agreene
RaspberryPi Fedora Remix 18 Alpha
Tue Dec 04, 2012 9:55 pm
The new alpha image for the raspberrypi is out. I encourage you to test it out and report any bugs that you notice. Also the default run level is 3 so it boots into text mode, if you would like to test out the GUI "Graphical User Interface" you will need to run the following command from the CLI "Command Line Interface".
Because this is just an alpha release and we are still working on firstboot you will need to login as "root", the default password is "raspberrypi".
Login: root
Password: raspberrypi
start GUI cmd:
startxfce4
rpfr-f18-alpha-v5 image:
http://scotland.proximity.on.ca/arm-nig ... -alpha.zip
Please file tickets here:
http://trac.proximity.on.ca/projects/rpfr/wiki
Bad Wolf
Re: RaspberryPi Fedora Remix 18 Alpha
Wed Dec 05, 2012 12:17 am
Andrew,
Chris Tyler is right, you truly are the “Repro Guru” Two releases in two days
Well done hats off to you (It would have to be a Fedora!) :lol:
Christmas has come early this year for us!
Now if only I could decide which of the two to take for a test-drive first!
To a person with a hammer, everything looks like a nail.
amitsaha
Sat Jan 12, 2013 7:03 pm
I installed the Fedora 18 beta-2 images today. And all looks great so far. My notes soon. Thanks!
Deteros
Sun Jan 13, 2013 5:49 pm
I have just copied the image from rpfr-f18-beta-2.zip,
which I downloaded from
http://scotland.proximity.on.ca/arm-nig ... -rpi-remix
onto my sd card, but the pi does not boot.
I verified, that the rpfr-17-xfce-r2.zip boots fine with the sd card,
which is a 32 GB SanDisk Ultra.
Any ideas? When is the final release to be expected?
amitsaha
Sun Jan 13, 2013 9:39 pm
Deteros wrote:Hi,
Strange, I am using the same image. Did you try both HDMI and composite video? In my case, it worked the first time with HDMI, but then afterwards only composite seemed to be working.
Can you share your /boot/config.txt?
Thanks.
Deteros
Mon Jan 14, 2013 10:15 pm
I did not change anything, thus it is the one on the image.
The Monitor is connected via HDMI - it should boot!
#Title: HDMI default, NTSC (North American) fallback
#Desc: Output to North American composite video (NTSC) if HDMI is not connected at boot.
sdtv_mode=0
sdtv_aspect=1
overscan_left=15
overscan_right=15
overscan_top=15
overscan_bottom=15
hdmi_drive=2
amitsaha
Tue Jan 15, 2013 4:37 am
Deteros wrote:> Can you share your /boot/config.txt?
sdtv_mode=0
sdtv_aspect=1
overscan_left=15
overscan_right=15
overscan_top=15
overscan_bottom=15
hdmi_drive=2
Strange. I may sound stupid, but I hope you extracted the .zip file and wrote the .img file to the disk? Believe it or not, I was wrongly writing the .zip file without extracting it, and couldn't think why it wasn't booting. :(.
Also, did you try the composite video output?
Deteros
Tue Jan 15, 2013 5:21 pm
Hi amitsaha,
Yes, I did.
I don't have a tv, and do not plan to buy one.
Thanks for asking.
I assumed it could be the 32 Gbyte SD-card - therefore I tried another one
with 4 GByte - and this one booted without any problems :-)
So problem is solved, thank you very much.
watje999
Tue Jan 29, 2013 7:45 pm
Hi there, thanks for the fedora 18 Beta. I can't do a yum install httpd.
Installing:
httpd armv5tel 2.4.3-12.fc18 fedora 1.0 M
Installing for dependencies:
fedora-logos noarch 17.0.3-1.fc18 fedora 4.7 M
httpd-tools armv5tel 2.4.3-12.fc18 fedora 82 k
mailcap noarch 2.1.40-1.fc18 fedora 30 k
Transaction Summary
Install 1 Package (+3 Dependent packages)
Total size: 5.9 M
Installed size: 8.0 M
Is this ok [y/N]: y
Downloading Packages:
Running Transaction Check
Running Transaction Test
Transaction Check Error:
file /etc/favicon.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/anaconda/pixmaps/splash.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/anaconda/pixmaps/anaconda_header.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/anaconda/pixmaps/progress_first.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/16x16/apps/gnome-main-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/22x22/apps/gnome-main-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/24x24/apps/gnome-main-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/256x256/apps/gnome-main-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/32x32/apps/gnome-main-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/36x36/apps/gnome-main-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/48x48/apps/gnome-main-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/96x96/apps/gnome-main-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch
file /usr/share/icons/Bluecurve/16x16/apps/icon-panel-menu.png from install of fedora-logos-17.0.3-1.fc18.noarch conflicts with file from package raspberrypi-fedora-remix-logos-1-1.rpfr18.noarch >>>>> many more lines to come...
How can I resolve this conflict?
amitsaha
Tue Jan 29, 2013 11:16 pm
watje999 wrote:Hi there, thanks for the fedora 18 Beta. I can't do a yum install httpd.
Installing:
Transaction Summary
Total size: 5.9 M
Is this ok [y/N]: y
Can you try cleaning the meta data and try to install again? To clean:
# yum clean
# yum -y install httpd
Does that help?
watje999
Wed Jan 30, 2013 5:08 pm
thanks, same problem after yum clean all.
agreene
Wed Jan 30, 2013 7:15 pm
Thanks for bringing up this issue I am currently looking into it
watje999
Wed Jan 30, 2013 8:05 pm
agreene wrote:Thanks for bringing up this issue I am currently looking into it
This maybe helps: I did
#yum remove raspberrypi-fedora-remix-logos
#yum install httpd
#yum install raspberrypi-fedora-remix-logos
after this httpd worked after configuring /etc/httpd/conf/httpd.conf
[[email protected] conf]# systemctl start httpd.service
[[email protected] conf]# systemctl status httpd.service
httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; disabled)
Active: active (running) since Wed 2013-01-30 20:52:25 CET; 7s ago
Main PID: 1857 (httpd)
Status: "Processing requests..."
CGroup: name=systemd:/system/httpd.service
├─1857 /usr/sbin/httpd -DFOREGROUND
├─1858 /usr/sbin/httpd -DFOREGROUND
├─1859 /usr/sbin/httpd -DFOREGROUND
├─1860 /usr/sbin/httpd -DFOREGROUND
├─1861 /usr/sbin/httpd -DFOREGROUND
└─1862 /usr/sbin/httpd -DFOREGROUND
Jan 30 20:52:25 raspi01.fritz.box systemd[1]: Started The Apache HTTP Server.
Used this as a work around.
ScottKnight
Wed Jan 30, 2013 8:12 pm
Ah, I discovered this a few days ago and have been trying to find time to figure out who and how to properly submit a fix. This is because whoever created the raspberrypi-remix-logos package didn't include fedora-logos in the provides.
After downloading the srcrpm and modifying it to include fedora-logos and installing, another dependency issue cropped up. Something else (can't remember what) required system-logos to be provided at greater than 7.something.
Here is a simple diff that brings corrects the problems and brings the logos into line with the current fedora-logos that it is trying to replace (of course, I had to rename the source directory and create a new tarball before rebuilding):
[[email protected] SPECS]# diff raspberrypi-remix-logos.spec raspberrypi-remix-logos.original.spec
3c3
< Version: 17.0.3
> Version: 1
7c7
< Source0: raspberrypi-fedora-remix-logos-17.0.3.tar.gz
> Source0: raspberrypi-fedora-remix-logos-1.tar.gz
17d16
< Provides: fedora-logos = %{version}-%{release}
agreene
Thu Jan 31, 2013 4:05 pm
ScottKnight wrote:Ah, I discovered this a few days ago and have been trying to find time to figure out who and how to properly submit a fix. This is because whoever created the raspberrypi-remix-logos package didn't include fedora-logos in the provides.
3c3
< Version: 17.0.3
> Version: 1
7c7
17d16
I realized this yesterday I forgot to add an obsoletes line to the package but the issue has been resolved as of yesterday.
If you do a yum clean all then a yum update you will install the new updated package.
Once again thanks for bringing this up. If you guys notice any other weird issue please contact me with details about the issue and I will do my best to fix them.
[email protected]
ScottKnight
Thu Jan 31, 2013 6:04 pm
Andrew,
agreene wrote: I realized this yesterday I forgot to add an obsoletes line to the package but the issue has been resolved as of yesterday.
Nice job on a quick and effective turnaround on this. I just did a yum downgrade to replace my (higher versioned) quickndirty rpm with your version 1-3, and it appears to work as intended.
Thanks, Scott
watje999
Thu Jan 31, 2013 9:11 pm
[email protected]
Thanks Andrew, I did a yum clean all, and yum update, and got the new version correctly.
Another good step forward, in a very short time!
watje999
Sun Feb 03, 2013 1:42 pm
fedora18 hangs using rsync or tar on raspberry-pi version2.
Having a usb-disk with rootfs on it, booting from sd-card.
rsync version 3.0.9 is last version.
syncing via network or using tar on usb hard-disk hangs my raspberry-pi version 2 completely.
Have to power-down and up to get it running again. No info in /var/log/messages.
A domotiga system runs for weeks without problem. (with active mysql database, httpd server running with php support.)
Is there a firmware update, newer kernel or adjustment nescessary?
[[email protected] boot]# ls -la
total 9444
drwxr-xr-x 4 root root 16384 Jan 1 1970 .
drwxr-xr-x 19 root root 4096 Feb 3 12:21 ..
-rwxr-xr-x 1 root root 17764 Nov 23 12:50 bootcode.bin
-rwxr-xr-x 1 root root 129 Jan 28 20:32 cmdline.txt
-rwxr-xr-x 1 root root 84926 Nov 19 17:22 config-3.2.27-1.20120926git9245b4c.rpfr18
-rwxr-xr-x 1 root root 495 Jan 28 14:56 config.txt
-rwxr-xr-x 1 root root 465 Nov 19 12:09 config.txt.hdmi_nooverscan
-rwxr-xr-x 1 root root 540 Nov 19 12:09 config.txt.hdmi_overscan
-rwxr-xr-x 1 root root 524 Nov 19 12:09 config.txt.ntsc_japan
-rwxr-xr-x 1 root root 541 Nov 19 12:09 config.txt.ntsc_northamerica
-rwxr-xr-x 1 root root 495 Nov 19 12:09 config.txt.pal
-rwxr-xr-x 1 root root 498 Nov 19 12:09 config.txt.pal_brazil
-rwxr-xr-x 1 root root 5284 Nov 23 12:50 fixup.dat
drwxr-xr-x 2 root root 2048 Jan 31 18:40 grub
drwxr-xr-x 3 root root 2048 Jan 30 20:41 grub2
-rwxr-xr-x 1 root root 7159860 Nov 19 17:21 kernel.img
-rwxr-xr-x 1 root root 2353656 Nov 23 12:50 start.elf
-rwxr-xr-x 1 root root 407 Nov 19 12:09 start.elf.desc
[[email protected] boot]# cat cmdline.txt
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/sda1 ro rootfstype=ext4 rootwait quiet
[[email protected] boot]# cat config.txt
# Raspberry Pi configuration file
# Composite video mode: PAL 50 Hz (non-Brazilian version)
# Composite aspect ratio: 4:3
# Overscan: Enabled, 15 pixels
# HDMI resolution: From EDID
# HDMI sound: Enabled
#Title: HDMI default, PAL (European) fallback
#Desc: Output to European composite video (PAL) if HDMI is not connected at boot.
sdtv_mode=2
sdtv_aspect=1
overscan_left=15
overscan_right=15
overscan_top=15
overscan_bottom=15
hdmi_drive=2
agreene
Mon Feb 04, 2013 10:45 pm
watje999 wrote:fedora18 hangs using rsync or tar on raspberry-pi version2.
total 9444
sdtv_mode=2
sdtv_aspect=1
overscan_left=15
overscan_right=15
overscan_top=15
overscan_bottom=15
hdmi_drive=2
I am currently working on updating the kernel package for the final release , however im not sure at the moment if this will have any affect your current issue. But I will look into it for you and see what I can do.
remsnet
Contact: Website Yahoo Messenger
Mon Feb 04, 2013 10:52 pm
Agreene ,
I wrote you allready an private message how to gain an 3.7.6 Rasp kernel onto the PI.
It contains an lot of featgers, include support for stable turbo 64GB cards.
#!/bin/sh
mkdir -p /usr/src/PRI/linux-RPi
cd /usr/src/PRI/
git clone https://github.com/Olipro/linux-RPi
wget  ftp.kernel.org/pub/linux/kernel/v3.0/incr/patch-3.7.1-2.bz2
wget  ftp.kernel.org/pub/linux/kernel/v3.0/incr/patch-3.7.2-3.bz2
wget  ftp.kernel.org/pub/linux/kernel/v3.0/incr/patch-3.7.3-4.bz2
wget  ftp.kernel.org/pub/linux/kernel/v3.0/incr/patch-3.7.4-5.bz2
wget  ftp.kernel.org/pub/linux/kernel/v3.0/incr/patch-3.7.5-6.bz2
wget http://pastebin.com/ZFKG5Mm6  config-371-saved
tar cpfj linux-RPi-3.7.1.tar.bz2  linux-RPi
cd /usr/src/PRI/linux-RPi
patch -p1 < ../patch-3.7.1-2
patch -p1 < ../patch-3.7.2-3
patch -p1 < ../patch-3.7.3-4
patch -p1 < ../patch-3.7.4-5
cd /usr/src/PRI
ln -s linux-RPi a
ln -s linux-RPi b
patch -p0 < patch-3.7.5-6
tar cpfj linux-RPi-3.7.6.tar.bz2 linux-RPi
cp config-371-saved linux-RPi/.config
cd linux-RPi
#make
#make vmlinux
#make modules
#make modules-install
remsnet
Mon Feb 04, 2013 11:10 pm
amitsaha wrote:Hello,
Deteros wrote:Hi,
Thanks.
Most Current 3.1 and 3.2 kernels from images like rpfr-f18-beta-2 miss this settings and patches for that.
CONFIG_MMC_SDHCI_BCM2708=y
CONFIG_MMC_SDHCI_BCM2708_DMA=y
This are nessary for Cards +32GB.
watje999
Tue Feb 05, 2013 7:03 pm
Hi Remsnet, was trying your suggestion about an new kernel build, but following line gives errors:
command wrongly interpreted?
output:
[[email protected] PRI]# wget http://pastebin.com/ZFKG5Mm6 config-371-saved
--2013-02-05 19:49:49-- http://pastebin.com/ZFKG5Mm6
Resolving pastebin.com (pastebin.com)... 66.252.2.46
Connecting to pastebin.com (pastebin.com)|66.252.2.46|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: ‘ZFKG5Mm6’
[ <=> ] 212,827 191KB/s in 1.1s
2013-02-05 19:49:50 (191 KB/s) - ‘ZFKG5Mm6’ saved [212827]
--2013-02-05 19:49:50-- http://config-371-saved/
Resolving config-371-saved (config-371-saved)... failed: Name or service not known.
wget: unable to resolve host address ‘config-371-saved’
FINISHED --2013-02-05 19:49:51--
can I rename ZFKG5Mm6 manually to config-371-saved and continue the process?
remsnet
Tue Feb 05, 2013 10:01 pm
watje999 wrote:Hi Remsnet, was trying your suggestion about an new kernel build, but following line gives errors:
output:
Well ,
For that fauxpass :)
but Sorry ! - RTFMLC - Read The ******* Manuals Linux Contains ! -
I am assume that new Linux users may not use this script 1:1 ,
but the bits with the information it contains. :)
Open the URL http://pastebin.com/ZFKG5Mm6 manualy in an browser instead of wget...
That show you its contents ;-) - it contains an Moded & tested 3.7.5 .config for an RPI.
If you RUN debian / FC you can use instead of the wget also :
zcat /proc/config.gz >config-371-saved
witch contains your current kernel Config.
kind regards
Return to “Pidora / Fedora”
