Bad Wolf
Raspberry Pi Fedora Remix 17 Final Release Image
Sat Nov 03, 2012 9:55 pm
Announcement from Andy Greene @ Seneca
Greetings to all
We proud to finally announce our much anticipated release of the Raspberry Pi Fedora Remix 17. After weeks of hard work.
The final release image can be found here:
Raspberry Pi Fedora Remix 17<http://scotland.proximity.on.ca/raspber ... 5/latest/>
The new repositories are located here:
RPFR-17 Repo<http://scotland.proximity.on.ca/raspber ... os/f17-v5/>
Also if you have any issue or suggestions for this release you can file a bug on the FedoraHosted ARM Trac system at:
ARM Trac system<https://fedorahosted.org/arm/>
I would like to take this opportunity to say thank you to everyone who helped contribute to this release in one way or another. Also for waiting so patiently
To a person with a hammer, everything looks like a nail.
bud-pnq
Re: Raspberry Pi Fedora Remix 17 Final Release Image
Sun Nov 04, 2012 3:33 am
Finally finished fedora remix! Hooray!! Let's hope we don't have big bugs in it :)
billb
Sun Nov 04, 2012 3:49 am
Download link fix (the > was included in original):
http://scotland.proximity.on.ca/raspber ... v5/latest/
smuggly
Wed Nov 07, 2012 12:59 am
Gonna Check It Out! Thanks To All
WeeN
Sat Nov 10, 2012 4:15 pm
When will there be an option to enable the full 512 MB RAM with the Fedora spin or is this already possible? I know that there is a fix for that for the raspbian distro, so it should be possible with Fedora too, shouldn't it? At the moment you can only choose from the usual "256MB total" options.
stagefright1989
Tue Nov 13, 2012 9:57 am
still no support for 512 MB board? did anybody try using start.elf from wheezy ?
WeeN
Wed Nov 14, 2012 9:01 pm
Yeah, tried that a couple of minutes ago. A simple copy and paste of start.elf didn't work. top said that i had roughly 118 MB total. Maybe some of the more advanced users out there can give us a clue how we can resolve this problem?
coblau
Tue Nov 20, 2012 11:48 am
...same problem here, any suggestions so far?
strobert
Sat Dec 01, 2012 6:22 am
As discussed in this thread:
http://www.raspberrypi.org/phpBB3/viewt ... 51&t=22779
sounds like best known work-around is to pull down rpi-update and run it.
Schorschi
Tue Dec 11, 2012 5:53 am
I am trying to get this image to work in Qemu (for Windows) and it boots but then crashes. Fedora seems to drop into that horrible... Control-D continue issue. I know the image is good, I have Fedora (RC1, Updated) running on my Pi, but would love to have the same image running in Qemu so I can play with updates and various application installations in a Qemu based image before I touch the version running on the Pi. Any assistance appreciated.
This boots but then crashes as noted above... I am not sure, but I figure I might need a custom kernel-qemu image?
qemu-system-arm.exe -kernel kernel-qemu -cpu arm1176 -m 256 -M versatilepb -append "root=/dev/sda2" -net none -hda rpfr-17-xfce-r1.img -serial stdio
rvinoth39
Fri Jan 18, 2013 11:21 am
there r two os in this link.. which one should be downloaded.. i'm using pi model b
alittlebitdifferent
Tue Feb 12, 2013 7:10 am
I am confused.
I installed Fedora on my Pi...but needed certain additional things.
I spent a long time locating a repo that would work.
There is a repo link in past posts...but the files seem outdated.
I have this link..
http://armpkgs.fedoraproject.org/packag ... /armv5tel/
which is not a repo, but seems to have more recent versions of ports in it...ie 2013 updates.
Does anyone know if this bunch of RPM's is offered as a repo anywhere?
Xenon
Sat Feb 23, 2013 10:46 pm
Help! Final Release Image Link "404 Not Found" !
Cloudcentric
Sat Feb 23, 2013 11:24 pm
alittlebitdifferent » Pi is ARMv6
Xenon » http://scotland.proximity.on.ca/raspberrypi
I know everything about nothing"
Return to “Pidora / Fedora”
