Damn i had like´d the upcoming FC on PI .. but at the current state , its useless.
[root@smb ~]# yum update
Loaded plugins: langpacks, presto, refresh-packagekit
pidora | 3.9 kB 00:00:00
pidora-rpfr-updates | 3.8 kB 00:00:00
http://mirror.raspberrypi.org/pidora/up ... repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 403 Forbidden"
Resolving Dependencies
--> Running transaction check
---> Package lightdm.armv6hl 0:1.4.0-2.fc18 will be updated
---> Package lightdm.armv6hl 0:1.4.1-3.fc18.1307170533kf will be an update
--> Processing Dependency: lightdm-greeter = 1.2 for package: lightdm-1.4.1-3.fc18.1307170533kf.armv6hl
--> Processing Dependency: lightdm-gobject(armv6hl-32) = 1.4.1-3.fc18.1307170533kf for package: lightdm-1.4.1-3.fc18.1307170533kf.armv6hl
---> Package mdadm.armv6hl 0:3.2.6-1.fc18 will be updated
---> Package mdadm.armv6hl 0:3.2.6-21.fc18 will be an update
---> Package raspberrypi-kernel.armv6hl 0:3.12.0-3.20131106git839f349.rpfr18 will be obsoleted
---> Package raspberrypi-kernel.armv6hl 0:3.12.0-5.20131106git839f349.rpfr18 will be obsoleting
---> Package raspberrypi-kernel-headers.armv6hl 0:3.12.0-3.20131106git839f349.rpfr18 will be updated
---> Package raspberrypi-kernel-headers.armv6hl 0:3.12.0-5.20131106git839f349.rpfr18 will be an update
---> Package lightdm-gobject.armv6hl 0:1.4.1-3.fc18.1307170533kf will be installed
---> Package lightdm-gtk.armv6hl 0:1.3.1-4.fc18 will be installed
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
raspberrypi-kernel armv6hl 3.12.0-5.20131106git839f349.rpfr18 pidora-rpfr-updates 11 M
replacing raspberrypi-kernel.armv6hl 3.12.0-3.20131106git839f349.rpfr18
Updating:
lightdm armv6hl 1.4.1-3.fc18.1307170533kf pidora-updates 125 k
mdadm armv6hl 3.2.6-21.fc18 pidora-updates 308 k
raspberrypi-kernel-headers armv6hl 3.12.0-5.20131106git839f349.rpfr18 pidora-rpfr-updates 827 k
Installing for dependencies:
lightdm-gobject armv6hl 1.4.1-3.fc18.1307170533kf pidora-updates 27 k
lightdm-gtk armv6hl 1.3.1-4.fc18 pidora-updates 65 k
Transaction Summary
Install 1 Package (+2 Dependent packages)
Upgrade 3 Packages
Total size: 13 M
Total download size: 525 k
Is this ok [y/N]: y
Downloading Packages:
Setting up and reading Presto delta metadata
lightdm-1.4.1-3.fc18.130717053 FAILED
http://mirror.raspberrypi.org/pidora/up ... rmv6hl.rpm: [Errno 14] curl#22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
lightdm-gobject-1.4.1-3.fc18.1 FAILED
lightdm-gtk-1.3.1-4.fc18.armv6 FAILED
(1/4): lightdm-1.4.1-3.fc18.1307170533kf.armv6hl.rpm | 125 kB 00:00:03
(2/4): lightdm-gobject-1.4.1-3.fc18.1307170533kf.armv6hl.rpm | 27 kB 00:00:00
(3/4): mdadm-3.2.6-21.fc18.armv6hl.rpm | 308 kB 00:00:04
(4/4): lightdm-gtk-1.3.1-4.fc18.armv6hl.rpm | 65 kB 00:00:00
Total 67 kB/s | 525 kB 00:07
Running Transaction Check
ERROR with transaction check vs depsolve:
raspberrypi-kernel < 3.12.0-5.20131106git839f349.rpfr18 is obsoleted by raspberrypi-kernel-3.12.0-5.20131106git839f349.rpfr18.armv6hl
Please report this error in https://bugzilla.redhat.com/enter_bug.c ... ponent=yum
Any know what happend here with the FC remix / pidora Project ?
best regards
- Contact: Website Yahoo Messenger
Re: Pidora Mirror issue ?!?
Have you tried checking to see if SELinux was enabled. This somehow worked when i changed the policy status from disabled to enforcing. then I ran yum update and it downloaded the .armv6hl packages. If you need detailed instructions check the "Pidora repo" thread.
selinux disabled .. same issue.kernel_cougar wrote:Have you tried checking to see if SELinux was enabled. This somehow worked when i changed the policy status from disabled to enforcing. then I ran yum update and it downloaded the .armv6hl packages. If you need detailed instructions check the "Pidora repo" thread.
major issue are on the RPI mirror director , the page are DENIED either access with my Windows7 browsers.
.... i am Going to WIPE out FC now.. replacing it with OpenSuse 13.1 image http://www.zq1.de/bernhard/linux/opensuse/
