That actually sounds swell.DougieLawson wrote:Do you need Pidora any more? Fedora has native ARMv7 support.
http://fedoraproject.org/wiki/Changes/ARM_as_Primary
Neither. It's the ARM distro you want. i386 and x64 aren't compatible with the processor on the Pi (any of 'em including Pi 2)andtaeus wrote:That actually sounds swell.DougieLawson wrote:Do you need Pidora any more? Fedora has native ARMv7 support.
But which architecture? i386 or x64?
Thank you! Actually, thinking about it, it was a stupid question. The installation process just looks... overwhelming.grynnan wrote:Neither. It's the ARM distro you want. i386 and x64 aren't compatible with the processor on the Pi (any of 'em including Pi 2)andtaeus wrote:That actually sounds swell.DougieLawson wrote:Do you need Pidora any more? Fedora has native ARMv7 support.
Which installation process are we meant to use?The installation process just looks... overwhelming.
Well, I am having the same issue as you. I'm not really sure how to install that raw file on the SD card. I thought about just extracting the file on the SD, but then technically it isn't installed.dfunk wrote:Which installation process are we meant to use?The installation process just looks... overwhelming.
Would it be creating your own Fedora remix?
I tried the 'fedora-arm-installer' with the image 'Fedora-Minimal-armhfp-21-5-sda.raw' but this didn't get me anything except a black screen when attempting to boot.
I asked Edward if he can post a torrent image for an SD card for those newbies who won't be able to do what Edward did without a Linux system to extract the files from http://mirror.pnl.gov/fedora/linux/rele ... sda.raw.xz that go into the ext4 partition, and to understand how to copy the Pi boot partition files from https://github.com/raspberrypi/firmware. If he doesn't, it would be nice if someone else could - I'm busy traveling and won't have a Linux system handy to do it for a couple of weeks.dfunk wrote:Edward Mann has it working!
Read his comment here: http://rglinuxtech.com/?p=1286#comment-7161
Then why do you post this in an existing topic with 'Pidora' in the title?The Forum moderators should provide a Fedora Section.
+1jamesh wrote:I think we will just rename this forum to Pidora/Fedora, there simply not enough demand for two forums.
Hi vk4tx,
If you cant understand that, sorry I cant help you.DirkS wrote:Then why do you post this in an existing topic with 'Pidora' in the title?The Forum moderators should provide a Fedora Section.
Wouldn't it be better if you had at least started a new topic?
If you think that then I can only assume that you did not get my point.vk4tux wrote:If you cant understand that, sorry I cant help you.DirkS wrote:Then why do you post this in an existing topic with 'Pidora' in the title?The Forum moderators should provide a Fedora Section.
My RPI2 with Fedora 21 is an incredible workhorse and very stable see it here ;DomL wrote:Hi vk4tx,
Is your version with "KDE" really stable ?
I tried several times to set up a version of Debian (the latest one uploaded) with KDE, but I am really frustrated with the results : it is very unstable : kdm doesn't seem to work well, and the system hangs very regularly...
May I ask why you choose to build that image with Fedora ? What advantages does Fedora offer compared to Debian, for example ? I must admit that I do not know Fedora at all...
Kind regards,
DL
I tell you something, dont mess with rubbish SD cards, Use only genuine sandisk ultra (48mb/s) 8 to 16GB for excellent long lasting performance.Ongelma wrote:one more reflash and now i get it to boot to desktop.... BUT. theres some icons showing up in the bottom of the desktop and after they all show up, the desktop disappears and it gets a shutdown command and shuts down... rinse and repeat.
Any help?.
