STICKY: Pignus / Fedora / Fedberry & CentOS2018
Sun Jun 12, 2016 11:25 am
Updated October 2019
Fedora 30 for RPi 2B & 3B & 3B+
https://fedoraproject.org/wiki/Architec ... spberry_Pi
Fedberry the Raspberry Pi 2/3 Fedora 'Minimal, XFCE and LXQt' Remixes
http://fedberry.org/
CentOS for RPi 2B / 3B / 3B+
https://wiki.centos.org/SpecialInterest ... rch/armhfp
Last edited by fruitoftheloom on Wed Oct 30, 2019 9:45 am, edited 41 times in total.
Retired disgracefully.....
MrEngman
Re: Fedora and respins Wiki
Sun Jun 12, 2016 4:24 pm
And ??
Tried this twice and it doesn't work for me. Pi 2B starts to boot and both times I end up with
Welcome to emergency mode! After logging in, type "journalctl -xb" to view
system logs, "systemctl reboot" to reboot, "systemctl default" or ^D to
try again to boot into default mode.
Give root password for maintenance
(or press Control-D to continue):
whatever root password is.
Created SD card on a Pi 2B with SD card reader to access card used to generate fedora image.
MrEngman
MrEngman
Sun Jun 12, 2016 4:36 pm
Checked the /var/log/boot.log file on the Fedora image and for whatever reason it shows
^[%G^[%G[^[[32m  OK  ^[[0m] Found device /dev/disk/by-uuid/52d42742-f5a2-4c8c-909b-a30380b101ed.
         Activating swap /dev/disk/by-uuid/52d42742-f5a2-4c8c-909b-a30380b101ed...
[^[[32m  OK  ^[[0m] Found device /dev/disk/by-uuid/C73B-DD59.
         Mounting /boot...
[^[[1;31mFAILED^[[0m] Failed to mount /boot.
See "systemctl status boot.mount" for details.
[^[[1;33mDEPEND^[[0m] Dependency failed for Local File Systems.
[^[[1;33mDEPEND^[[0m] Dependency failed for Mark the need to relabel after reboot.
MrEngman
Sun Jun 12, 2016 5:08 pm
Well then it is time for the Community Developers to undertake a full update and also include RPi 3B :?
linux_author
Sun Jun 12, 2016 5:20 pm
i took a look at the wiki and must say first that it's great that someone took the effort to write up a Fedora spin for ARM...
on the other hand, the install seems needlessly complicated - i think more users would enjoy Fedora if the install were via a crafted image... the install could then be as simple as:
sudo ddrescue --force fedora_arm_version_xxx.img /dev/sda
(assuming /dev/sda holds an unmounted microsdhc in a usb carrier) ... the system could then be expanded after rebooting
just my US$0.03 (adjusted for inflation)
p.s. i use ddrescue quite a bit - very easy to backup a running system:
sudo ddrescue --force /dev/mmcblk0 /dev/sda
(i make sure to back up onto or from same-size, same-manufacturer, same-brand cards - generally Samsung EVO+ 32GB)
willie
on the simple and easy Gulf of Mexico
philipmather
Re: STICKY: Pignus / Fedora / Fedberry / Suse SEPT '17
Mon Dec 25, 2017 5:22 pm
Has anyone been able to make the Fedora 27 aarch64 images work? I get nothing but a blank screen after the boot menu, tried usual stuff like another card, reflash, checked sha256sum etc... no joy.
Turns out... it takes awhile to boot... :lol: came back to find the screen had eventually reappeared and finished booting. Patience is the key, removing the Plymouth packages (that do the pretty booting page) gives you a bit more "feedback" if you're just making minimal headless boxes but it really is just chugging away in there one way or another.
Return to “Pidora / Fedora”
