MrEngman
Debian6-19-04-2012 source, firmware and tools
Wed Jun 06, 2012 1:45 pm
Can someone tell me where I can find the source, firmware and tools used to make the Debian6-19-04-2012 image on the RasPi downloads page.
rurwin
Re: Debian6-19-04-2012 source, firmware and tools
Wed Jun 06, 2012 1:49 pm
Search github for Raspberry Pi.
MrEngman
Wed Jun 06, 2012 2:50 pm
rurwin wrote:Search github for Raspberry Pi.
I can download the current code from there but that's not what I want. I don't want the current code.
If it is there how do I get code from some time in the past, e.g. the code used to create the Debian image?
What command would I need to use down load code from the past?
nick.mccloud
Wed Jun 06, 2012 3:41 pm
Er, the whole point of Git is that you can extract out a point in time - it's a fully functional source code management system.
What's not clear however is if you are looking for the code that created the kernel (and indeed, why - context always helps in answering questions).
Or if you want the install files for Debian at a point in time.
First one, check out https://github.com/raspberrypi/linux/co ... pi-patches and scroll down to the 16th April when there were a series of updates on that day.
Second one, Google led me to this: http://snapshot.debian.org/
MrEngman
Wed Jun 06, 2012 4:31 pm
nick.mccloud wrote:Er, the whole point of Git is that you can extract out a point in time - it's a fully functional source code management system.
I want to get hold of the code for the Debian6-19-04-2012 image so I can use it to check a new driver I have. I have a driver that works with that code but then stops working after the code is updated with rpi-update. I want to first check the new driver with the original code and then advance to using later versions of the code.
I also thought if I could end up making an identical image I would learn a lot in the process.
I have a clone of the git on my Pi and assume I should be able to get the code from that but I've no idea how. I also have a git manual and am trying to read through that try and find how to do it but its rather tough going at the moment.
rurwin
Wed Jun 06, 2012 4:47 pm
You scared me. The way you worded it, it looked like a probe for GPL non-conformance :-D
Clone the repository on your PC, then get a copy of TortoiseGit and you can do it all in a GUI. But TortoiseGit only works with Windows and Nuatilus (maybe Mac), and Nautilus would be a big install for a Pi; you'd bring most of Gnome.
MrEngman
Wed Jun 06, 2012 5:32 pm
rurwin wrote:You scared me. The way you worded it, it looked like a probe for GPL non-conformance :-D
Sorry, hope your'e OK now.
I prefer to stay away from GUI's but I've got some big SD cards with plenty of room so could just try it to see how it is.
Return to “Debian”
