Guy999
Most Stable Usable Puppy for Pi?
Tue May 14, 2013 8:43 pm
Hi
I am a long time puppy user just waiting for my 1st ever Pi to turn up in the mail :D
I see there is more than 1 version available. I would like to hear from those who have used them which currently gives the best experience.
thanks
Guy
dancytron
Re: Most Stable Usable Puppy for Pi?
Fri May 17, 2013 8:37 pm
The easiest way to get Puppy on a R. Pi is to use Berryboot. It also installs other os's in a multiboot setup.
Otherwise, you need to update the kernel manually somehow. That information is on the puppy forum.
http://www.berryterminal.com/doku.php/berryboot
Guy999
Sat May 18, 2013 9:54 pm
Thanks for the reply. Is there a way to use Berryboot to install an image like unetbootin does?
I dislike the way Berryboot appears to install directly, it means another download every time you re-install & I am on limited bandwidth. Also, when you use wget or a torrent to download it supports resume if there is a problem with the download.
dancytron
Mon May 20, 2013 2:54 am
you don't have to redownload to start over. In fact, it can make multiple OS copies from the one file that it downloads.
Return to “Puppy”
