berry boot?
Posted: Fri Jul 04, 2014 11:45 pm
by ric96
How do I put pidora on berryboot??
Re: berry boot?
Posted: Sat Jul 05, 2014 9:26 am
by fruitoftheloom
Re: berry boot?
Posted: Sat Jul 05, 2014 9:33 am
by ric96
I did RTFM ...That doesn't work it ends in a terminal error
error: having a symlink for /lib and/or /sbin inside your image is not allowed!
This conflicts with the shared AUFS folders
switch root: can't execute '/sbin/init': no such file or directory
Re: berry boot?
Posted: Thu Nov 12, 2015 9:41 am
by masterkiwi
Hi guys,
I just got a PI2 hifiberry and trying to set up piMusicBox next to OpenELEC in berryboot.
OpenELEC installed through the normal way in Berryboot.
I tried to RTFM the PiMusicBox image and get the exact same error as Ric96.
Mounting image pimusicbox.img240...
Mounting RW data directory on top
Setting CPU governor to ondemand
Starting operating system pimusicbox.img240...
switch_root: can't execute 'sbin/init' : No such file or directory
[ 130.625902] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000100
Could anyone help?
Re: berry boot?
Posted: Thu Nov 12, 2015 9:53 am
by fruitoftheloom
masterkiwi wrote:Hi guys,
Could anyone help?
Well ric96 is after 18 months still around so maybe he will respond with his solution, though bear in mind he was using a RPi1 Model B :D
Re: berry boot?
Posted: Thu Nov 12, 2015 10:19 am
by ric96
Could anyone help?
If it gives that error, then it simply won't run, just normally flash it on a separate sdcard.
