IhazPi
STICKY: Super Simple Pidora Quick Start Guide
Tue Aug 19, 2014 5:07 am
After a couple days and lots of research trying to get my setup just right, I realized it only took a few steps. I used my own SD card, loaded Pidora on it from my Mac, and got the wireless USB dongle up and running. Getting the wifi working was not easy. I tried a number of approaches and finally found the right commands.
These commands are taken from various other "quick start guides" but simplified here. This assumes you are somewhat familiar with a command line and that you are using Mac OS to set up the SD card:
On your Mac:
1. Insert the SD card and get the device of your SD card
diskutil list
2. Unmount the disk with the device listed above
diskutil unmountDisk /dev/disk<n>
3. Write the disk image to the SD card
sudo dd bs=1m if=Pidora-2014-R2-1.img of=/dev/disk2
On your Pi:
1. Insert the card in the Raspberry Pi and start it up.
2. Fire up your wireless network
nmcli dev wifi con "myssid" password "myssidpassword"
3. Celebrate!
I also recommend installing net-tools (provides ifconfig) and updating the system (as root):
yum install net-tools
yum update
Hopefully this will save someone some googling! Happy hacking!
kayvan
Re: Super Simple Pidora Quick Start Guide
Wed Dec 31, 2014 6:36 pm
Thanks for the post.
ifconfig *is* available in Pidora without installing net-tools, it's just named "pifconfig"
At first I though it was named like that as some sort of nod to the "pi" (Pidora, pifconfig, etc.) but it's actually part of the python-ethtool pacakge:
[[email protected] boot]# rpm -qf /usr/sbin/pifconfig
python-ethtool-0.10-1.fc20.armv6hl
Best regards,
---Kayvan
Return to “Pidora / Fedora”
Who is online
Users browsing this forum: No registered users and 3 guests
