Kangaroo
How to start TightVNC on boot?
Sat Feb 15, 2014 12:54 pm
I have done this heaps of times on Ubuntu using a cronjob, but I'd like to know how to do it on Debian at boot.
I have googled it and tried but I haven't been able to get it to work.
Please hmu with some suggestions.
Kangaroo
Re: How to start TightVNC on boot?
Sat Feb 15, 2014 1:51 pm
For anyone else having trouble this is how I did it.
First open up a notepad and enter this script:
### BEGIN INIT INFO
# Provides: vncserver
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start daemon at boot time
# Description: Enable service provided by daemon.
### END INIT INFO
PATH="$PATH:/usr/bin/"
# The Username:Group that will run VNC
export USER="root"
#${RUNAS}
# The display that VNC will use
DISPLAY="1"
# Color depth (between 8 and 32)
DEPTH="16"
# The Desktop geometry to use.
#GEOMETRY="x"
GEOMETRY="800x600"
#You Can Choice GEOMETRY="1024x768" && GEOMETRY="1280x1024"
# The name that the VNC Desktop will have.
NAME="Vncserver"
OPTIONS="-name ${NAME} -depth ${DEPTH} -geometry ${GEOMETRY} :${DISPLAY}"
. /lib/lsb/init-functions
case "$1" in
start)
su ${USER} -c "/usr/bin/vncserver ${OPTIONS}"
stop)
su ${USER} -c "/usr/bin/vncserver -kill :${DISPLAY}"
restart)
$0 stop
$0 start
esac
exit 0
Change this:
to vncserver config path, should be this location or it will have your username and then bin for example: /usr/myname/bin/
Then you want to change this:
export USER="root"
To your username, leave it like this if your running it under root.
Now you want to save this in: /etc/init.d/
After you have the file saved in that directory and you have it named "vncserver" type this command:
chmod +x /etc/init.d/vncserver
and then this one:
update-rc.d vncserver defaults
then reboot your system to make sure it works :)
Good luck, if you need any help PM me.
Return to “Debian”
