0xa67be860: istate->_locals       = 0xa67be8a8
 0xa67be864: istate->_constants    = 0xb060cbf0
 0xa67be868: istate->_method       = net.i2p.router.Router.startupStuff()V
 0xa67be86c: istate->_mdx          = 0x00000000
 0xa67be870: istate->_stack        = 0xa67be850
 0xa67be874: istate->_msg          = 0x00000000
 0xa67be878: istate->_result       = 0xa67be83c
 0xa67be87c: (istate->_result)     = 0xa67be828
 0xa67be880: (istate->_result)     = 0xa67be844
 0xa67be884: istate->_prev_link    = 0xa67be844
 0xa67be888: istate->_oop_temp     = 0x00000000
 0xa67be88c: istate->_stack_base   = 0xa67be858
 0xa67be890: istate->_stack_limit  = 0xa67be83c
 0xa67be894: istate->_monitor_base = 0xa67be858
 0xa67be898: istate->_self_link    = 0xa67be858
 0xa67be89c: frame_type            = INTERPRETER_FRAME
 0xa67be8a0: next_frame            = 0xa67be904
 0xa67be8a4: local[1]              = 0x00000000
 0xa67be8a8: local[0]              = 0xaadf0fe8
 0xa67be8ac: monitor[1]->_lock     = 0x00000009
 0xa67be8b0: monitor[1]->_obj      = 0x00000000
 0xa67be8b4: monitor[0]->_lock     = 0x00000009
 0xa67be8b8: monitor[0]->_obj      = 0xaadf0fe8
 0xa67be8bc: istate->_thread       = 0xa6b25d30
 0xa67be8c0: istate->_bcp          = 0xb05fbe9f (bci 119)
 0xa67be8c4: istate->_locals       = 0xa67be91c
 0xa67be8c8: istate->_constants    = 0xb060cbf0
 0xa67be8cc: istate->_method       = net.i2p.router.Router.runRouter()V
 0xa67be8d0: istate->_mdx          = 0x00000000
 0xa67be8d4: istate->_stack        = 0xa67be8a4
 0xa67be8d8: istate->_msg          = 0x00000000
 0xa67be8dc: istate->_result       = 0x00000000
 0xa67be8e0: (istate->_result)     = 0x00000000
 0xa67be8e4: (istate->_result)     = 0xa67be8bc
 0xa67be8e8: istate->_prev_link    = 0x00000000
 0xa67be8ec: istate->_oop_temp     = 0x00000000
 0xa67be8f0: istate->_stack_base   = 0xa67be8ac
 0xa67be8f4: istate->_stack_limit  = 0xa67be898
 0xa67be8f8: istate->_monitor_base = 0xa67be8bc
 0xa67be8fc: istate->_self_link    = 0xa67be8bc
 0xa67be900: frame_type            = INTERPRETER_FRAME
 0xa67be904: next_frame            = 0xa67be968
 0xa67be908: local[5]              = 0x00000000
 0xa67be90c: local[4]              = 0x00000000
 0xa67be910: local[3]              = 0x00000000
 0xa67be914: local[2]              = 0x00000000
 0xa67be918: local[1]              = 0x00000000
 0xa67be91c: local[0]              = 0xaadf0fe8
 0xa67be920: istate->_thread       = 0xa6b25d30
 0xa67be924: istate->_bcp          = 0xb05fefc8 (bci 152)
 0xa67be928: istate->_locals       = 0xa67be980
 0xa67be92c: istate->_constants    = 0xb060cbf0
 0xa67be930: istate->_method       = net.i2p.router.Router.main([Ljava/lang/String;)V
 0xa67be934: istate->_mdx          = 0xa67be8f4
 0xa67be938: istate->_stack        = 0xa67be918
 0xa67be93c: istate->_msg          = 0x00000000
 0xa67be940: istate->_result       = 0xa6b25d30
 0xa67be944: (istate->_result)     = 0xa6b25d30
 0xa67be948: (istate->_result)     = 0xa67be990
 0xa67be94c: istate->_prev_link    = 0xb04e3608
 0xa67be950: istate->_oop_temp     = 0x00000000
 0xa67be954: istate->_stack_base   = 0xa67be920
 0xa67be958: istate->_stack_limit  = 0xa67be908
 0xa67be95c: istate->_monitor_base = 0xa67be920
 0xa67be960: istate->_self_link    = 0xa67be920
 0xa67be964: frame_type            = INTERPRETER_FRAME
 0xa67be968: next_frame            = 0xa67be98c
 0xa67be96c: local[5]              = 0x00000000
 0xa67be970: local[4]              = 0xffffffff
 0xa67be974: local[3]              = 0xa8279b90
 0xa67be978: local[2]              = 0xaadf0fe8
 0xa67be97c: local[1]              = 0x00000000
 0xa67be980: local[0]              = 0xaadf0fd8
 0xa67be984: call_wrapper          = 0xa66f3368
 0xa67be988: frame_type            = ENTRY_FRAME
 0xa67be98c: next_frame            = 0xa67be9d8
 0xa67be990: istate->_thread       = 0xa6b25d30
 0xa67be994: istate->_bcp          = 0x00000000
 0xa67be998: istate->_locals       = 0xa67be9e4
 0xa67be99c: istate->_constants    = 0xb04e3070
 0xa67be9a0: istate->_method       = sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;
 0xa67be9a4: istate->_mdx          = 0xb029b520
 0xa67be9a8: istate->_stack        = 0xb029af90
 0xa67be9ac: istate->_msg          = 0x00000000
 0xa67be9b0: istate->_result       = 0xb023b748
 0xa67be9b4: (istate->_result)     = 0x00000000
 0xa67be9b8: (istate->_result)     = 0x00000000
 0xa67be9bc: istate->_prev_link    = 0x00000000
 0xa67be9c0: istate->_oop_temp     = 0xaad8f030
 0xa67be9c4: istate->_stack_base   = 0xa67be990
 0xa67be9c8: istate->_stack_limit  = 0xa67be98c
 0xa67be9cc: istate->_monitor_base = 0xa67be990
 0xa67be9d0: istate->_self_link    = 0xa67be990
 0xa67be9d4: frame_type            = INTERPRETER_FRAME
 0xa67be9d8: next_frame            = 0xa67bea30
 0xa67be9dc: local[2]              = 0xaadf0fb8
 0xa67be9e0: local[1]              = 0x00000000
 0xa67be9e4: local[0]              = 0xaadf0f68
 0xa67be9e8: istate->_thread       = 0xa6b25d30
 0xa67be9ec: istate->_bcp          = 0xb04e2d1f (bci 87)
 0xa67be9f0: istate->_locals       = 0xa67bea40
 0xa67be9f4: istate->_constants    = 0xb04e3070
 0xa67be9f8: istate->_method       = sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;
 0xa67be9fc: istate->_mdx          = 0xa67bea44
 0xa67bea00: istate->_stack        = 0xa67be9d8
 0xa67bea04: istate->_msg          = 0x00000000
 0xa67bea08: istate->_result       = 0x00000000
 0xa67bea0c: (istate->_result)     = 0xa67be9e8
 0xa67bea10: (istate->_result)     = 0x00000000
 0xa67bea14: istate->_prev_link    = 0x00000000
 0xa67bea18: istate->_oop_temp     = 0x00000000
 0xa67bea1c: istate->_stack_base   = 0xa67be9e8
 0xa67bea20: istate->_stack_limit  = 0xa67be9c8
 0xa67bea24: istate->_monitor_base = 0xa67be9e8
 0xa67bea28: istate->_self_link    = 0xa67be9e8
 0xa67bea2c: frame_type            = INTERPRETER_FRAME
 0xa67bea30: next_frame            = 0xa67bea8c
 0xa67bea34: local[3]              = 0x00000000
 0xa67bea38: local[2]              = 0xaadf0fb8
 0xa67bea3c: local[1]              = 0x00000000
 0xa67bea40: local[0]              = 0xaadf1040
 0xa67bea44: istate->_thread       = 0xa6b25d30
 0xa67bea48: istate->_bcp          = 0xb04e337e (bci 6)
 0xa67bea4c: istate->_locals       = 0xa67bea98
 0xa67bea50: istate->_constants    = 0xb04e3608
 0xa67bea54: istate->_method       = sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;
 0xa67bea58: istate->_mdx          = 0xb023b5f8
 0xa67bea5c: istate->_stack        = 0xa67bea34
 0xa67bea60: istate->_msg          = 0x00000000
 0xa67bea64: istate->_result       = 0x00000000
 0xa67bea68: (istate->_result)     = 0x00000000
 0xa67bea6c: (istate->_result)     = 0x00000000
 0xa67bea70: istate->_prev_link    = 0x00000000
 0xa67bea74: istate->_oop_temp     = 0x00000000
 0xa67bea78: istate->_stack_base   = 0xa67bea44
 0xa67bea7c: istate->_stack_limit  = 0xa67bea34
 0xa67bea80: istate->_monitor_base = 0xa67bea44
 0xa67bea84: istate->_self_link    = 0xa67bea44
 0xa67bea88: frame_type            = INTERPRETER_FRAME
 0xa67bea8c: next_frame            = 0xa67beae4
 0xa67bea90: local[2]              = 0xaadf0fb8
 0xa67bea94: local[1]              = 0x00000000
 0xa67bea98: local[0]              = 0xaadf1058
 0xa67bea9c: istate->_thread       = 0xa6b25d30
 0xa67beaa0: istate->_bcp          = 0xb023b179 (bci 57)
 0xa67beaa4: istate->_locals       = 0xa67beaf4
 0xa67beaa8: istate->_constants    = 0xb0285ef8
 0xa67beaac: istate->_method       = java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;
 0xa67beab0: istate->_mdx          = 0xa67beaf4
 0xa67beab4: istate->_stack        = 0xa67bea8c
 0xa67beab8: istate->_msg          = 0x00000000
 0xa67beabc: istate->_result       = 0xb03fcfe8
 0xa67beac0: (istate->_result)     = 0xa6b26b84
 0xa67beac4: (istate->_result)     = 0x00000000
 0xa67beac8: istate->_prev_link    = 0x00000000
 0xa67beacc: istate->_oop_temp     = 0x00000000
 0xa67bead0: istate->_stack_base   = 0xa67bea9c
 0xa67bead4: istate->_stack_limit  = 0xa67bea84
 0xa67bead8: istate->_monitor_base = 0xa67bea9c
 0xa67beadc: istate->_self_link    = 0xa67bea9c
 0xa67beae0: frame_type            = INTERPRETER_FRAME
 0xa67beae4: next_frame            = 0xa67beb48
 0xa67beae8: local[3]              = 0xaadf1058
 0xa67beaec: local[2]              = 0xaadf0fb8
 0xa67beaf0: local[1]              = 0x00000000
 0xa67beaf4: local[0]              = 0xaadf0f68
 0xa67beaf8: monitor[0]->_lock     = 0x00000003
 0xa67beafc: monitor[0]->_obj      = 0x00000000
 0xa67beb00: istate->_thread       = 0xa6b25d30
 0xa67beb04: istate->_bcp          = 0xb03f15ed (bci 61)
 0xa67beb08: istate->_locals       = 0xa67beb60
 0xa67beb0c: istate->_constants    = 0xb03f4408
 0xa67beb10: istate->_method       = org.tanukisoftware.wrapper.WrapperSimpleApp.run()V
 0xa67beb14: istate->_mdx          = 0xb6cbf778
 0xa67beb18: istate->_stack        = 0xa67beae8
 0xa67beb1c: istate->_msg          = 0x00000000
 0xa67beb20: istate->_result       = 0xa81a72e0
 0xa67beb24: (istate->_result)     = 0xa67beb84
 0xa67beb28: (istate->_result)     = 0x00000000
 0xa67beb2c: istate->_prev_link    = 0xb6af5ed8
 0xa67beb30: istate->_oop_temp     = 0x00000000
 0xa67beb34: istate->_stack_base   = 0xa67beaf8
 0xa67beb38: istate->_stack_limit  = 0xa67beadc
 0xa67beb3c: istate->_monitor_base = 0xa67beb00
 0xa67beb40: istate->_self_link    = 0xa67beb00
 0xa67beb44: frame_type            = INTERPRETER_FRAME
 0xa67beb48: next_frame            = 0xa67bebac
 0xa67beb4c: local[5]              = 0x00000000
 0xa67beb50: local[4]              = 0x00000000
 0xa67beb54: local[3]              = 0x00000000
 0xa67beb58: local[2]              = 0x00000000
 0xa67beb5c: local[1]              = 0x00000000
 0xa67beb60: local[0]              = 0xaacf68a8
 0xa67beb64: istate->_thread       = 0xa6b25d30
 0xa67beb68: istate->_bcp          = 0xb0228d1b (bci 11)
 0xa67beb6c: istate->_locals       = 0xa67bebb0
 0xa67beb70: istate->_constants    = 0xb028a858
 0xa67beb74: istate->_method       = java.lang.Thread.run()V
 0xa67beb78: istate->_mdx          = 0x00000000
 0xa67beb7c: istate->_stack        = 0xa67beb5c
 0xa67beb80: istate->_msg          = 0x00000000
 0xa67beb84: istate->_result       = 0xa6b26b84
 0xa67beb88: (istate->_result)     = 0xa67bf674
 0xa67beb8c: (istate->_result)     = 0x00000020
 0xa67beb90: istate->_prev_link    = 0xb6cbf778
 0xa67beb94: istate->_oop_temp     = 0x00000000
 0xa67beb98: istate->_stack_base   = 0xa67beb64
 0xa67beb9c: istate->_stack_limit  = 0xa67beb5c
 0xa67beba0: istate->_monitor_base = 0xa67beb64
 0xa67beba4: istate->_self_link    = 0xa67beb64
 0xa67beba8: frame_type            = INTERPRETER_FRAME
 0xa67bebac: next_frame            = 0xa67bebbc
 0xa67bebb0: local[0]              = 0xaadf0f00
 0xa67bebb4: call_wrapper          = 0xa67bec50
 0xa67bebb8: frame_type            = ENTRY_FRAME
 0xa67bebbc: next_frame            = 0x00000000
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x01b63668 JavaThread "PRNG" daemon [_thread_in_Java, id=1338, stack(0xa5e00000,0xa5fa0000)]
  0x01b4f820 JavaThread "SimpleScheduler 4/4" daemon [_thread_blocked, id=1335, stack(0xa5fa0000,0xa6140000)]
  0x01b4e338 JavaThread "SimpleScheduler 3/4" daemon [_thread_blocked, id=1334, stack(0xa6140000,0xa62e0000)]
  0x01b4cea0 JavaThread "SimpleScheduler 2/4" daemon [_thread_blocked, id=1333, stack(0xa62e0000,0xa6480000)]
  0x01b48120 JavaThread "SimpleScheduler 1/4" daemon [_thread_blocked, id=1332, stack(0xa6480000,0xa6620000)]
  0x01b45b50 JavaThread "LogWriter" daemon [_thread_blocked, id=1331, stack(0xa67c0000,0xa6960000)]
  0x01b3d550 JavaThread "Timestamper" daemon [_thread_blocked, id=1330, stack(0xa6c53000,0xa6df3000)]
=>0xa6b25d30 JavaThread "WrapperSimpleAppMain" [_thread_in_native, id=1311, stack(0xa6620000,0xa67c0000)]
  0xb6406bb0 JavaThread "DestroyJavaVM" [_thread_blocked, id=1300, stack(0xb6526000,0xb66c5000)]
  0xa6b247d8 JavaThread "Wrapper-Connection" daemon [_thread_in_native, id=1309, stack(0xa6960000,0xa6b00000)]
  0xa72f7260 JavaThread "Wrapper-Control-Event-Monitor" daemon [_thread_blocked, id=1307, stack(0xa6df3000,0xa6f93000)]
  0xb6477f28 JavaThread "Service Thread" daemon [_thread_blocked, id=1305, stack(0xa75bb000,0xa775b000)]
  0xb6476538 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1304, stack(0xa775b000,0xa78fb000)]
  0xb6463980 JavaThread "Finalizer" daemon [_thread_blocked, id=1303, stack(0xa7ac0000,0xa7c60000)]
  0xb6462500 JavaThread "Reference Handler" daemon [_thread_blocked, id=1302, stack(0xa7c60000,0xa7e00000)]
Other Threads:
  0xb645fb98 VMThread [stack: 0xa7f75000,0xa7ff4000] [id=1301]
  0xb6479c60 WatcherThread [stack: 0xa753c000,0xa75bb000] [id=1306]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 def new generation   total 1792K, used 146K [0xa8200000, 0xa83e0000, 0xaaca0000)
  eden space 1664K,   6% used [0xa8200000, 0xa821a5c0, 0xa83a0000)
  from space 128K,  32% used [0xa83c0000, 0xa83ca428, 0xa83e0000)
  to   space 128K,   0% used [0xa83a0000, 0xa83a0000, 0xa83c0000)
 tenured generation   total 4096K, used 3861K [0xaaca0000, 0xab0a0000, 0xb0200000)
   the space 4096K,  94% used [0xaaca0000, 0xab0655e8, 0xab065600, 0xab0a0000)
 compacting perm gen  total 5632K, used 5479K [0xb0200000, 0xb0780000, 0xb4200000)
   the space 5632K,  97% used [0xb0200000, 0xb0759d88, 0xb0759e00, 0xb0780000)
No shared spaces configured.
Card table byte_map: [0xb429e000,0xb42ff000] byte_map_base: 0xb3d5d000
Polling page: 0xb6f4e000
Code Cache  [0xb437f000, 0xb43a7000, 0xb637f000)
 total_blobs=95 nmethods=0 adapters=88 free_code_cache=32697Kb largest_free_block=33481792
Compilation events (0 events):
No events
GC Heap History (10 events):
Event: 4,351 GC heap before
{Heap before GC invocations=0 (full 0):
 def new generation   total 1792K, used 1663K [0xa8200000, 0xa83e0000, 0xaaca0000)
  eden space 1664K,  99% used [0xa8200000, 0xa839ff68, 0xa83a0000)
  from space 128K,   0% used [0xa83a0000, 0xa83a0000, 0xa83c0000)
  to   space 128K,   0% used [0xa83c0000, 0xa83c0000, 0xa83e0000)
 tenured generation   total 4096K, used 0K [0xaaca0000, 0xab0a0000, 0xb0200000)
   the space 4096K,   0% used [0xaaca0000, 0xaaca0000, 0xaaca0200, 0xab0a0000)
 compacting perm gen  total 4096K, used 2108K [0xb0200000, 0xb0600000, 0xb4200000)
   the space 4096K,  51% used [0xb0200000, 0xb040f1d0, 0xb040f200, 0xb0600000)
Event: 4,417 GC heap after
Heap after GC invocations=1 (full 0):
 def new generation   total 1792K, used 128K [0xa8200000, 0xa83e0000, 0xaaca0000)
  eden space 1664K,   0% used [0xa8200000, 0xa8200000, 0xa83a0000)
  from space 128K, 100% used [0xa83c0000, 0xa83e0000, 0xa83e0000)
 tenured generation   total 4096K, used 342K [0xaaca0000, 0xab0a0000, 0xb0200000)
   the space 4096K,   8% used [0xaaca0000, 0xaacf59b8, 0xaacf5a00, 0xab0a0000)
Event: 9,264 GC heap before
{Heap before GC invocations=1 (full 0):
 def new generation   total 1792K, used 1782K [0xa8200000, 0xa83e0000, 0xaaca0000)
  eden space 1664K,  99% used [0xa8200000, 0xa839dbb8, 0xa83a0000)
 compacting perm gen  total 4352K, used 4132K [0xb0200000, 0xb0640000, 0xb4200000)
   the space 4352K,  94% used [0xb0200000, 0xb0609288, 0xb0609400, 0xb0640000)
Event: 9,402 GC heap after
Heap after GC invocations=2 (full 0):
  from space 128K, 100% used [0xa83a0000, 0xa83c0000, 0xa83c0000)
 tenured generation   total 4096K, used 956K [0xaaca0000, 0xab0a0000, 0xb0200000)
   the space 4096K,  23% used [0xaaca0000, 0xaad8f010, 0xaad8f200, 0xab0a0000)
Event: 11,622 GC heap before
{Heap before GC invocations=2 (full 0):
 def new generation   total 1792K, used 1791K [0xa8200000, 0xa83e0000, 0xaaca0000)
  eden space 1664K,  99% used [0xa8200000, 0xa839ffb0, 0xa83a0000)
 compacting perm gen  total 4864K, used 4644K [0xb0200000, 0xb06c0000, 0xb4200000)
   the space 4864K,  95% used [0xb0200000, 0xb0689078, 0xb0689200, 0xb06c0000)
Event: 11,736 GC heap after
Heap after GC invocations=3 (full 0):
 tenured generation   total 4096K, used 1347K [0xaaca0000, 0xab0a0000, 0xb0200000)
   the space 4096K,  32% used [0xaaca0000, 0xaadf0d38, 0xaadf0e00, 0xab0a0000)
Event: 35,434 GC heap before
{Heap before GC invocations=3 (full 0):
 def new generation   total 1792K, used 1762K [0xa8200000, 0xa83e0000, 0xaaca0000)
  eden space 1664K,  98% used [0xa8200000, 0xa8398960, 0xa83a0000)
 compacting perm gen  total 5632K, used 5432K [0xb0200000, 0xb0780000, 0xb4200000)
   the space 5632K,  96% used [0xb0200000, 0xb074e398, 0xb074e400, 0xb0780000)
Event: 35,531 GC heap after
Heap after GC invocations=4 (full 0):
 tenured generation   total 4096K, used 2198K [0xaaca0000, 0xab0a0000, 0xb0200000)
   the space 4096K,  53% used [0xaaca0000, 0xaaec5bc8, 0xaaec5c00, 0xab0a0000)
Event: 39,020 GC heap before
{Heap before GC invocations=4 (full 0):
  eden space 1664K,  99% used [0xa8200000, 0xa839ffa0, 0xa83a0000)
 compacting perm gen  total 5632K, used 5463K [0xb0200000, 0xb0780000, 0xb4200000)
   the space 5632K,  97% used [0xb0200000, 0xb0755fd8, 0xb0756000, 0xb0780000)
Event: 39,087 GC heap after
Heap after GC invocations=5 (full 0):
 def new generation   total 1792K, used 41K [0xa8200000, 0xa83e0000, 0xaaca0000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 35,049 Thread 0xa6b25d30 Threw 0xa82f9870 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Event: 35,092 Thread 0xa6b25d30 Threw 0xa82ff268 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Event: 35,120 Thread 0xa6b25d30 Threw 0xa830a0b0 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Event: 35,417 Thread 0xa6b25d30 Threw 0xa8316bb0 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Event: 38,743 Thread 0xa6b25d30 Threw 0xa8380ce0 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Event: 38,793 Thread 0xa6b25d30 Threw 0xa83868d0 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Event: 38,862 Thread 0xa6b25d30 Threw 0xa83982f0 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Event: 38,879 Thread 0xa6b25d30 Threw 0xa839c728 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Event: 39,176 Thread 0xa6b25d30 Threw 0xa8207ba8 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jni.cpp:721
Event: 39,275 Thread 0xa6b25d30 Threw 0xa820f3a0 at /build/java7-openjdk/src/icedtea-2.5.5/openjdk/hotspot/src/share/vm/prims/jvm.cpp:1284
Events (10 events):
Event: 38,875 loading class 0x01b70ea0
Event: 38,876 loading class 0x01b70ea0 done
Event: 38,879 loading class 0x01b2c8a0
Event: 38,879 loading class 0x01b2c8a0 done
Event: 39,011 Executing VM operation: GenCollectForAllocation
Event: 39,121 Executing VM operation: GenCollectForAllocation done
Event: 39,172 loading class 0xb6439108
Event: 39,174 loading class 0xb6439108 done
Event: 39,274 loading class 0xa6b0cec0
Event: 39,274 loading class 0xa6b0cec0 done
Dynamic libraries:
00010000-00011000 r-xp 00000000 b3:06 406969      /usr/lib/jvm/java-7-openjdk/jre/bin/java
00020000-00021000 rw-p 00000000 b3:06 406969      /usr/lib/jvm/java-7-openjdk/jre/bin/java
01b17000-01b86000 rw-p 00000000 00:00 0           [heap]
a5de3000-a5df7000 r-xp 00000000 00:1e 15714       /tmp/i2p-MQnuXuL1.tmp/libjbigi.so
a5df7000-a5dfe000 ---p 00014000 00:1e 15714       /tmp/i2p-MQnuXuL1.tmp/libjbigi.so
a5dfe000-a5dff000 r--p 00013000 00:1e 15714       /tmp/i2p-MQnuXuL1.tmp/libjbigi.so
a5dff000-a5e00000 rw-p 00014000 00:1e 15714       /tmp/i2p-MQnuXuL1.tmp/libjbigi.so
a5e00000-a5e03000 ---p 00000000 00:00 0
a5e03000-a5fa0000 rw-p 00000000 00:00 0           [stack:1338]
a5fa0000-a5fa3000 ---p 00000000 00:00 0
a5fa3000-a6140000 rw-p 00000000 00:00 0           [stack:1335]
a6140000-a6143000 ---p 00000000 00:00 0
a6143000-a62e0000 rw-p 00000000 00:00 0           [stack:1334]
a62e0000-a62e3000 ---p 00000000 00:00 0
a62e3000-a6480000 rw-p 00000000 00:00 0           [stack:1333]
a6480000-a6483000 ---p 00000000 00:00 0
a6483000-a6620000 rw-p 00000000 00:00 0           [stack:1332]
a6620000-a6623000 ---p 00000000 00:00 0
a6623000-a67c0000 rw-p 00000000 00:00 0           [stack:1311]
a67c0000-a67c3000 ---p 00000000 00:00 0
a67c3000-a6960000 rw-p 00000000 00:00 0           [stack:1331]
a6960000-a6963000 ---p 00000000 00:00 0
a6963000-a6b00000 rw-p 00000000 00:00 0           [stack:1309]
a6b00000-a6b3b000 rw-p 00000000 00:00 0
a6b3b000-a6c00000 ---p 00000000 00:00 0
a6c02000-a6c08000 r-xp 00000000 b3:06 148473      /usr/lib/libnss_dns-2.21.so
a6c08000-a6c17000 ---p 00006000 b3:06 148473      /usr/lib/libnss_dns-2.21.so
a6c17000-a6c18000 r--p 00005000 b3:06 148473      /usr/lib/libnss_dns-2.21.so
a6c18000-a6c19000 rw-p 00006000 b3:06 148473      /usr/lib/libnss_dns-2.21.so
a6c2d000-a6c53000 r--p 00000000 b3:06 263565      /usr/share/locale/fr/LC_MESSAGES/libc.mo
a6c53000-a6c56000 ---p 00000000 00:00 0
a6c56000-a6df3000 rw-p 00000000 00:00 0           [stack:1330]
a6df3000-a6df6000 ---p 00000000 00:00 0
a6df6000-a6f93000 rw-p 00000000 00:00 0           [stack:1307]
a6f93000-a6fa6000 r-xp 00000000 b3:06 148474      /usr/lib/libresolv-2.21.so
a6fa6000-a6fb5000 ---p 00013000 b3:06 148474      /usr/lib/libresolv-2.21.so
a6fb5000-a6fb6000 r--p 00012000 b3:06 148474      /usr/lib/libresolv-2.21.so
a6fb6000-a6fb7000 rw-p 00013000 b3:06 148474      /usr/lib/libresolv-2.21.so
a6fb7000-a6fb9000 rw-p 00000000 00:00 0
a6fb9000-a70a7000 r-xp 00000000 b3:06 143698      /usr/lib/libglib-2.0.so.0.4400.1
a70a7000-a70b6000 ---p 000ee000 b3:06 143698      /usr/lib/libglib-2.0.so.0.4400.1
a70b6000-a70b7000 r--p 000ed000 b3:06 143698      /usr/lib/libglib-2.0.so.0.4400.1
a70b7000-a70b8000 rw-p 000ee000 b3:06 143698      /usr/lib/libglib-2.0.so.0.4400.1
a70b8000-a71eb000 r-xp 00000000 b3:06 143940      /usr/lib/libgio-2.0.so.0.4400.1
a71eb000-a71fb000 ---p 00133000 b3:06 143940      /usr/lib/libgio-2.0.so.0.4400.1
a71fb000-a71fd000 r--p 00133000 b3:06 143940      /usr/lib/libgio-2.0.so.0.4400.1
a71fd000-a71ff000 rw-p 00135000 b3:06 143940      /usr/lib/libgio-2.0.so.0.4400.1
a71ff000-a7200000 rw-p 00000000 00:00 0
a7200000-a72f8000 rw-p 00000000 00:00 0
a72f8000-a7300000 ---p 00000000 00:00 0
a7308000-a730f000 r-xp 00000000 b3:06 406907      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libmanagement.so
a730f000-a731e000 ---p 00007000 b3:06 406907      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libmanagement.so
a731e000-a731f000 rw-p 00006000 b3:06 406907      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libmanagement.so
a731f000-a7382000 r-xp 00000000 b3:06 136528      /usr/lib/libpcre.so.1.2.5
a7382000-a7392000 ---p 00063000 b3:06 136528      /usr/lib/libpcre.so.1.2.5
a7392000-a7393000 r--p 00063000 b3:06 136528      /usr/lib/libpcre.so.1.2.5
a7393000-a7394000 rw-p 00064000 b3:06 136528      /usr/lib/libpcre.so.1.2.5
a7394000-a7396000 r-xp 00000000 b3:06 143436      /usr/lib/libgmodule-2.0.so.0.4400.1
a7396000-a73a6000 ---p 00002000 b3:06 143436      /usr/lib/libgmodule-2.0.so.0.4400.1
a73a6000-a73a7000 r--p 00002000 b3:06 143436      /usr/lib/libgmodule-2.0.so.0.4400.1
a73a7000-a73a8000 rw-p 00003000 b3:06 143436      /usr/lib/libgmodule-2.0.so.0.4400.1
a73a8000-a73ee000 r-xp 00000000 b3:06 143918      /usr/lib/libgobject-2.0.so.0.4400.1
a73ee000-a73fe000 ---p 00046000 b3:06 143918      /usr/lib/libgobject-2.0.so.0.4400.1
a73fe000-a73ff000 r--p 00046000 b3:06 143918      /usr/lib/libgobject-2.0.so.0.4400.1
a73ff000-a7400000 rw-p 00047000 b3:06 143918      /usr/lib/libgobject-2.0.so.0.4400.1
a7400000-a74fa000 rw-p 00000000 00:00 0
a74fa000-a7500000 ---p 00000000 00:00 0
a7500000-a7505000 r--s 0004d000 b3:06 394489      /usr/lib/jvm/java-7-openjdk/jre/lib/jsse.jar
a7505000-a750d000 r-xp 00000000 b3:06 792355      /home/pi/.i2p/lib/libwrapper.so
a750d000-a7514000 ---p 00008000 b3:06 792355      /home/pi/.i2p/lib/libwrapper.so
a7514000-a7515000 r--p 00007000 b3:06 792355      /home/pi/.i2p/lib/libwrapper.so
a7515000-a7516000 rw-p 00008000 b3:06 792355      /home/pi/.i2p/lib/libwrapper.so
a7516000-a752a000 r-xp 00000000 b3:06 406916      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnet.so
a752a000-a753a000 ---p 00014000 b3:06 406916      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnet.so
a753a000-a753b000 rw-p 00014000 b3:06 406916      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnet.so
a753b000-a753c000 ---p 00000000 00:00 0
a753c000-a75bb000 rw-p 00000000 00:00 0           [stack:1306]
a75bb000-a75be000 ---p 00000000 00:00 0
a75be000-a775b000 rw-p 00000000 00:00 0           [stack:1305]
a775b000-a775e000 ---p 00000000 00:00 0
a775e000-a78fb000 rw-p 00000000 00:00 0           [stack:1304]
a78fb000-a7ac0000 r--p 00000000 b3:06 152130      /usr/lib/locale/locale-archive
a7ac0000-a7ac3000 ---p 00000000 00:00 0
a7ac3000-a7c60000 rw-p 00000000 00:00 0           [stack:1303]
a7c60000-a7c63000 ---p 00000000 00:00 0
a7c63000-a7e00000 rw-p 00000000 00:00 0           [stack:1302]
a7e00000-a7e38000 rw-p 00000000 00:00 0
a7e38000-a7f00000 ---p 00000000 00:00 0
a7f02000-a7f0f000 r-xp 00000000 b3:06 406915      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnio.so
a7f0f000-a7f1e000 ---p 0000d000 b3:06 406915      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnio.so
a7f1e000-a7f1f000 rw-p 0000c000 b3:06 406915      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnio.so
a7f1f000-a7f22000 r--s 0001b000 b3:06 791698      /home/pi/.i2p/lib/wrapper.jar
a7f22000-a7f24000 r--s 00002000 b3:06 792394      /home/pi/.i2p/lib/systray.jar
a7f24000-a7f25000 r--s 0000d000 b3:06 792379      /home/pi/.i2p/lib/systray4j.jar
a7f25000-a7f27000 r--s 00015000 b3:06 791688      /home/pi/.i2p/lib/sam.jar
a7f27000-a7f2f000 r--s 00058000 b3:06 791776      /home/pi/.i2p/lib/standard.jar
a7f2f000-a7f35000 r--s 0016b000 b3:06 791880      /home/pi/.i2p/lib/routerconsole.jar
a7f35000-a7f48000 r--s 00178000 b3:06 791902      /home/pi/.i2p/lib/router.jar
a7f48000-a7f4a000 r--s 00005000 b3:06 792298      /home/pi/.i2p/lib/org.mortbay.jmx.jar
a7f4a000-a7f4f000 r--s 00053000 b3:06 791868      /home/pi/.i2p/lib/org.mortbay.jetty.jar
a7f4f000-a7f51000 r--s 00006000 b3:06 792118      /home/pi/.i2p/lib/jstl.jar
a7f51000-a7f54000 r--s 00028000 b3:06 792035      /home/pi/.i2p/lib/jrobin.jar
a7f54000-a7f56000 r--s 00019000 b3:06 791866      /home/pi/.i2p/lib/jetty-webapp.jar
a7f56000-a7f5b000 r--s 00042000 b3:06 792259      /home/pi/.i2p/lib/jetty-util.jar
a7f5b000-a7f5d000 r--s 0000a000 b3:06 791522      /home/pi/.i2p/lib/jetty-start.jar
a7f5d000-a7f5e000 r--s 00000000 b3:06 792219      /home/pi/.i2p/lib/jetty-sslengine.jar
a7f5e000-a7f60000 r--s 00016000 b3:06 791954      /home/pi/.i2p/lib/jetty-servlets.jar
a7f60000-a7f62000 r--s 00017000 b3:06 792363      /home/pi/.i2p/lib/jetty-servlet.jar
a7f62000-a7f64000 r--s 00014000 b3:06 791926      /home/pi/.i2p/lib/jetty-security.jar
a7f64000-a7f66000 r--s 00007000 b3:06 792079      /home/pi/.i2p/lib/jetty-rewrite-handler.jar
a7f66000-a7f67000 r--s 00000000 b3:06 791888      /home/pi/.i2p/lib/jetty-java5-threadpool.jar
a7f67000-a7f69000 r--s 00018000 b3:06 791624      /home/pi/.i2p/lib/jetty-io.jar
a7f69000-a7f6a000 r--s 00009000 b3:06 792171      /home/pi/.i2p/lib/jetty-xml.jar
a7f6a000-a7f6c000 r--s 00007000 b3:06 792124      /home/pi/.i2p/lib/jetty-i2p.jar
a7f6c000-a7f6e000 r--s 00016000 b3:06 792081      /home/pi/.i2p/lib/jetty-http.jar
a7f6e000-a7f71000 r--s 0000d000 b3:06 791769      /home/pi/.i2p/lib/jetty-deploy.jar
a7f71000-a7f74000 r--s 0041f000 b3:06 791951      /home/pi/.i2p/lib/jbigi.jar
a7f74000-a7f75000 ---p 00000000 00:00 0
a7f75000-a7ff4000 rw-p 00000000 00:00 0           [stack:1301]
a7ff4000-a81a5000 r--s 01d27000 b3:06 394466      /usr/lib/jvm/java-7-openjdk/jre/lib/rt.jar
a81a5000-a83e0000 rw-p 00000000 00:00 0
a83e0000-aaca0000 rw-p 00000000 00:00 0
aaca0000-ab0a0000 rw-p 00000000 00:00 0
ab0a0000-b0200000 rw-p 00000000 00:00 0
b0200000-b0780000 rw-p 00000000 00:00 0
b0780000-b4200000 rw-p 00000000 00:00 0
b4200000-b4202000 r--s 00004000 b3:06 792097      /home/pi/.i2p/lib/jetty-continuation.jar
b4202000-b4209000 r--s 0007d000 b3:06 792324      /home/pi/.i2p/lib/jasper-runtime.jar
b4209000-b4255000 rw-p 00000000 00:00 0
b4255000-b4273000 rw-p 00000000 00:00 0
b4273000-b4276000 rw-p 00000000 00:00 0
b4276000-b429e000 rw-p 00000000 00:00 0
b429e000-b429f000 rw-p 00000000 00:00 0
b429f000-b42b3000 rw-p 00000000 00:00 0
b42b3000-b42b6000 rw-p 00000000 00:00 0
b42b6000-b42de000 rw-p 00000000 00:00 0
b42de000-b42e1000 rw-p 00000000 00:00 0
b42e1000-b42fe000 rw-p 00000000 00:00 0
b42fe000-b4300000 rw-p 00000000 00:00 0
b4300000-b437f000 rw-p 00000000 00:00 0
b437f000-b43a7000 rwxp 00000000 00:00 0
b43a7000-b637f000 rw-p 00000000 00:00 0
b637f000-b6386000 r-xp 00000000 b3:06 406921      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libzip.so
b6386000-b6395000 ---p 00007000 b3:06 406921      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libzip.so
b6395000-b6396000 rw-p 00006000 b3:06 406921      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libzip.so
b6396000-b63a2000 r-xp 00000000 b3:06 148067      /usr/lib/libnss_files-2.21.so
b63a2000-b63b1000 ---p 0000c000 b3:06 148067      /usr/lib/libnss_files-2.21.so
b63b1000-b63b2000 r--p 0000b000 b3:06 148067      /usr/lib/libnss_files-2.21.so
b63b2000-b63b3000 rw-p 0000c000 b3:06 148067      /usr/lib/libnss_files-2.21.so
b63b3000-b63d5000 r-xp 00000000 b3:06 406904      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjava.so
b63d5000-b63e5000 ---p 00022000 b3:06 406904      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjava.so
b63e5000-b63e6000 rw-p 00022000 b3:06 406904      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjava.so
b63e6000-b63f0000 r-xp 00000000 b3:06 406913      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libverify.so
b63f0000-b63ff000 ---p 0000a000 b3:06 406913      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libverify.so
b63ff000-b6400000 rw-p 00009000 b3:06 406913      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libverify.so
b6400000-b64ff000 rw-p 00000000 00:00 0
b64ff000-b6500000 ---p 00000000 00:00 0
b6500000-b6505000 r--s 0003c000 b3:06 791964      /home/pi/.i2p/lib/javax.servlet.jar
b6505000-b6509000 r--s 00053000 b3:06 791827      /home/pi/.i2p/lib/i2ptunnel.jar
b6509000-b650c000 r--s 00022000 b3:06 791907      /home/pi/.i2p/lib/streaming.jar
b650c000-b650e000 r--s 00007000 b3:06 791817      /home/pi/.i2p/lib/mstreaming.jar
b650e000-b6514000 r-xp 00000000 b3:06 148157      /usr/lib/librt-2.21.so
b6514000-b6523000 ---p 00006000 b3:06 148157      /usr/lib/librt-2.21.so
b6523000-b6524000 r--p 00005000 b3:06 148157      /usr/lib/librt-2.21.so
b6524000-b6525000 rw-p 00006000 b3:06 148157      /usr/lib/librt-2.21.so
b6525000-b6529000 ---p 00000000 00:00 0
b6529000-b66c5000 rw-p 00000000 00:00 0           [stack:1300]
b66c5000-b6732000 r-xp 00000000 b3:06 148042      /usr/lib/libm-2.21.so
b6732000-b6741000 ---p 0006d000 b3:06 148042      /usr/lib/libm-2.21.so
b6741000-b6742000 r--p 0006c000 b3:06 148042      /usr/lib/libm-2.21.so
b6742000-b6743000 rw-p 0006d000 b3:06 148042      /usr/lib/libm-2.21.so
b6743000-b6806000 r-xp 00000000 b3:06 148045      /usr/lib/libstdc++.so.6.0.20
b6806000-b6815000 ---p 000c3000 b3:06 148045      /usr/lib/libstdc++.so.6.0.20
b6815000-b6819000 r--p 000c2000 b3:06 148045      /usr/lib/libstdc++.so.6.0.20
b6819000-b681b000 rw-p 000c6000 b3:06 148045      /usr/lib/libstdc++.so.6.0.20
b681b000-b6821000 rw-p 00000000 00:00 0
b6821000-b6828000 r-xp 00000000 b3:06 148152      /usr/lib/libffi.so.6.0.4
b6828000-b682f000 ---p 00007000 b3:06 148152      /usr/lib/libffi.so.6.0.4
b682f000-b6830000 r--p 00006000 b3:06 148152      /usr/lib/libffi.so.6.0.4
b6830000-b6831000 rw-p 00007000 b3:06 148152      /usr/lib/libffi.so.6.0.4
b6831000-b6ca2000 r-xp 00000000 b3:06 406937      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/server/libjvm.so
b6ca2000-b6cb1000 ---p 00471000 b3:06 406937      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/server/libjvm.so
b6cb1000-b6cd1000 rw-p 00470000 b3:06 406937      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/server/libjvm.so
b6cd1000-b6d2c000 rw-p 00000000 00:00 0
b6d2c000-b6d3f000 r-xp 00000000 b3:06 147901      /usr/lib/libz.so.1.2.8
b6d3f000-b6d46000 ---p 00013000 b3:06 147901      /usr/lib/libz.so.1.2.8
b6d46000-b6d47000 rw-p 00012000 b3:06 147901      /usr/lib/libz.so.1.2.8
b6d47000-b6d64000 r-xp 00000000 b3:06 147896      /usr/lib/libgcc_s.so.1
b6d64000-b6d73000 ---p 0001d000 b3:06 147896      /usr/lib/libgcc_s.so.1
b6d73000-b6d74000 rw-p 0001c000 b3:06 147896      /usr/lib/libgcc_s.so.1
b6d74000-b6ea0000 r-xp 00000000 b3:06 148064      /usr/lib/libc-2.21.so
b6ea0000-b6eb0000 ---p 0012c000 b3:06 148064      /usr/lib/libc-2.21.so
b6eb0000-b6eb2000 r--p 0012c000 b3:06 148064      /usr/lib/libc-2.21.so
b6eb2000-b6eb3000 rw-p 0012e000 b3:06 148064      /usr/lib/libc-2.21.so
b6eb3000-b6eb6000 rw-p 00000000 00:00 0
b6eb6000-b6eba000 r-xp 00000000 b3:06 148485      /usr/lib/libdl-2.21.so
b6eba000-b6ec9000 ---p 00004000 b3:06 148485      /usr/lib/libdl-2.21.so
b6ec9000-b6eca000 r--p 00003000 b3:06 148485      /usr/lib/libdl-2.21.so
b6eca000-b6ecb000 rw-p 00004000 b3:06 148485      /usr/lib/libdl-2.21.so
b6ecb000-b6ed7000 r-xp 00000000 b3:06 406935      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/jli/libjli.so
b6ed7000-b6ee6000 ---p 0000c000 b3:06 406935      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/jli/libjli.so
b6ee6000-b6ee7000 rw-p 0000b000 b3:06 406935      /usr/lib/jvm/java-7-openjdk/jre/lib/arm/jli/libjli.so
b6ee7000-b6efc000 r-xp 00000000 b3:06 148520      /usr/lib/libpthread-2.21.so
b6efc000-b6f0b000 ---p 00015000 b3:06 148520      /usr/lib/libpthread-2.21.so
b6f0b000-b6f0c000 r--p 00014000 b3:06 148520      /usr/lib/libpthread-2.21.so
b6f0c000-b6f0d000 rw-p 00015000 b3:06 148520      /usr/lib/libpthread-2.21.so
b6f0d000-b6f0f000 rw-p 00000000 00:00 0
b6f0f000-b6f11000 r--s 0003b000 b3:06 792182      /home/pi/.i2p/lib/i2psnark.jar
b6f11000-b6f1c000 r--s 000c2000 b3:06 792336      /home/pi/.i2p/lib/i2p.jar
b6f1c000-b6f1e000 r--s 00015000 b3:06 792296      /home/pi/.i2p/lib/desktopgui.jar
b6f1e000-b6f20000 r--s 0000d000 b3:06 792256      /home/pi/.i2p/lib/commons-logging.jar
b6f20000-b6f23000 r--s 0001f000 b3:06 792121      /home/pi/.i2p/lib/commons-el.jar
b6f23000-b6f43000 r-xp 00000000 b3:06 148173      /usr/lib/ld-2.21.so
b6f43000-b6f44000 r--s 00000000 b3:06 792212      /home/pi/.i2p/lib/jasper-compiler.jar
b6f44000-b6f45000 r--s 00009000 b3:06 791781      /home/pi/.i2p/lib/BOB.jar
b6f45000-b6f4d000 rw-s 00000000 00:1e 15575       /tmp/hsperfdata_pi/1299
b6f4d000-b6f4e000 rw-p 00000000 00:00 0
b6f4e000-b6f4f000 r--p 00000000 00:00 0
b6f4f000-b6f52000 rw-p 00000000 00:00 0
b6f52000-b6f53000 r--p 0001f000 b3:06 148173      /usr/lib/ld-2.21.so
b6f53000-b6f54000 rw-p 00020000 b3:06 148173      /usr/lib/ld-2.21.so
be832000-be853000 rw-p 00000000 00:00 0           [stack]
bebdb000-bebdc000 r-xp 00000000 00:00 0           [sigpage]
ffff0000-ffff1000 r-xp 00000000 00:00 0           [vectors]
VM Arguments:
jvm_args: -DloggerFilenameOverride=logs/[email protected] -Di2p.dir.base=/home/pi/.i2p/ -Xmx128m -Djava.library.path=/home/pi/.i2p/:/home/pi/.i2p//lib -Dwrapper.key=q-HPX5NGgVkwOYRF -Dwrapper.port=32001 -Dwrapper.jvm.port.min=31000 -Dwrapper.jvm.port.max=31999 -Dwrapper.disable_console_input=TRUE -Dwrapper.pid=1085 -Dwrapper.version=3.5.25 -Dwrapper.native_library=wrapper -Dwrapper.arch=armhf -Dwrapper.service=TRUE -Dwrapper.cpu.timeout=10 -Dwrapper.jvmid=4
java_command: org.tanukisoftware.wrapper.WrapperSimpleApp net.i2p.router.Router
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
SHELL=/bin/bash
Signal Handlers:
SIGSEGV: [libjvm.so+0x41e2ec], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x41e2ec], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x33684c], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x33684c], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x33684c], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x33684c], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x3366d8], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libwrapper.so+0x44d4], sa_mask[0]=0x00000001, sa_flags=0x10000000
SIGINT: [libwrapper.so+0x4534], sa_mask[0]=0x00000002, sa_flags=0x10000000
sdjf
Tue Jun 02, 2015 6:14 pm
Your most important clue is at the top of the error log, not in the THREAD data.
Upon googling the above error (in quotes) along with "java runtime environment", you can find lots of hits, and it looks like the following one may be something to study closely for a solution:
http://archlinuxarm.org/forum/viewtopic.php?f=15&t=5282
If the above does not help, try reading the other search engine hits for other ideas? The above one starts out mentioning signal 11, but later the poster changed to saying the problem was really signal 4.
plugh
Thu Jun 04, 2015 12:57 pm
I just brought up i2p 0.9.19 on a pi2 running the 5-5-15 raspian image
I note the following in your log
https://geti2p.net/en/download
says that Java Version 7 or 8 recommended, except Raspberry Pi: JDK 8 for ARM
viewtopic.php?p=704990#p704990
says that Oracle Java 8 (JDK version 1.8.0) is pre-installed in raspian
I observed the newer JRE version was listed in my I2P startup log.
Perhaps that is your problem?
BTW and FWIW, I *did* run into a separate problem which affects performance.
ref: https://trac.i2p2.de/ticket/1594 (and the parent ticket)
plugh
Wed Jun 10, 2015 9:43 am
FYI and FWIW...
In response to my ticket, i2p folk issued an updated jbigi package for 0.9.20 on RPi2
sunoon9
Wed Jun 10, 2015 11:42 am
thank you for your replies
Return to “Arch”
