Vnc Viewer, can't reconnect
Posted: Fri Mar 31, 2017 4:20 pm
by antc1111
Hi
I have kali-linux-full on my Raspberry and I install vnc viewer. When im connect everythings works great but if i disconnect from my client i get error: The connection was refused by the computer. Then i have to reboot my Raspberry to make connection again
I make file cd /usr/local/bin/sharex11vnc to automaticly run x11vnc in system start.
#!/bin/sh
x11vnc -ncache 10 -auth guess -repeat -nap -loop -forever -rfbauth ~/.vnc/passwd -desktop "VNC ${USER}@${HOSTNAME}"|grep -Eo "[0-9]{4}">~/.vnc/port.txt
# comment this out if you dont want a pop up telling you which port you're using
zenity --info --text="Your VNC port is 'cat~/.vnc/port.txt'"
and give him permissions
chmod 755 /usr/local/bin/sharex11vnc
Where is the problem. How can i solve this?
