kemisten
startx dont work when used by user
Tue Jan 09, 2018 11:10 am
Hello, ive been looking for a fix to make "startx"/"xinit" as a regular user(not root) work and i finally figure it out. login as root/sudo and type startx/xinit in the console.Now the desktop should load and when your pi has loaded it open pcmanfm (file mnanager)
**On the left side press "Places" select directory three, open root folder.
**select all files and folders,right click select copy
**press home folder and then press folder thats named after your username
**right click the background inside user folder and select paste
**Log out and login on your user and run startx/xinit from consoole and there u go
Ive never used linux before and im not that good at explaining things on english so if you encounter a problem with my instructions just post it hee and ill try help you.
i made tghis thread cuz ive been looking for a ffix over a week 10+ h without any sucsess until now. Hope this fixes your ploblem to.
//benjamin
PeterO
Re: startx dont work when used by user
Tue Jan 09, 2018 1:08 pm
This is a really bad idea. This is the thing you did at some point in the past that probably caused your problem in the first place !
PeterO
Interests: C,Python,PIC,Electronics,Ham Radio (G0DZB),Aeromodelling,1960s British Computers.
B.Goode
Tue Jan 09, 2018 2:00 pm
I don't mean to belittle the Arch Distribution of Linux in its own subforum, but maybe as a new user of Raspberry Pi and Linux maybe you would be better off using the Raspberry Pi Foundation recommended and supported Raspbian version of Linux.
Running a graphical Desktop as a non-root user is enabled by default with Raspbian, no configuration changes needed.
kemisten
Wed Jan 10, 2018 11:50 am
PeterO
No thats wrong on a fresh install it gives me error when tryying to start on regular user
PeterO
Wed Jan 10, 2018 2:28 pm
Oh well, that's what you get for using odd distributions I suppose, they come broken out of the box !
PeterO
Return to “Arch”
Who is online
