mike632t
Unable to install gdm
Sun May 27, 2012 8:22 pm
OK - I know there are some very good reasons why the Debian image doesn't use gdm, however I thought I might use my Pi to allow me to discover how to access a remote x-window session.
I've removed LXDE and installed a very mimimal XFCE desktop which I prefer and that is all working fine, however when I try to install gdm I get an error
root@unknown:~# apt-get install gdm --no-install-recommends
Unpacking gdm (from .../gdm_2.20.11-4_armel.deb) ...
Setting up gdm (2.20.11-4) ...
Adding group `gdm' (GID 103) ...
Done.
Warning: The home dir /var/lib/gdm you specified already exists.
Adding system user `gdm' (UID 101) ...
Adding new user `gdm' (UID 101) with group `gdm' ...
The home directory `/var/lib/gdm' already exists. Not copying from `/etc/skel'.
adduser: Warning: The home directory `/var/lib/gdm' does not belong to the user you are currently creating.
usermod: no changes
usermod: no changes
usermod: no changes
dpkg: error processing gdm (--configure):
subprocess installed post-installation script returned error exit status 1
configured to not write apport reports
gdm
E: Sub-process /usr/bin/dpkg returned an error code (1)
Anyone know how to resolve this? I've tried removing and reinstalling gdm without success.
Thanks - Mike632T.
david3x3x3
Re: Unable to install gdm
Tue Jun 05, 2012 1:33 am
I think GDM is already installed by default. Just edit /etc/inittab to change the default runlevel to 5, and gdm will start automatically every time you boot.
mike632t
Thu Jun 14, 2012 11:37 pm
It isn't that gdm won't start - it won't install properly. Interestingly I get the same error message the first time I try to install on x86 hardware but on that platform a --reinstall resolved the problem. I've also found that gdm3 installs without a hitch but would rather not use it as it has many more dependancies..
If anyone has any ideas how to solve this one let me know - as I'd like to get it working is possible..
bredman
Fri Jun 15, 2012 8:14 am
It will not install properly because it is already installed.
gdm is part of the Debian image by default. To run it, use the command
sudo gdm
instead of startx
nadir
Fri Jun 15, 2012 8:20 am
Try
aptitude purge ~c
to remove orphaned configuration files
Perhaps look at the output of
deborphan
too
Renaming /var/lib/gdm might be worth a try too (thouhg in my humble opinion such manual fiddling should not be necessary).
I did the same, replacing lxde with xfce, and simulated the installation of gdm, which worked fine:
apt-get install -s gdm
gave no errors. The only thing i can think of that i run "aptitude purge ~c" and "deborphan" regulary (especially after bigger operations of installation/removal )
mike632t
Sun Jun 17, 2012 7:48 pm
bredman wrote:It will not install properly because it is already installed.
sudo gdm
instead of startx
No I removed it using apt-get purge when trimmng down the 'standard' image to give me something more like a minimal install. I'm then using this a a starting point for several different builds.
bredman
Sun Jun 17, 2012 7:56 pm
mike632t wrote:I removed it using apt-get purge when trimmng down the 'standard' image to give me something more like a minimal install.
It would have been helpful to tell us this and not waste our time.
mike632t
Sun Jun 17, 2012 10:03 pm
nadir wrote:Try
aptitude purge ~c
deborphan
too
I ran the following to tidy up as you sugested
# apt-get purge gdm
# aptitude purge ~c
# apt-get install gdm -s
Reading package lists... Done
Building dependency tree
Suggested packages:
pm-utils libpam-gnome-keyring
Recommended packages:
gdm-themes
gdm
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Inst gdm (2.20.11-4 Debian:6.0.5/stable [armel])
Conf gdm (2.20.11-4 Debian:6.0.5/stable [armel])
Although 'apt-get install gdm -s' succeeds, when I try to reinstall gdm using 'apt-get install gdm' it still fails with the same error message as above.
rocketero
Thu Jul 12, 2012 1:49 am
GDM is already installed.
just edit the file:
/etc/inittab
change the line:
for:
After that run gdm setup and make it login automatically.
Return to “Debian”
