MrMarkus
Problem with vsftpd - "553 Could not create file"
Mon Dec 24, 2012 7:21 am
Hi all,
Does anyone have any thoughts on why I can't ftp a file to my Pi using vsftpd?
I can browse folders, ftp files off the Pi but when I try to ftp to the Pi I get a response: "553 Could not create file, critical file transfer error"
I'm running the Rasbian Wheezy O/S, probably from one of the first releases as it was a few months ago that I downloaded it.
I've modified vsftpd.conf to set write_enable = yes & local_enable = yes, I can't see any other areas of the config that might be preventing writes.
I've tried the latest version of filezilla on my win7 machine, and "ftp" from the win7 command line - both fail in the same way so I think it's somethign with vsftpd or the Pi / O/S.
I'm trying to test the first PiXi-200 prototype (please see my other posts if you're interested) and need a means of getting an FPGA configuration file into /home without logging in to the Pi itself. FTP seemed the easiest way of doing this... I know vsftpd should work but i'm Linux novice so I'm going to plead ignorance here and shout for help
Many thanks,
Mark
Return to “Debian”
