sunover
install fedora 21 armv7 on rasperry pi 2?
Fri Mar 27, 2015 1:50 pm
how to install fedora Fedora-Xfce-armhfp-21-5-sda.raw.xz on sd card?
i try this but no work:
xzcat Fedora-Minimal-armhfp-21-5-sda.raw.xz |dd of=/dev/mmcblk0 bs=1M
r3d4
Re: install fedora 21 armv7 on rasperry pi 2?
Sat Mar 28, 2015 12:35 am
Do you have gparted ?
(& if you have enough disk space ) you could tri extracting the image , then
 gparted Fedora-Minimal-armhfp-21-5-sda.raw
fdisk would also work but gparted shows the layout of the disk graphicly
so its quick to see whats what .... perhaps? it is only a root file system image so it must be combined with a boot partition ! idk :!:
sunover wrote:i try this but no work:
How exactly did it fail ??!! ...
sunover
Sat Mar 28, 2015 1:32 pm
i have format 32gb sd card....
fdisk -l
Device         Boot Start      End  Sectors  Size Id Type
/dev/mmcblk0p1       2048 61521919 61519872 29,3G 83 Linux
lsblk
mmcblk0         179:0    0  29,3G  0 disk
└─mmcblk0p1     179:1    0  29,3G  0 part /run/media/rubber/7C80-66CA
i use fdisk to see # fdisk /dev/mmcblk0
sunover
Sat Mar 28, 2015 1:35 pm
when use dd i charge in sd fedora...but blank screen when boot...boot partition was created..i think rasp2 not support fedora armhf image.....
Return to “Pidora / Fedora”
