dextrus
Manually installing packages
Tue Feb 12, 2013 10:44 am
I'm trying to write a tutorial for people without internet-enabled Pis on how to install Debian packages manually.
I'm checking the dependencies for the packages to see what is required, manually downloading the required .deb files, copying them over to the Pi and then installing them in reverse order using dkpg.
The thing is, I've tried two packages now (reasonably complex to show how to resolve dependencies) and both fail. Both packages work if installed using apt-get (which defeats the purpose). I have also checked the manually installed packages with apt-rdepends and everything seems fine, only they don't work (illegal instruction).
Am I doing something wrong, or is something missing (note: I'm pretty certain I'm not missing a package)?
/Dextrus
Have more FUN with your Pi. Visit www.pi-fun.com
rurwin
Re: Manually installing packages
Tue Feb 12, 2013 10:54 am
Are you sure you are downloading the right architecture?
dextrus
Tue Feb 12, 2013 11:01 am
Yes, armhf.
jojopi
Tue Feb 12, 2013 11:06 am
Your Pi is not running Debian armhf. It is running Raspbian armhf. You must get the debs from the Raspbian repository. Debian armhf packages are compiled for ARMv7 and will not run on the Pi's ARMv6 processor.
dextrus
Tue Feb 12, 2013 11:15 am
Ah thanks. I guess that rules out manual installation of packages then!
Spid
Tue Feb 12, 2013 11:16 am
dextrus wrote:Yes, armhf.
Raspbian "Wheezy" (RPF), like PiBang and Bodhi etal are based of Raspbian ARMHF NOT Debian ARMHF http://www.raspbian.org/RaspbianRepository
You just need to use the correct repository when writing the manual....
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
jojopi
Tue Feb 12, 2013 11:41 am
dextrus wrote:Ah thanks. I guess that rules out manual installation of packages then!
You can install packages manually, if you download them from here: http://mirrordirector.raspbian.org/raspbian/
dextrus
Tue Feb 12, 2013 12:02 pm
Ah, I see. In /pool/main there is an alphabetical list of most .deb's. Thanks.
Return to “Debian”
