marakalastic
Is Pidora on the Raspberry Pi B+ dead?
Mon Oct 17, 2016 7:02 pm
Hey guys,
I've recently purchased a new batch of Raspberry Pi B+ that my Pidora image will not boot on, the green LED does not flash once on this new batch. A major difference I noticed between the B+'s I had already used vs. the new batch was the change in RAM chip from Micron to Elpida. I've even tried a fresh Pidora image downloaded from their website, the results remain the same.
Has anyone else gotten a workaround for this issue? Or will Pidora no longer work on the Raspberry Pi B+ from here on out?
Re: Is Pidora on the Raspberry Pi B+ dead?
Mon Oct 17, 2016 7:33 pm
marakalastic wrote:Hey guys,
Would appear development stopped 2 years ago, which is a shame, maybe try:
https://pignus.computer/index.html
Retired disgracefully.....
......to an uncomplicated life !
gregeric
Mon Oct 17, 2016 8:40 pm
As a workaround you might try copying new firmware to your /boot partition (make a backup first). Keep your current kernel, but take bootcode.bin, start_elf.bin etc from: https://github.com/RPi-Distro/firmware/tree/debian/boot
marakalastic
Mon Oct 17, 2016 9:42 pm
gregeric wrote:As a workaround you might try copying new firmware to your /boot partition (make a backup first). Keep your current kernel, but take bootcode.bin, start_elf.bin etc from: https://github.com/RPi-Distro/firmware/tree/debian/boot
Just tried keeping the kernel.img's, grub folder, and lost+found folder and replaced bootcode.bin, start_elf, start_x.elf, fixup.dat, etc... to no avail. The card won't be able to be read (green LED stays on) if I make these changes.
Looks like Pignus is the way to go. I'm surprised more people have no reported this issue with the original B+.
marakalastic
Mon Oct 17, 2016 10:04 pm
Just tried Pignus, it ONLY works on the old B+'s I have with the Micron RAM chip and I am able to log in successfully. The Pi B+'s from the new batch I received with the Elpida RAM chip fail to detect an ethernet connection on boot so it hangs mid-boot. Seems this issue is more on the Raspberry Pi Foundation's decision to switch RAM chips.
Gavinmc42
Tue Oct 18, 2016 2:47 am
I just got the Zero version working.
Can login with Windows via USB serial.
Can ping it in Linux Mint.
Have not tried on a B+ as I was looking for a Zero specific OS.
I'm dancing on Rainbows.
Return to “Pidora / Fedora”
