typhoon
Re: Help test the next Debian image (wheezy)
Fri Jun 15, 2012 11:05 am
yes, every time I atp-get upgrade the fat partition looks like that.
no monitor till this evening, but if you point me to the log you need I can fetch it from the SD.
asb
Fri Jun 15, 2012 11:12 am
typhoon wrote:yes, every time I atp-get upgrade the fat partition looks like that.
The most relevant log file is /var/log/apt/term.log.
typhoon
Fri Jun 15, 2012 11:18 am
here it is
term.log.tar.gz
(1.85 KiB) Downloaded 208 times
asb
Fri Jun 15, 2012 11:23 am
typhoon wrote:here it is
Thanks. That is exactly what a successful upgrade should look like, and matches my local successful upgrades. Hmm.
typhoon
Fri Jun 15, 2012 12:00 pm
mmm, so what now? should I wait your next image build to check this update?
Want me to try something else this evening?
asb
Fri Jun 15, 2012 12:01 pm
typhoon wrote:mmm, so what now? should I wait your next image build to check this update?
I'll have a think if there's anything else I can do other than forcing a sync during the upgrade and let you know. Thanks for testing.
Sander
Fri Jun 15, 2012 12:18 pm
I've no HDMI/DVI monitor, so I've connected the Raspi to my TV using the yellow (RCA?) connector. That works sort-of; I do get an image, but it is black-and-white and it is a bit shaky at underlines.
I tried 'overscan' from raspi-config, expecting overscan has to do with TV-screen, but no result. Any tips?
Thanks.
asb
Fri Jun 15, 2012 12:27 pm
Sander wrote:I've no HDMI/DVI monitor, so I've connected the Raspi to my TV using the yellow (RCA?) connector. That works sort-of; I do get an image, but it is black-and-white and it is a bit shaky at underlines.
Thanks.
The problem is likely that composite defaults to NTSC, which your display does not support. See http://elinux.org/R-Pi_Troubleshooting# ... r_no_image and you should just be able to edit /boot/config.txt which actually has lines with comments to indicate what you might want to change. This is something raspi-config or a tool like it should eventually help you with.
javaboyuk
Fri Jun 15, 2012 12:58 pm
@asb I did do a sync and then an init 6 which should do another sync :-)
I have been in unix sa since... well I long time :-).
Suggestion for you installation script to reduce the "window" when you can corrupt the boot
install into /boot/install then sync then move (not copy) the files to correct names in /boot
then run sync again. I think this is actually essential as most users (children?) will just
power it on and off maybe at that point. I think when we develop the OS and packages
for PI we need to think very defensible.
I have just bought a card-reader so I can cut/read my own cards now. Hence I will have a look
at the broken image this evening and report back to you, and post the log file etc, however I do not remember seeing any issues and I has watching for errors, does not mean I did not miss them tho :-)
Remember I tried to run a config that gave an error earlier, so if you really do not see the issue
if you take your image do TWO (yes TWO) updates then upgrade and init 6 and don't see the problem I too will be confused, but maybe an issue with the earlier error in config?
Anyway need to do work so will post later when I am home.
Sander
Fri Jun 15, 2012 1:57 pm
Thanks.
OK, I tried a few times, but after a "sudo sync" and "sudo shutdown -r now", the /boot/config.txt is missing the stuff from the point where I edited it. I used both "sudo vi /boot/config.txt" and "sudo nano config.txt". After editing (but before rebooting), the config.txt was correctly changed:
pi@raspberrypi /boot $ grep sdtv config.txt
sdtv_mode=2
# sdtv edited by Sander
pi@raspberrypi /boot $ diff config.txt config.txt.org
36,37c36
< sdtv_mode=2
< # sdtv edited by Sander
> #sdtv_mode=2
pi@raspberrypi /boot $ sudo sync
However, after the reboot, the config.txt is larger (I added also some comment), but the added stuff is gone.
pi@raspberrypi /boot $ ls -al config.txt*
-rwxr-xr-x 1 root root 1203 Jun 15 13:38 config.txt
-rwxr-xr-x 1 root root 1180 Jun 15 13:28 config.txt.org
I'm ssh-in into the raspi from my Ubuntu, editing is done locally, so that can't be the problem.
When I open config.txt again with "sudo nano config.txt", the last line reads:
# uncomment for ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
Weird.
I scp-ed config.txt to my Ubuntu, edited it there, scp-ed it back to /boot, made a few copies, did a sync, did a "sudo reboot", and ... /boot/config.txt again is garbled. And config.txt.sdtv does not match. The ~/config.txt (a copy of /boot/config.txt) is still correct.
pi@raspberrypi ~ $ cd /boot/
pi@raspberrypi /boot $ ls -al conf*
-rwxr-xr-x 1 root root 1202 Jun 15 13:48 config.txt
-rwxr-xr-x 1 root root 1202 Jun 15 13:49 config.txt.sdtv
pi@raspberrypi /boot $ grep sdtv confi*
Binary file config.txt matches
config.txt.org:#sdtv_mode=2
pi@raspberrypi /boot $ grep sdtv ~/config.txt
sdtv_mode=2
# sdtv done by Sander
So ... is /boot/config.txt hold / overwritten by some other process?
I will now get the flash card out of the Raspi, mount it in my Ubuntu, and edit it there ...
Sander
Fri Jun 15, 2012 2:05 pm
OK, that was the solution:
Get the micro flash card out of the Raspi, put into your Ubuntu, let it mount the two partitions, find config.txt, edit it, save it, gracely umount, put the micro flash card back into the Raspi and boot it.
Now the /boot/config.txt survived the boot and contained the content I put into it, and ... we have color!
Sander
Fri Jun 15, 2012 3:30 pm
Maybe this question is not purely related to this debian image, so ignore/remove if it is not relevant here:
I'm trying to a get a Wifi USB dongle working. When I put it in the Raspi, lsusb does show it and some kernel modules are loaded. However, there appears no wlan0 in ifconfig, and lshw does not show it.
The same dongle under Ubuntu 12.04 works out of the box.
I'm an Ubuntu GUI user, and not yet a Debian CLI user ... ;)
Any tips?
On Raspi:
pi@raspberrypi ~ $ lsusb
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
pi@raspberrypi ~ $
pi@raspberrypi ~ $
pi@raspberrypi ~ $ lsmod
ipv6                  289987  22
snd_bcm2835            21605  0
snd_pcm                82208  1 snd_bcm2835
snd_seq                59808  0
snd_timer              21905  2 snd_seq,snd_pcm
snd_seq_device          6920  1 snd_seq
snd                    57668  5 snd_seq_device,snd_timer,snd_seq,snd_pcm,snd_bcm2835
snd_page_alloc          5383  1 snd_pcm
rtl8192cu             116808  1
rtl8192c_common        69644  1 rtl8192cu
rtlwifi                81641  1 rtl8192cu
mac80211              253889  3 rtlwifi,rtl8192c_common,rtl8192cu
cfg80211              180459  2 mac80211,rtlwifi
pi@raspberrypi ~ $
pi@raspberrypi ~ $ sudo lshw -C network
  *-network
       description: Ethernet interface
       physical id: 1
       logical name: eth0
       serial: b8:27:eb:87:a0:a2
       capacity: 100Mbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=smsc95xx driverversion=22-Aug-2005 duplex=full firmware=smsc95xx USB 2.0 Ethernet ip=192.168.1.52 link=yes multicast=yes port=MII speed=100Mbit/s
pi@raspberrypi ~ $ ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:87:a0:a2
          inet addr:192.168.1.52  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: 2a00:cd8:c3f1:88da:ba27:ebff:fe87:a0a2/64 Scope:Global
          inet6 addr: fe80::ba27:ebff:fe87:a0a2/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1158 errors:0 dropped:0 overruns:0 frame:0
          TX packets:999 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:238128 (232.5 KiB)  TX bytes:152375 (148.8 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
pi@raspberrypi ~ $
On Ubuntu 12.04:
sander@R540:~$ lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 1210:25f4 DigiTech
Bus 002 Device 018: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN
Bus 002 Device 016: ID 046d:c050 Logitech, Inc. RX 250 Optical Mouse
sander@R540:~$
sander@R540:~$
sander@R540:~$ lsmod
rtl8192cu             103297  0
rtl8192c_common        75767  1 rtl8192cu
rtlwifi               111202  1 rtl8192cu
ppp_deflate            13038  0
zlib_deflate           27139  1 ppp_deflate
bsd_comp               12994  0
ppp_async              17539  0
crc_ccitt              12667  1 ppp_async
option                 25849  0
usb_wwan               20491  1 option
usbserial              47077  2 option,usb_wwan
nls_iso8859_1          12713  0
nls_cp437              16991  0
vfat                   17585  0
fat                    61512  1 vfat
uas                    18180  0
usb_storage            49198  0
usbhid                 47199  0
hid                    99559  1 usbhid
pci_stub               12622  1
vboxpci                23200  0
vboxnetadp             13382  0
vboxnetflt             23441  0
vboxdrv               287082  3 vboxpci,vboxnetadp,vboxnetflt
ip6table_filter        12815  0
ip6_tables             27864  1 ip6table_filter
ebtable_nat            12807  0
ebtables               30984  1 ebtable_nat
ipt_MASQUERADE         12759  3
iptable_nat            13229  1
nf_nat                 25891  2 ipt_MASQUERADE,iptable_nat
nf_conntrack_ipv4      19716  4 iptable_nat,nf_nat
nf_defrag_ipv4         12729  1 nf_conntrack_ipv4
xt_state               12578  1
nf_conntrack           81926  5 ipt_MASQUERADE,iptable_nat,nf_nat,nf_conntrack_ipv4,xt_state
ipt_REJECT             12576  2
xt_CHECKSUM            12549  1
iptable_mangle         12734  1
xt_tcpudp              12603  5
iptable_filter         12810  1
ip_tables              27473  3 iptable_nat,iptable_mangle,iptable_filter
x_tables               29846  12 ip6table_filter,ip6_tables,ebtables,ipt_MASQUERADE,iptable_nat,xt_state,ipt_REJECT,xt_CHECKSUM,iptable_mangle,xt_tcpudp,iptable_filter,ip_tables
bridge                 90989  0
stp                    12931  1 bridge
kvm_intel             137721  0
kvm                   415549  1 kvm_intel
parport_pc             32866  0
ppdev                  17113  0
bnep                   18281  2
rfcomm                 47604  0
bluetooth             180104  10 bnep,rfcomm
binfmt_misc            17540  1
snd_hda_codec_hdmi     32474  1
snd_hda_codec_realtek   223867  1
joydev                 17693  0
samsung_laptop         13709  0
uvcvideo               72627  0
videodev               98259  1 uvcvideo
v4l2_compat_ioctl32    17128  1 videodev
arc4                   12529  4
snd_hda_intel          33773  5
snd_hda_codec         127706  3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              13668  1 snd_hda_codec
snd_pcm                97188  4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_seq_midi           13324  0
snd_rawmidi            30748  1 snd_seq_midi
snd_seq_midi_event     14899  1 snd_seq_midi
ath9k                 132390  0
snd_seq                61896  2 snd_seq_midi,snd_seq_midi_event
snd_timer              29990  2 snd_pcm,snd_seq
snd_seq_device         14540  3 snd_seq_midi,snd_rawmidi,snd_seq
psmouse                87692  0
serio_raw              13211  0
mac80211              506816  4 rtl8192cu,rtl8192c_common,rtlwifi,ath9k
ath9k_common           14053  1 ath9k
ath9k_hw              411112  2 ath9k,ath9k_common
ath                    24067  3 ath9k,ath9k_common,ath9k_hw
snd                    78855  19 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
mac_hid                13253  0
cfg80211              205544  4 rtlwifi,ath9k,mac80211,ath
intel_ips              18089  0
soundcore              15091  1 snd
snd_page_alloc         18529  2 snd_hda_intel,snd_pcm
i915                  468745  7
drm_kms_helper         46978  1 i915
drm                   242038  3 i915,drm_kms_helper
i2c_algo_bit           13423  1 i915
video                  19596  1 i915
lp                     17799  0
parport                46562  3 parport_pc,ppdev,lp
sky2                   59043  0
sander@R540:~$
sander@R540:~$
sander@R540:~$ ifconfig
<snip>
wlan1     Link encap:Ethernet  HWaddr 00:9e:81:99:ca:f4
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
sander@R540:~$
sander@R540:~$ sudo lshw -C network
  *-network
       description: Wireless interface
       product: AR9285 Wireless Network Adapter (PCI-Express)
       vendor: Atheros Communications Inc.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlan0
       version: 01
       serial: 18:f4:6a:9c:ce:d4
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath9k driverversion=3.2.0-25-generic firmware=N/A ip=192.168.1.53 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:16 memory:fc500000-fc50ffff
  *-network
       product: 88E8040 PCI-E Fast Ethernet Controller
       vendor: Marvell Technology Group Ltd.
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: eth0
       version: 00
       serial: 00:24:54:e8:54:31
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full firmware=N/A latency=0 link=no multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:41 memory:fc600000-fc603fff ioport:4000(size=256)
  *-network
       physical id: 4
       bus info: usb@2:1.5
       logical name: wlan1
       serial: 00:9e:81:99:ca:f4
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8192cu driverversion=3.2.0-25-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bgn
sander@R540:~$
On Ubuntu, "sudo iwlist wlan1 scan" does show the Wifi networks around me.
Should I manually extra / other drivers on the Raspi?
asb
Fri Jun 15, 2012 3:46 pm
sander: sudo apt-get update && sudo apt-get install firmware-realtek might be worth a try.
Sander
Fri Jun 15, 2012 7:43 pm
asb wrote:sander: sudo apt-get update && sudo apt-get install firmware-realtek might be worth a try.
I tried, and it did not make a difference. Never mind: it's probably not for this thread.
javaboyuk
Fri Jun 15, 2012 9:20 pm
@asb
OK the Raspberry PI Wheezy card not booting is reproducible:
installed image onto 4GB Transcend class 6 card
insert into RPI, with wired network, HDMI, zippy Keyboard
boot it
select expand root
select set keyboard layout (I see an error message in bottom left hand corner of screen briefly)
select finish
login
sudo init 6
<reboots ok and resizes>
login
sudo su
apt-get update
<downloads about 10Meg>
apt-get update
<downloads about 27K>
apt-get upgrade
ls -l /boot
md5sum /boot
init 6
<dead system blank screen>
to fix power off, disconnect hdmi for 3sec
remove card, insert a new image
power on
boots
<insert hdmi>
soddit112
Fri Jun 15, 2012 9:48 pm
With regards to Pis not booting after running apt-get update: I had this problem with my Pi, but after checking the boot partition I found that start.elf was 0kb. Replacing this with one of the other .elf files resulted in the Pi booting normally. I guess it must have gotten corrupted at some point in the installation procedure.
This was after running "sync" and "init 6" once the installation had completed.
thelini
Fri Jun 15, 2012 10:00 pm
Using the old Debian image I was a little disappointed with the speed it ran on my pi. This new version is a lot quicker. I'm very impressed.
Might try over clocking it.
javaboyuk
Fri Jun 15, 2012 10:21 pm
I have managed to get it to mount on my windows platform and this is the contents
of what would be /boot
J:\>dir
Volume in drive J has no label.
Volume Serial Number is 18DA-FFB9
Directory of J:\
15/06/2012 20:55 2,047,848 arm128_start.elf
15/06/2012 20:55 2,047,848 arm192_start.elf
10/06/2012 21:30 142 cmdline.txt
15/06/2012 23:02 1,228 config.txt
15/06/2012 20:55 2,047,848 arm224_start.elf
15/06/2012 20:55 16,528 bootcode.bin
15/06/2012 20:55 6,236,636 kernel.img
15/06/2012 20:55 4,195,844 kernel_cutdown.img
15/06/2012 20:55 314,691 loader.bin
9 File(s) 16,908,613 bytes
0 Dir(s) 24,537,088 bytes free
So looks like the start .elf file is not being handled correctly?
I will see if putting arm192_start.elf as start.elf works ......
IT DID!!
OK so how do we take this forward to see why its not copying the correct image
to start.elf during the update.....
is there a way to put the script in "debug mode" at squirt the sdtout/err into a file?
Sander
Sat Jun 16, 2012 12:29 pm
I have a remark / recommendation: Although the image fits on a 2GB flash card, I would say a 4GB card is minimum and certainly recommended. Reason: It's the third time in 48 hours my 2GB fills up (after installing just a few small package like usbutils etc), and I have recreate the image.
So, in the sticky: "Requirement: 4GB flash card".
With a Kingston "Kingston SDC4/4GBSP 4GB, SD Micro HC" starting at € 2.11, that should not be a problem for most people
Furthermore: How can I make a backup of an image? Just put it into a Linux system and then
sudo dd bs=1M if=/dev/sdb of=~/my-image-blabla.img
Is that it?
Thanks.
rym
Sat Jun 16, 2012 1:50 pm
Hi
Just tried the new image but I cannot seem to get any sound at all over hdmi, any ideas?
Alkarex
Sat Jun 16, 2012 4:28 pm
Many thanks to Alex Bradbury for this image on Debian Wheezy with the very convenient raspi-config.
I use it with success on a Samsung 32GB SDHC Class 10, which was not working with the official Debian Squeeze.
Like some others, I have experienced the keyboard layout error from raspi-config. Furthermore, I would suggest placing the menu entry "configure keyboard" higher than "change password", and if possible with a note if this require rebooting or not.
Furthermore, I cannot get ffmpeg to work, while it worked fine with the official image debian6-19-04-2012. In both case, I install ffmpeg with:
sudo apt-get install ffmpeg
I get an error, which is not that informative... Furthermore, I cannot find any log with more details:
pi@raspberrypi ~ $ ffmpeg
Illegal instruction
Did some of you succeed in running ffmpeg on this image?
Alkarex
Sat Jun 16, 2012 5:58 pm
Here is a strace of ffmpeg ending with "Illegal instruction":
http://pastebin.com/7RHCr3B2
P.S.: Attachments do not allow .txt or .log? What extension to use for that then?
mem
Sat Jun 16, 2012 7:41 pm
Thanks!
Are the sources available somewhere? And the scripts used to create the image?
Thanks again!
asb
Sat Jun 16, 2012 9:32 pm
Sander wrote:I have a remark / recommendation: Although the image fits on a 2GB flash card, I would say a 4GB card is minimum and certainly recommended.
Is that it?
It seems workable on a 2GB card for me (that's what I use). Though sure, you'll run out of space if you install lots more. Installing and using localepurge will actually free up a couple of hundred meg at least.
asb
Sat Jun 16, 2012 9:40 pm
mem wrote:Thanks!
Thanks again!
Of course:
http://asbradbury.org/projects/spindle/
Return to “Debian”
