Martin Frezman
Warning in update (Hopefully in the "can be ignored" cat)
Wed Jun 14, 2017 1:46 pm
So, having figured out how to upgrade the system, it generated the following message (the line in question is the one that starts with "WARNING"):
:: Running post-transaction hooks...
( 1/14) Updating linux-raspberrypi initcpios
==> Building image from preset: /etc/mkinitcpio.d/linux-raspberrypi.preset: 'default'
-> -k 4.9.31-2-ARCH -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 4.9.31-2-ARCH
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
-> Running build hook: [filesystems]
-> Running build hook: [keyboard]
-> Running build hook: [fsck]
==> WARNING: No modules were added to the image. This is probably not what you want.
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
==> Image generation successful
Is this reason for concern, or is it the usual "Oh, it's Linux, just ignore it" sort of thing?
If this post appears in the wrong forums category, my apologies.
SkyRise
Re: Warning in update (Hopefully in the "can be ignored" cat
Wed Jun 14, 2017 2:19 pm
Never used Arch, but having a quick read of https://wiki.archlinux.org/index.php/Mkinitcpio it looks like it's used to create an initial ramdisk environment before going into the full 'init'.
So as long as it can mount your root filesystem, I think you should be OK (I don't know if it specifically requires a module for whatever filesystem your root is on though)
cjan
Thu Jun 15, 2017 1:16 am
i vote "Oh, it's Linux, just ignore it" .
Martin Frezman
Thu Jun 15, 2017 6:10 am
cjan wrote:i vote "Oh, it's Linux, just ignore it" .
Heh heh. Yeah, that's kinda what I thought...
Return to “Arch”
Who is online
Users browsing this forum: No registered users and 2 guests
