archlinux startup problem
Posted: Tue Jul 10, 2012 7:10 pm
by rotciv
I received my RasbPi and started to use it with Debian6 and immediately after inputting the username and password I found that I needed to type STARTX for it to display anything on my screen. So now I have decided to try Arc-linux-arm and after a few failed attempts of typing username and password (root) and getting a report that these words are invalid, I have finally got in and am presented with [root@alarmpi ] ...what do I do next ?
you can also reply to: pcwizkid9@hotmail.com
Re: archlinux startup problem
Posted: Tue Jul 10, 2012 9:53 pm
by ASpotySpot
This should be posted in the Arch Linux section I think.
This is a reasonable beginner's guide for Arch on RPi.
http://www.mybiteofpi.com/guides.html
And for more detail see:
https://wiki.archlinux.org/index.php/Beginners'_Guide
However that is a general guide not just for RPi.
I'd recommend sticking with Debian till you're more familiar with Linux.
Posted: Sun Jul 15, 2012 2:09 am
by rocketero
I followed step by step as explained on http://www.mybiteofpi.com/guides.html and after 2 hours of installing and configuring, the final product was slim login screen, then after input name and password a black blank screen with a cursor like the X window. And then, it went back to the slim login screen.
in the boot process I noticed that Root (/) was mounted READ ONLY. I search about this and seems like is a problem for many since 2009.
So back to square one, probably flash Debian again (I had flashed before but was trying to see other Linux distros for pi)
