having problems with SSH under Pignus
Posted: Thu Mar 02, 2017 7:32 pm
by goldencircuit
I'm having an issue with my pi where I can log in via screen and the ttyACM0 to a desired user (root or a username i've set up) but i cannot for some reason log in via SSH. It keeps telling me that the password is incorrect. I've added a file named ssh under /boot but this has not remedied the problem. Has anyone run into this issue and/or know of a fix?
Thanks!
Re: having problems with SSH under Pignus
Posted: Thu Mar 02, 2017 9:19 pm
by DougieLawson
What part of "It's not supported on here" are you struggling with? Go ask on a Pignus forum.
viewtopic.php?f=28&t=176014
Posted: Fri Mar 03, 2017 10:15 am
by fruitoftheloom
goldencircuit wrote:Hello,
Thanks!
Pingus is only compatible with the ARMv6 BCM2835 RPi's, maybe ask the developers ??
https://pignus.computer/index.html
Regards SSH the disabled setting is specifically for Raspbian Jessie with Pixel DE..
Posted: Fri Mar 03, 2017 10:17 am
by fruitoftheloom
DougieLawson wrote:What part of "It's not supported on here" are you struggling with? Go ask on a Pignus forum.
The Mods have moved this to correct forum and removed the duplicate in Raspbian Forum..
