markosjal
init.d problem on xbian with atvclient
Thu Aug 08, 2013 2:54 pm
The xbian forums seem useless so I will try this here
while trying to build and run ATV client on xbian, I get the following error while executing:
sudo update-rc.d atvclient defaults
[email protected] ~/atvclient $ sudo update-rc.d atvclient defaults
update-rc.d: using dependency based boot sequencing
insserv: warning: script 'atvclient' missing LSB tags and overrides
insserv: There is a loop between service watchdog and atvclient if stopped
insserv: loop involving service atvclient at depth 2
insserv: loop involving service watchdog at depth 1
insserv: Stopping atvclient depends on watchdog and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
runs fine the issue is autostarting
Any help on this is appreciated.
Return to “Debian”
