Setup PI to work without monitor (debian image)
Posted: Sun Jun 03, 2012 5:04 pm
by piways_and_highways
Hi
I thought I would keep my notes on my PI configurations, in case it helps anyone else.
Using the PI without a monitor
You can plug your Pi into the Network and your laptop USB for low power usage and use VNC and SSH, also this method frees up the USB ports from mouse and keyboard.
I am assuming you have already used the boot.rc file to enable SSH and managed to login to the PI over SSH, or are using the HDMI for initial interfacing with the PI.
Static IP Address
If your running your PI on the local LAN. Chances are the PI will be getting the same IP Address everytime you boot. However if you want to be sure that this is the case you can edit the following config file /etc/network/interfaces. You can use whatever text editor you wish to do this, but you must run it as sudo. Once you have opened the file complete the network information that relates to your network. Use the sample below for reference, but use your IP range, gateway etc. This will give your PI the same IP each time it boots. Note: make sure nothing else on the network has the same IP.
iface eth0 inet static
address 192.168.1.5
netmask 255.255.255.0
gateway 192.168.1.1
Once you have done this restart networking or reboot
sudo /etc/init.d/network stop
sudo /etc/init.d/network start
or
sudo reboot
Next install the vncserver
sudo apt-get install tightvncserver
Now complete the initial vncserver setup as detailed below. Set this up as the pi user When you see the output below vncserver is good to go.
pi@raspberrypi:~$ vncserver
You will require a password to access your desktops.
Password:
Warning: password truncated to the length of 8.
Verify:
Would you like to enter a view-only password (y/n)? n
New 'X' desktop is raspberrypi:1
Creating default startup script /home/pi/.vnc/xstartup
Starting applications specified in /home/pi/.vnc/xstartup
Log file is /home/pi/.vnc/raspberrypi:1.log
Now we want vncserver desktop to run at boot time. This is done by putting a startup script in /etc/init.d. Create the file tightvncserver in here. This must be done as superuser.
pi@raspberrypi:~$ cd /etc/init.d
pi@raspberrypi:/etc/init.d$ sudo vim tightvncserver
Add the following to the script:
#! /bin/sh
# /etc/init.d/tightvncserver
# Carry out specific functions when asked to by the system
case "$1" in
  start)
    su pi -c '/usr/bin/vncserver'
    echo "Starting VNC server "
  stop)
    pkill vncserver
    echo "VNC Server has been stopped (didn't double check though)"
    echo "Usage: /etc/init.d/blah {start|stop}"
    exit 1
esac
exit 0
Make the script executable:
sudo chmod +x tightvncserver
Now kill the previous instance which started on hte initial setup
sudo pkill Xtightvncserver
check VNC server is not running:
ps aux | grep vnc
Now start the vncserver via the startup script
pi@raspberrypi:/etc/init.d$ sudo /etc/init.d/tightvncserver start
You should see the output as below:
Now each time you boot the raspberry PI the VNC server will be started on the IP Address at desktop :1
e.g.
192.168.1.5:1
Re: Setup PI to work without monitor (debian image)
Posted: Sun Jun 03, 2012 5:27 pm
Erratum:
should be:
Posted: Sun Jun 03, 2012 6:10 pm
Erratum 2 [missed a step off the end]
To make sure the script runs at boot and shutdown:
cd /etc/init.d
pi@raspberrypi:/etc/init.d$ sudo update-rc.d tightvncserver defaults
This will add the correct symbolic links for the script at reboot and shutdown.
[* http://www.debian-administration.org/articles/28 ]
Posted: Fri Jun 08, 2012 11:59 pm
by alexreyland
thanks for going to the effort of writing it all down step by step which is perfect for me as im trying to get my head around commands at the moment.
i am having troble at
it just comes back with
-bash: vim: command not found
even though vim seems a legit command as it will happily bring the man up for it.
if you could tell me where im going wrong that would be great, and if you dont mind telling me what the uses for vim are.
thanks
Posted: Sat Jun 09, 2012 9:03 am
by bladerunner
use vi not vim
Posted: Sat Jun 09, 2012 5:53 pm
by phrasz
Vnc is unencrypted FYI.
You also don't have to setup static IP's if you get a network scanner like nmap
sudo apt-get install nmap #debian
pacman -S nmap #arch
Then scan:
nmap 192.168.XXX.0/24 # where XXX is your class c; find it via ifconfig/ipconfig
At that point look for port 22 for ssh...
Nmap scan report for 192.168.1.130
Host is up (0.0017s latency).
Not shown: 999 closed ports
PORT   STATE SERVICE
22/tcp open  ssh
Posted: Sun Jun 10, 2012 3:04 am
by blurp
alexreyland wrote:thanks for going to the effort of writing it all down step by step which is perfect for me as im trying to get my head around commands at the moment.
thanks
There is no vim. Only vim.tiny.
Best Regards
Posted: Sun Jun 10, 2012 2:44 pm
by GravitySmacked
I'm stuck at this step, how do I add the script? I've opened the file I've just created and pasted it in but then when I try the next step:
It just tells me there is no such file or directory.
Sorry for the noob question but I'm stumped.
Posted: Sun Jun 10, 2012 2:56 pm
by alexreyland
I think I managed all the steps but I'm not sure if its all done correctly i was completly guessing it when it came to creating script with vi.
I tried connecting from my windows pc with tight vnc but it just said it was refused.
Posted: Sun Jun 10, 2012 4:46 pm
by GravitySmacked
When connecting try changing your VNC port number to 5901
Posted: Sun Jun 17, 2012 10:43 pm
by Colossus86
when i do
"sudo update-rc.d tightvncserver defaults"
i receive this error:
insserv: warning: script 'K01tightvncserver' missing LSB tags and overrides
insserv: warning: script 'tightvncserver' missing LSB tags and overrides
whats mean?
p.s. i apologize for my bad eng
p.p.s. in the script ".... echo "Usage: /etc/init.d/blah {start|stop}" ......" blah don't be replaced by tightvncserver?
Posted: Fri Jun 29, 2012 12:56 am
by jtorresheredia
Posted: Thu Aug 02, 2012 7:28 pm
by stewils
might i suggest that instead of using vim/ vi it might be easier for us mere mortals to use nano?
so after starting vnc for the first time and doing the password stuff the next bit would be:
cd /etc/init.d
sudo nano tightvncserver
Posted: Tue Aug 07, 2012 12:34 pm
by raven_squire
Another noob here with a few questions.
When I "ps aux | grep vnc" what should I expect I get five lines of stuff that I don’t understand
When I try starting the server (sudo /etc/init.d/tightvncserver start) I get
/etc/init.d/tightvncserver: 7: /etc/init.d/tightvncserver start: Syntax error: word unexpected (expecting ")")
Also what client do I use to access this server and how. Can I use Real VNC Viewer on windows 7 and just leave the default settings?
Thanks in advance.
Posted: Wed Aug 08, 2012 1:11 am
by iby
ps - command lists running processes,
ps aux - lists ALL active processes
| is pipe to combine it with another command
grep is that another command used to filter output of ps and only show lines containing "vnc"
Posted: Tue Sep 04, 2012 5:02 pm
by areyal
thanks piways_and_highways for the info, and stewils for telling about nano (I was dying with vim) :lol:
Posted: Thu Oct 18, 2012 11:37 am
by craig_uk
Hey Guys,
I am also getting the same error when trying to start the script, same as raven_squire above.
I thought it may be a copy paste thing but i have also tried typing everything out.
Any Ideas?
Posted: Wed Oct 31, 2012 4:16 am
by beave2111
craig_uk wrote:Hey Guys,
Any Ideas?
I happened to get the same error while running through this and it was caused by a typo. The keyword was esac and I had typed esc. Perhaps you did the same thing?
Posted: Sun Dec 02, 2012 2:18 am
by total_Linux_noob
Hi all, using a combination of these instructions...
http://myraspberrypiexperience.blogspot ... cally.html
...and forum user jtorresheredia's header edit, I was able to get tightvncserver up and running at boot time!
Thanks everyone!
TLN
Posted: Fri Dec 28, 2012 8:31 pm
by mrcranky
I followed the instructions, but when I get to:
The response is:
/etc/init.d/tightvncserver: 7: /etc/init.d/tightvncserver: Syntax error: word unexpected (expecting ")")
Can anyone tell me what I'm doing wrong? I'm using the Raspbian wheezy image.
Thanks!
Posted: Fri Dec 28, 2012 9:03 pm
by mrcranky
mrcranky wrote:Hi,
The response is:
Thanks!
I'll add that this is what my tightvncserver file reads, which is the exact same as what the initial post says:
#! /bin/sh
case "$1" in
start)
echo "Starting VNC server"
stop)
pkill vncserver
exit 1
esac
exit 0
Posted: Fri Jan 25, 2013 10:04 pm
by seven
After I type this:
I get this :
Syntax error: Unterminated quoted string
I typed this into the file
#! /bin/sh
case "$1" in
  start)
  stop)
    pkill vncserver
    exit 1
esac
Im rereading what I typed did I miss anything?
UPDATE: I have a feeling that those parenthesis that are used are causing the issue... but thats how the script was written..
Posted: Thu Feb 21, 2013 12:39 am
by jordan314
Thanks for this. I couldn't get init.d/vncserver to keep running on reboot. I had to run this:
sudo update-rc.d vncserver defaults 99
That sets it to run on reboot, but at a low boot order, per these threads:
http://www.abdevelopment.ca/blog/start- ... omment-355
I found that your init.d script works better than the one I found in the other forum though.
Also, I have two tricks for connecting to the raspberry pi headless. The first is to run arp -a on your desktop and look for raspberrypi. You should see something like:
raspberrypi.yourISP.com (192.168.1.109)
You can connect either via the IP or the DNS name, raspberrypi.yourISP.com.
Also, I installed Avahi, which is the same as apple's bonjour, and now I can also access the pi with the domain raspberrypi.local. So I can use http://raspberrypi.local for HTTP, ssh:pi@raspberrypi.local for SSH, etc.
Thanks--
Posted: Sat Apr 06, 2013 9:42 pm
by azrith
After following all of the instructions and other users posts, I got the script working so that the VNC server starts on boot.
Unfortunately, it seems to be in some sort of restricted mode. I get some misc errors when running my python scripts like it doesn't have access to specific files.
I also noticed that if I go to reboot I only have a logout option. If I start the VNC server when directly connected to the pi, I get all of the regular options from reboot to shutdown etc.
Anyone have any ideas why this would be and how I can go about fixing it?
Thank you!
(Update) - After doing some searching I found this guide to starting the server:
http://learn.adafruit.com/adafruit-rasp ... at-startup
This is much simpler and it also fixed my issue.
Posted: Thu Apr 11, 2013 10:11 pm
by j8t
I'm at a loss at what to do. After playing around for several hours now, I just can't get vncserver to run on boot.
This is the script I'm using, but I've tried others, including those listed in the thread:
#! /bin/sh
### BEGIN INIT INFO
# Provides:          vncserver
# Required-Start:    networking
# Default-Start:	2 3 4 5
# Default-Stop:		0 1 6
### END INIT INFO
set -e
# etc/init.d/vncserver: start and stop the vacserver daemon
. /lib/lsb/init-functions
case $1 in
	start)
		log_daemon_msg "Starting vncserver"
		/usr/bin/vncserver
 	stop)
		/usr/bin/vncserver -kill :1
	restart|force-reload)
                $0 stop && sleep 2 && $0 start
        try-restart)
                if $0 status >/dev/null; then
                        $0 restart
                else
                        exit 0
                fi
        reload)
                exit 3
        status)
                status_of_proc $DAEMON "vncserver"
                echo "Usage: $0 {start|stop|restart|try-restart|force-reload|st"$
                exit 2
esac
Any ideas what I can try? The script is set to execute and I've used update-rc.local <...> defaults to make the symbolic links...
Would appreciate any help that can be offered.
