I have no way to connect the monitor to my raspberry
Posted: Wed Dec 26, 2012 10:45 pm
by agrynchuk
I have no way to connect the monitor to my raspberry and I want to use as a server without a graphical environment. Tell me how to set up auto-ssh. How to configure a static ip I found http://danielgibbs.co.uk/2012/06/fedora ... p-address/.
Re: I have no way to connect the monitor to my raspberry
Posted: Wed Dec 26, 2012 11:12 pm
by madman_xxx
Let me get this straight: You have a Raspberry Pi, an SD card with Raspbian preloaded, all seems to be running, but headless (without monitor).
  • you want to log on it over the network?
  • you already did that and now want to set a static IP for it?
Which is it?
Posted: Thu Dec 27, 2012 12:00 am
by Vindicator
It helps to let us know the distribution you intend to use as your link is for fedora, You can use a TV with composite source to attach your Raspi if need be to set it up.
I used this site to setup Raspbian static ip
http://www.penguintutor.com/blog/viewblog.php?blog=6306
As far as SSH I believe that SSH is setup already enabled on the latest distributions of Raspbian so all you should need is the current IP of your device to use it. and you should be able to attain that by looking in your routing table in your router.
