NewToLinux
RASPBERRY PI WITH CENTOS 8
Fri Jun 19, 2020 1:24 pm
Is it possible to install CENTOS 8 on RASPBERRY PIE 4. If so can you suggest a site I can use to guide me through installing the software on your product.
B.Goode
Re: RASPBERRY PI WITH CENTOS 8
Fri Jun 19, 2020 2:08 pm
This forum thread appears to contain an answer to a similar question regarding Centos7 - viewtopic.php?f=56&t=249048 Maybe the same links will guide you to an answer for a later version?
The thread also contains a link to a support forum for that third-party Operating System.
Moonmarch
Mon Jun 22, 2020 9:15 pm
There are 2 versions of CentOS that is usable on ARM computers. You can install either the AARCH64 or the ARMHFP version of CentOS 7 version 1908. AARCH64 is the same as ARM64, which is the 64 bit version of a Linux operating system for ARM computers. The ARMHF version of CentOS is intended for Raspberry PI computer models 2 - 3. Raspberry PI computers 2 - 3 use a ARMv7 computer, the Raspberry Pi 4 uses a ARMv8 computer. The AARCH64 version of CentOS is downloaded as a .ISO file. I don't know if you can flash the .ISO image to a USB drive using Raspberry PI Imager tool.
There are several versions of CentOS 7 that you can install on the Raspberry Pi 2/3 computer. I don't which version of CentOS you should use on the Raspberry Pi computer. If you know about CentOS, your understanding of CentOS would be better than what I know about CentOS. I don't know anything about CentOS. Here is a link to the CentOS wiki website that shows you how to install the CentOS image on a Raspberry Pi 3 computer:
CentOS Linux on the Raspberry Pi 3
https://wiki.centos.org/SpecialInterest ... spberryPi3
dickon
Mon Jun 22, 2020 9:26 pm
Pi3 and Pi2 v1.2 or later are also aarch64-capable. And the Pi4's CPUs are quite happy running aarch32 code.
t3kg33k
Tue Jul 28, 2020 12:15 pm
Maybe I am not reading correctly but to me it seems this question was not answered.
Is there no CentOS 8 image for the RPi 4?
I've also posted this same question on the CentOS forum so awaiting the answer there also.
Tue Jul 28, 2020 12:34 pm
CentOS support their software, see:
https://forums.centos.org/viewtopic.php?f=55&t=73495
smallphd
Mon Aug 10, 2020 10:10 am
The following is my operations to install a vanilla CentOS 8.2 aarch64 to raspberry pi 4b.
1.Download uefi firmware
https://github.com/pftf/RPi4/releases/d ... _v1.18.zip
2.Create an SD card in `MBR` mode with a single partition of type `0x0c` (`FAT32 LBA`) or `0x0e` (`FAT16 LBA`). Then format this partition to `FAT`.
3.Extract all the files from the archive onto the partition you created above.
4.Insert the SD card.
5.Prepare two usb drives.
6.Burn the vanilla CentOS 8.2 aarch64 image to a USB drive1.
7.Plug both USB drives and power up your Raspberry Pi.
8.Now you will see the install procedure as normal. Please select the USB drive2 as the destiny drive.
There are two weaks in this situation:
1.Netcard can not be used .
2.SDcard can not be used (You must install CentOS to a USB drive).
smallphd
Tue Aug 11, 2020 3:15 am
You could insert a usb gigabit ethernet. CentOS 8.2 will recognize this network card automatically.
philofellow
Thu Aug 13, 2020 12:24 am
Here is a step by step instruction for installing centos 8 on Raspberry Pi 4. Basically you just need to burn the centos 8 aarch image to the SD card and it should work out of the box.
http://reallyappreciate.com/raspberry-p ... -centos-8/
Return to “Pidora / Fedora”
