abhishekpreet07
installing htop on centos7
Thu Aug 20, 2020 7:17 am
I tried to install htop on centos7 on rpi 4 but due to insufficient space it didn't installed .....
I got this from yyum install htop
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).
3. Run the command with the repository temporarily disabled
yum --disablerepo=<repoid> ...
4. Disable the repository permanently, so yum won't use it by default. Yum
will then just ignore the repository until you permanently enable it
again or use --enablerepo for temporary usage:
yum-config-manager --disable <repoid>
or
subscription-manager repos --disable=<repoid>
5. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:
yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Insufficient space in download directory /var/cache/yum/armhfp/7/base
* free 0
* needed 100 k
I got this from
[root@localhost ~]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 1.7G 1.6G 0 100% /
devtmpfs 1.9G 0 1.9G 0% /dev
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 17M 1.9G 1% /run
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/mmcblk0p1 286M 52M 235M 19% /boot
tmpfs 383M 0 383M 0% /run/user/0
need support.......
jahboater
Re: installing htop on centos7
Thu Aug 20, 2020 8:29 am
need support.......
What do you need support for?
1) Free some space
2) Get a larger disk (2GB seems very small, 16 or 32GB are the cheapest sizes now)
3) Make sure the / filesystem is actually using all the available space
4) Install Raspbian Lite
These Sandisk A1 cards are popular:
https://www.amazon.co.uk/dp/B073JWXGNT/ ... =UTF8&th=1
16GB is £5.65 (the smallest size available)
32GB is £5.99
Pi4 8GB running PIOS64
Return to “Pidora / Fedora”
