eb2
Unable to install 'yum-utils' on CentOS 7.5 due to libxml2 version mismatch
Sun Sep 09, 2018 8:14 pm
I'm not sure how to resolve, but every time I try to install 'yum-utils' on my CentOS Pi, I get the following error message:
[[email protected] yum.repos.d]# yum install yum-utils
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction, or "yum-complete-transaction --cleanup-only" and "yum history redo last", first to finish them. If those don't work you'll have to try removing/installing packages by hand (maybe package-cleanup can help).
The program yum-complete-transaction is found in the yum-utils package.
--> Running transaction check
---> Package yum-utils.noarch 0:1.1.31-46.el7_5 will be installed
--> Processing Dependency: python-kitchen for package: yum-utils-1.1.31-46.el7_5.noarch
--> Processing Dependency: libxml2-python for package: yum-utils-1.1.31-46.el7_5.noarch
---> Package libxml2-python.armv7hl 0:2.9.1-6.el7_2.3 will be installed
--> Processing Dependency: libxml2 = 2.9.1-6.el7_2.3 for package: libxml2-python-2.9.1-6.el7_2.3.armv7hl
---> Package python-kitchen.noarch 0:1.1.1-5.el7 will be installed
--> Processing Dependency: python-chardet for package: python-kitchen-1.1.1-5.el7.noarch
---> Package python-chardet.noarch 0:2.2.1-1.el7_1 will be installed
--> Finished Dependency Resolution
Error: Package: libxml2-python-2.9.1-6.el7_2.3.armv7hl (base)
           Requires: libxml2 = 2.9.1-6.el7_2.3
           Installed: libxml2-2.9.1-6.el7.3.armv7hl (@centos-base_rbf)
               libxml2 = 2.9.1-6.el7.3
           Available: libxml2-2.9.1-6.el7_2.3.armv7hl (base)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
Return to “Pidora / Fedora”
