External USB Drives with Pidora?
Posted: Thu Jan 01, 2015 7:07 am
by coralnut
Does Pidora support the Raspbian commands "safe_mode_gpio=4" and "max_usb_current=1"?
I have used those commands previously with Raspbian, and I'd like to know if they (or something equivalent) can be used with Pidora, and if so, how to issue the commands.
Thanks.
Re: External USB Drives with Pidora?
Posted: Thu Jan 01, 2015 10:23 am
by DougieLawson
Those things in /boot/config.txt are parameters for the GPU startup code, so it doesn't matter what operating system is running.
Posted: Fri Jan 02, 2015 12:09 am
by coralnut
Thank you, that fixes my problem. :D
