The config.txt in Puppy alpha3:ChadP wrote:I finally have the puppy working on my RP. Does anyone know how to fit it to the screen? Im using hdmi but it over runs the screen a little on all four sides if someone could help me out it would be greatly appreciated. Thanks!!!
# refer: http://elinux.org/RPi_config.txt also: http://www.jtek.cz/?p=62
# Use HDMI mode even if no HDMI monitor is detected
# (i have this problem if any usb device plugged in at startup)
hdmi_force_hotplug=1
# this might force audio out on hdmi...
#hdmi_drive=2
# Force hdmi to CEA mode...
#hdmi_group=1
# CEA 720p 60Hz...
#hdmi_mode=4
# CEA 720p 50Hz... (this works on my tv, 60Hz does not)
#hdmi_mode=19
# The RP firmware in partition 1 currently is set to very high overscan, giving huge black borders on the screen.
# set this to disable overscan, so video will fill the screen...
disable_overscan=1
# leaving disable_overscan=1 enabled, to cancel the system default overscan (do not comment it out),
# you can reintroduce some small some overscan, if video is spilling off edges of screen...
#overscan_left=4
#overscan_right=4
#overscan_top=4
#overscan_bottom=4
disable_overscan=1
overscan_left=4
overscan_right=4
overscan_top=4
overscan_bottom=4
No, its Puppy. Navigate to it in the file manager and click on it and it will open in the right application. (Assuming it is like every other Puppy, I don't have a Raspberry Pi).ChadP wrote:I know this is a dumb question but where do I edit text do I do it in the console? I love the puppy the best of all the os. Great job!
I don't think that your first statement will mean a lot to many users who (like me - until yesterday!) assumed that Puppy was 'just another Unix distro' with a terminal which would accept commands like 'apt-get upate' to name but one!dancytron wrote: No, its Puppy. Navigate to it in the file manager and click on it and it will open in the right application. (Assuming it is like every other Puppy, I don't have a Raspberry Pi).
No, use a '#' like all the comment lines in BarryK's reply above.ChadP wrote:Do you comment something out like c code //.
