timl
raspbmc cli
Mon Aug 19, 2013 8:27 am
Hi, I have a video which does not run very well under raspbmc (audio but no video). A suggestion I received was to initiate the video from the command line and see what errors appear.
I can drop out of the media center to the command line. Which program should I be running? EG.
$ xbmc.bin file.avi
thanks
ghans
Re: raspbmc cli
Mon Aug 19, 2013 8:35 am
Is omxplayer there ?
ghans
RaTTuS
Re: raspbmc cli
Mon Aug 19, 2013 8:39 am
who and where was this suggestion made
what does
omxplayer file.ext
say
what is the file encoded as
where did you get it
Covfefe
timl
Re: raspbmc cli
Mon Aug 19, 2013 9:43 am
I got the suggestion from another forum
I tried sudo find / -iname *omxp* and this threw nothing up so I am guessing omxplayer is not present. Do I need to install this? I'll have to read up on it and how it integrates.
The file looks like this
Format : AVI
Format/Info : Audio Video Interleave
File size : 414 MiB
Duration : 48mn 14s
Overall bit rate : 1 199 Kbps
Video
Format : MPEG-4 Visual
Codec ID : MP42
Codec ID/Info : Microsoft MPEG-4 v2 (pre-standard)
Codec ID/Hint : Microsoft
Duration : 48mn 14s
Bit rate : 997 Kbps
Width : 352 pixels
Height : 288 pixels
Display aspect ratio : 1.222
Frame rate : 25.000 fps
Standard : PAL
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.393
Stream size : 344 MiB (83%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 48mn 14s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel count : 2 channels
Sampling rate : 44.1 KHz
Delay relative to video : 26ms
Stream size : 66.2 MiB (16%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Title : Audio Stream
ghans
Re: raspbmc cli
Thu Aug 22, 2013 9:25 am
Shouldn't this be enough info for the other thread (in the RaspBMC forum ?) already ?
I can't see anything wrong. (That does not say much , though. )
ghans
Return to “Debian”
