andreif
Installing Nginx 1.4.x on Raspberry Pi
Sat Jun 29, 2013 2:43 pm
Is it possible to install Nginx 1.4.x on RPi?
I have tried following these guides with no success and I see now that they are wrong:
http://virtualitblog.blogspot.se/2013/0 ... ry-pi.html
http://xn--90aexm.xn--80aahthvfydgg0a.x ... ebian.html
Should I compile Nginx from the source and how straightforward is this?
Thanks,
Andrei
andreif
Re: Installing Nginx 1.4.x on Raspberry Pi
Sat Jun 29, 2013 11:39 pm
It went OK to compile 1.5.1. Took me a half day and quite a few iterations :)
Tue Jul 09, 2013 5:42 am
I have compiled nginx from source a few weeks back. Had to do that because I needed the new feature of proxying websockets.
I don't recall how I did it. Which is good because that means it wasn't any problem:)
If I remember correctly out of the box it will build and install itself to different locations than the Debian package does. If that is a problem for you a quick search around will find you instructions on setting options to get things installed where you want.
elmicha
Tue Feb 04, 2014 8:18 pm
Although this thread is a bit old, I'll add how I compiled nginx-1.4.4 on Raspbian (in a chroot with qemu on my "big" PC, but that shouldn't matter here). I started with this guide and needed only minor changes:
Only add the deb-src line to the apt sources, because there are no armhf binary packages in the nginx repository:
sudo nano /etc/apt/sources.list.d/nginx.list
and add
deb-src http://nginx.org/packages/debian/ squeeze nginx
Get the repository's signing key and the build dependencies:
wget http://nginx.org/keys/nginx_signing.key
sudo apt-key add nginx_signing.key
sudo apt-get update
sudo apt-get build-dep nginx
Go to a directory where the normal user (e.g. pi) can write, get the sources and build them:
cd ~/src
apt-get source nginx
cd nginx-1.4.4/
dpkg-buildpackage -uc -b
The *.dpkg should land in the ~/src directory (one level up).
Remove the old nginx packages:
sudo apt-get remove "nginx*"
Press y at the prompt here ONLY if it wants to remove only the nginx packages, otherwise use something like this:
sudo apt-get remove nginx-common nginx-light
And install the new package:
sudo dpkg -i nginx_1.4.4-1~squeeze_armhf.deb
tomjerry
Sun Feb 09, 2014 6:16 pm
There is an article How to install nginx by compiling source from Nam Huy Linux Blog
http://namhuy.net/1050/how-to-install-n ... ource.html
For Ubuntu, Mint, or Debian based distributions
# apt-get update && apt-get dist-upgrade
# apt-get install build-essential libpcre3 libpcre3-dev libpcrecpp0 libssl-dev zlib1g-dev
As the time I’m writing, the lastest stable version is 1.5.10
# wget http://nginx.org/download/nginx-1.5.10.tar.gz
Extract the archive:
# tar -xvzf nginx-1.5.10.tar.gz
Go to nginx directory
# cd nginx-1.5.10
Lets keep thing simple here, i will use default install location with ssl module
./configure --sbin-path=/usr/local/sbin --with-http_ssl_module
# make
# make install
traverso85
Sun Feb 16, 2014 6:42 pm
Hi i'm Claudio,
i have some problem with nginx, at first time i had installed the version 1.2.1 by command apt-get install nginx..
Only after, i have discover that 1.4.4 or greater was necessary for the websocket..
Following this tutorial:
http://usefulmix.com/install-upgrade-to ... om-source/
have installed the version 1.5.10
Now in ssh monitor when i check nginx -v see the right version:
nginx version: nginx/1.5.10
after reboot the Pi and restart nginx, when i receive a web page from Pi in the chrome inspector see
like response header:
Server:nginx/1.2.1
:cry:
where i do wrong? someone can help me?
Thank's Claudio ;)
limpangel
Tue Feb 18, 2014 9:24 am
I don't think that guide is suitable for the arm architecture.
traverso85 wrote:Hi i'm Claudio,
Server:nginx/1.2.1
:cry:
Thank's Claudio ;)
I followed the steps in elmicha post above and that worked fine for me. Thanks.
traverso85
Tue Feb 18, 2014 10:49 am
limpangel wrote:I don't think that guide is suitable for the arm architecture.
but if it wasn't suitable, the installation process would fail or not?
and why I see the new version is installed?
Thanks Claudio
Return to “Debian”
