DavidS
Re: Squeezed Arm Puppy alpha4
Sun Sep 29, 2013 3:03 am
Never mind:
I will not be using Linux at all on the RPi for now.
I attempted to assemble a test program that I had ported over from RISC OS for testing, and lo and behold it bouught down the system with a Panic. Do not worrie, afterwords I attempted the same on Raspbian and got the same resaults :).
If I can crash the OS by running gas I do not want it.
I still hope that some one picks up Puppy Linux.
26-Bit R15 to 32-bit. 16-bit addressing to 24-bit. ARM and 65xx two CPU's that continue on, and are better than ever. Assembly Language forever :) .
bostonpatriot
Thu Jun 11, 2015 12:04 am
Hello and thanks for the "patch" to fix the non-booting Squeezed Arm Puppy problem. I swapped out the obsolete bootcode.bin file (Windows 7, Pi B - 512 Mb), inserted the SD card and it "Arm" booted perfectly.
Thanks again
Return to “Puppy”
Who is online
