Zoandar
Some keys do not produce the correct characters
Fri Apr 12, 2013 4:58 am
I have a Rev B Pi 512MB running Debian from a 4GB SD card, using a Logitech G11 Gaming Keyboard. Some of the characters, such as the # symbol, are not produced from the right keys. Shift+3 should be # but it comes out as the UK pound currency symbol. The pipe symbol I can't find in any of my keys, and its key produces the # symbol.
I have tried several types of keyboard in
dpkg-reconfigure keyboard-configuration
but none of them make any difference.
Is there some way I can correct which keys are displaying which symbols?
EDIT - Problem SOLVED! I found in a post on another thread:
setxkbmap -layout us
Running that fixed the problem, and now I get the correct symbols, including the pipe symbol. :)
- Zoandar -
Current:
Pi-Top Notebook with Pi 3 B v. 1.2
Older hardware:
Rpi Rev B - 512 MB with Rev 2 GertBoard
Zoandar
Re: Some keys do not produce the correct characters
Mon Apr 15, 2013 3:25 am
Unfortunately, this only works in the GUI, and only works ONCE. It will not keep this setting, and the console is still using the wrong symbols. So my solution is not so much.
I have Googled this some more, and am still not finding any solution that actually works. Any help will be appreciated. If I get to the point where I want to use the "pipe" symbol, say for grep, I can't, because I have not found any key that generates that symbol yet.
- Zoandar -
Current:
Older hardware:
SirLagz
Mon Apr 15, 2013 4:11 am
Try running dpkg-reconfigure keyboard-configuration as root / sudo
Zoandar
Mon Apr 15, 2013 2:41 pm
Thanks for the reply. Along the way, as I tried various suggestions found online, including the one you mentioned, nothing was working. Then I ran across this post, and in my reply to it I detail how I used the information to solve the problem. It now gives me the correct symbols both in X and on the console.
http://www.raspberrypi.org/phpBB3/viewt ... 16#p331516
Thanks for the help! :)
- Zoandar -
Current:
Older hardware:
MidnightJava
Sat May 25, 2013 8:27 pm
I had the same problems, trying to use an Apple keyboard. At first I thought setting the keyboard layout and locale didn't help, but I found I had to reboot to have the changes take effect.
flanman
Sat Jun 08, 2013 2:13 pm
Thanks for all the recon Zoandar, that worked great!
Zoandar
Sat Jun 08, 2013 7:53 pm
My pleasure, Flanman. I like to leave something behind so that others can benefit from my efforts. :)
- Zoandar -
Current:
Older hardware:
mynameisafruit
Wed Aug 07, 2013 11:23 pm
After trying everything here, I ended up just doing the following and it worked for me:
sudo vi /etc/default/keyboard
change the XKBLAYOUT propery to us:
XKBLAYOUT="us"
Save and reboot
jc_io
Tue Mar 08, 2016 10:42 pm
Worked for me a a usb Logitech.
borland502
Sun Dec 04, 2016 9:08 pm
If you're running retropie, or without x11, these commands will set you up.
sudo apt-get install console-common
sudo dpkg-reconfigure console-data
From the full list, select pc / qwerty / US american / Standard / Standard
Credit to the ask ubuntu site: http://askubuntu.com/questions/434849/c ... english-us
Return to “Debian”
Who is online
Users browsing this forum: No registered users and 2 guests
