Hi all,
i have a strange issue with the keymapping within LXDE.
I've configured my keyboard with dpkg and so far everything works well - but only on console.
On console i can use my setuped keymapping (qwertz) and all keyboard keys are detected (including german umlauts) correctly.
But if i start LXDE i discovered an other keymapping (qwerty, german umlauts are not detected). I've googled a bit around but haven't found a working way for correcting this strange behaviour.
Thank you very much for every hint.
Best regards,
André
Re: LXDE Keymap
same problem here with arch. i try to make it more clear
At least I do know now that changing to debian wouldn't help
With much trying and reading the arch wiki stuff now my keymap is german for some parts:
the symbols with shift+number key are the same as printed on my key.=>fine
but these are lost:
key pressed - sign printed in terminal
ö - ?
ä - ?
ü - ?
ß - ss
€ - e
@ - q
|, @ and € are done with altGr on german layout (don't know if us layout has that one?)
I can life without äöü but the pipe symbol is really missed.
some config:
regards,
Ben
but these are lost:
ö - ?
ä - ?
ü - ?
ß - ss
€ - e
@ - q
some config:
# cat /etc/xdg/lxsession/autostart
@setxkbmap -option -model -layout de -variant de
# cat /etc/lxsession/LXDE/autostart
@setxkbmap -model pc105
@setxkbmap -option 'grp:switch:alt_shift_toggle,grp_led:scroll,eurosign:e' 'de'
Ben
Re: LXDE Keymap
does
help?
The pipe sign should be: shift + '
left to the ä on a German keyboard (ups, not left, right !. Sorry. Same key like #, + the shift).
There are tables at wikipedia, which sometimes help. https://en.wikipedia.org/wiki/Keyboard_layout
setxkbmap de
Re: LXDE Keymap
Hello again,
update: I started over again with a bigger sdcard. I'm still in Arch but this is more of a LXDE-Problem so it would not be better located in the Arch-Thread?!
The only line to config keyboard in X now is
and the stuff in rc.conf (should not care for X)
this works a little bit better. I can do @ and | but Ö Ä Ü are still lost and if i want to have thar euro sign i get "EUR" . It seems to me that it may be less of a keymap problem but rather something like the font does no include this creepy german characters?! can I check this in any way? does anyone have a similar problem with other languages?
@nadir: thank you for your answer. That would have only helped if I stay on the us keymap. most of the keys do exactly what they should to do on a german keyboard except the few i mentioned above.
regards,
Ben
@setxkbmap de # in /etc/xdg/lxsession/LXDE/autostart
LOCALE="de_DE.UTF-8"
TIMEZONE="Europa/Berlin"
KEYMAP="de"
rest is default
regards,
Ben
Re: LXDE Keymap
Since some hours ago I have the same problem with the latest Raspbian Wheezy: I finally managed to get a WLAN adapter to work (plugged into a powered hub and after buying a Belkin N150 because the Sitecom WL113 and the ASUS Wl167g didn't work, with a ****load of different problems) with a Logitech K400 (plugged in the Pi directly). But all of a sudden, the keyboard layout of LXDE isn't set to german anymore. I did NOT change anything! At the console it's still german and eveything works fine but I can't find a way to change it back to german for LXDE, making the whole thing absolutely useless for me. 'setxbkd' does nothing, whatever combination of parameters I use, I only get "Cannot open display "default display"". In the keyboard/mouse options GUI of LXDE there is no option to change the layout. Searching the web up and down doesn't help either, nothing useful.
Oh my, all this Pi hassle ist slowly starting to make me mad and more and more makes me want to crush the Pi under some heavy boots...
Re: LXDE Keymap
Hi All !
Am having the same problem as Johann : Belgian keymap (azerty iso qwerty, etc) is used in the console, but as soon as i use X lxde the mapping reverts to qwerty . This is on a fresh install of the official raspbian, with latest updates of firmware, software et al .
I also installed an sd card with pisces MATE R2, did all the updates and upgrades, and Bingo! Qwerty in the GUI . In MATE one can set the keymap in the preferences, but this shows the be(lgian) map duly set .
I can't recall having this problem when i first installed the official raspbian image, few hours after it came out, so it's got to be one of the upgrades to the x innards thats the culprit, hence this mayday call .
If you keep it up, you're going to turn me into a grumpy old man far too soon
Regards
Binson
Regards
Binson
Re: LXDE Keymap
Hi All !
I posted a subject about this in the troubleshooting forum and got a good result . Have a look :
http://www.raspberrypi.org/phpBB3/viewt ... 20#p165520
Hope this helps .
Bye for now .
Binson
Hope this helps .
Bye for now .
Binson
