wjmeso
no network after raspberry-sys-mods20170306
Tue Mar 21, 2017 3:43 pm
On i386 Lenovo with Realtec rtl81888cu I installed the 2016-12-13-pixel-x86-jessie and it ran fine until I performed upgrade which contained raspberrypi-sys-mods-20170306.
After a reboot no network was available.Restored backup, rebooted and network was present.
After putting the raspberrypi-sys-mods-2017-03-06 back on and re-booting, no network is available.
I used synaptic to put a few upgrades on at a time, reboot and if I worked did a backup then did the next few upgrades until I got the failure.
Following are various screen prints from system when the failure happens:
[email protected]:~ $ ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:15:58:df:1c:16
inet6 addr: fe80::1bb:9bac:fb09:e31a/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:16 Memory:d0080000-d00a0000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:256 errors:0 dropped:0 overruns:0 frame:0
TX packets:256 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:20736 (20.2 KiB) TX bytes:20736 (20.2 KiB)
[email protected]:~ $ iwlist wlan0 scan
wlan0 Interface doesn't support scanning.
[email protected]:~ $ sudo ifup wlan0
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to bring up wlan0.
[email protected]:~ $ sudo ifdown wlan0
ifdown: interface wlan0 not configured
TO SHOW MODEM IS PRESENT:
[email protected]:~ $ lsusb
Bus 005 Device 007: ID 0781:5575 SanDisk Corp.
Bus 005 Device 006: ID 18a5:0302 Verbatim, Ltd 32GB Flash Drive
Bus 005 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 04b3:310b IBM Corp. Red Wheel Mouse
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 003: ID 067b:2305 Prolific Technology, Inc. PL2305 Parallel Port
Bus 002 Device 002: ID 0461:0371 Primax Electronics, Ltd Visioneer Onetouch 8920 Scanner
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Any help? Will continue running the 20161220 raspberrypi-sys-mods with it marked hold for now.
ShiftPlusOne
Re: no network after raspberry-sys-mods20170306
Tue Mar 21, 2017 4:18 pm
Does removing /etc/modprobe.d/blacklist-rtl*.conf fix the problem?
wjmeso
Tue Mar 21, 2017 5:05 pm
NEGATIVE, removed the two "rtl8****" entries, re-booted and still no network connection, access to the forum is via my windows system. As information, it also fails on 20170315.
ShiftPlusOne
Tue Mar 21, 2017 5:28 pm
I don't see any other relevant changes:
https://github.com/RPi-Distro/raspberry ... b...master
wjmeso
Tue Mar 21, 2017 6:35 pm
What will cause the "ifup wlan0"
as part of the error msg to have
"run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1"
in other words, what is pre-up looking at/for?
If I look at the wireless network when it works, there are 6-8 with strong signals (don't know if that helps).
I'm new to this unix/raspbdian world, looked for something new in retirement years to learn.
ShiftPlusOne
Tue Mar 21, 2017 6:56 pm
It would be running /etc/network/if-pre-up.d/wpasupplicant
Are you able to launch wpa_supplicant manually?
wjmeso
Tue Mar 21, 2017 8:30 pm
You got it--when I ran wpa_supplicant using driver rtl8192cu I get "wlan0: unsupported driver rtl8192cu".
Why it only fails once you do the upgrade to raspberry-sys-mods is strange. Would have though that some of the DEBIAN modules updates would have caused it to failed first. Guess I'll just have to keep the sys-mods on hold.
Thanks a bunch for the help....
ShiftPlusOne
Tue Mar 21, 2017 10:46 pm
What command are you launching it with?
wjmeso
Tue Mar 21, 2017 11:37 pm
command I am issuing is:
sudo wpa_supplicant -Drtl8192cu -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
According to Debian document the RTL8188cu uses the rtl8192 kernal, looks like the documentation for version 8 needs to be updated also
ShiftPlusOne
Tue Mar 21, 2017 11:40 pm
-D driver
    Driver to use (can be multiple drivers: nl80211,wext). (Per interface, see the available options below.)
That's not the type of driver the -D option refers to. Try -Dwext
wjmeso
Wed Mar 22, 2017 12:02 am
Using the "Dwext" here is the screen output:
[email protected]:~ $ sudo wpa_supplicant -Dwext -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
Successfully initialized wpa_supplicant
Could not read interface wlan0 flags: No such device
WEXT: Could not set interface 'wlan0' UP
wlan0: Failed to initialize driver interface
ShiftPlusOne
Wed Mar 22, 2017 10:23 am
Could you post the output of 'dmesg' and 'ifconfig -a'?
wjmeso
Wed Mar 22, 2017 12:27 pm
Not sure what you want from "dmsg", not familiar with it. Is that the run.log output in .cache?
Anyway, here the the ifconfig -a output
RX packets:192 errors:0 dropped:0 overruns:0 frame:0
TX packets:192 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15552 (15.1 KiB) TX bytes:15552 (15.1 KiB)
ShiftPlusOne
Wed Mar 22, 2017 12:42 pm
wjmeso wrote:Not sure what you want from "dmsg", not familiar with it.
Just the full output of the command "dmesg" (not "dmsg"). Please use code tags so that it doesn't take up the full screen:
example
wjmeso
Wed Mar 22, 2017 2:11 pm
Not sure how to do it--when I click on your "code: select all" cursor moves to "example" and nothing else happens. I think you are trying to show me how to shorten the output but not getting though the brick wall, sri...
ShiftPlusOne
Wed Mar 22, 2017 2:47 pm
When you post the output of dmesg, select it all and then click the 'Code' button. It should have 'Code' tags around it when you click submit.
If you don't figure it out, don't worry, just post the output as is.
wjmeso
Wed Mar 22, 2017 3:54 pm
Large, tried to attach as a file but said "file" extension invalid so converted to RichText to copy into here. [email protected]:~ $ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.16.0-4-686-pae ([email protected]) (gcc version 4.8.4 (Debian 4.8.4-1) ) #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19)
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007f51ffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007f520000-0x000000007f535fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007f536000-0x000000007f5fffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007f600000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.34 present.
[ 0.000000] DMI: IBM 8212MUS/IBM, BIOS 2EKT42AUS 11/29/2006
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x7f520 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-E3FFF uncachable
[ 0.000000] E4000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07F600000 mask FFFE00000 uncachable
[ 0.000000] 2 base 07F800000 mask FFF800000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [mem 0x000f6670-0x000f667f] mapped at [c00f6670]
[ 0.000000] initial memory mapped: [mem 0x00000000-0x01bfffff]
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[ 0.000000] init_memory_mapping: [mem 0x37200000-0x373fffff]
[ 0.000000] [mem 0x37200000-0x373fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x34000000-0x371fffff]
[ 0.000000] [mem 0x34000000-0x371fffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x33ffffff]
[ 0.000000] [mem 0x00100000-0x001fffff] page 4k
[ 0.000000] [mem 0x00200000-0x33ffffff] page 2M
[ 0.000000] init_memory_mapping: [mem 0x37400000-0x375fdfff]
[ 0.000000] [mem 0x37400000-0x375fdfff] page 4k
[ 0.000000] BRK [0x017a1000, 0x017a1fff] PGTABLE
[ 0.000000] BRK [0x017a2000, 0x017a3fff] PGTABLE
[ 0.000000] BRK [0x017a4000, 0x017a4fff] PGTABLE
[ 0.000000] BRK [0x017a5000, 0x017a5fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x7ce62000-0x7f51ffff]
[ 0.000000] Allocated new RAMDISK: [mem 0x34f40000-0x375fd7f9]
[ 0.000000] Move RAMDISK from [mem 0x7ce62000-0x7f51f7f9] to [mem 0x34f40000-0x375fd7f9]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F6590 000014 (v00 PTLTD )
[ 0.000000] ACPI: RSDT 0x000000007F530526 000040 (v01 PTLTD RSDT 060400D0 LTP 00000000)
[ 0.000000] ACPI: FACP 0x000000007F535E2B 000074 (v01 IBM THINKCEN 060400D0 PTL 00000001)
[ 0.000000] ACPI: DSDT 0x000000007F530761 0056CA (v01 IBM THINKCEN 060400D0 MSFT 0100000E)
[ 0.000000] ACPI: FACS 0x000000007F58BFC0 000040
[ 0.000000] ACPI: TCPA 0x000000007F535E9F 000032 (v02 IBM THINKCEN 060400D0 PTL 00000001)
[ 0.000000] ACPI: MCFG 0x000000007F535ED1 00003C (v01 PTLTD MCFG 060400D0 LTP 00000000)
[ 0.000000] ACPI: APIC 0x000000007F535F0D 000068 (v01 PTLTD ? APIC 060400D0 LTP 00000000)
[ 0.000000] ACPI: BOOT 0x000000007F535F75 000028 (v01 PTLTD $SBFTBL$ 060400D0 LTP 00000001)
[ 0.000000] ACPI: ASF! 0x000000007F535F9D 000063 (v32 CETP CETP 060400D0 PTL 00000001)
[ 0.000000] ACPI: SSDT 0x000000007F530566 0001FB (v01 PmRef CpuPm 00003000 INTL 20030224)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1151MB HIGHMEM available.
[ 0.000000] 885MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 375fe000
[ 0.000000] low ram: 0 - 375fe000
[ 0.000000] BRK [0x017a6000, 0x017a6fff] PGTABLE
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[ 0.000000] Normal [mem 0x01000000-0x375fdfff]
[ 0.000000] HighMem [mem 0x375fe000-0x7f51ffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00001000-0x0009efff]
[ 0.000000] node 0: [mem 0x00100000-0x7f51ffff]
[ 0.000000] On node 0 totalpages: 521406
[ 0.000000] free_area_init_node: node 0, pgdat c1661280, node_mem_map f3f50020
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] Normal zone: 1740 pages used for memmap
[ 0.000000] Normal zone: 222718 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2303 pages used for memmap
[ 0.000000] HighMem zone: 294690 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] Reserving Intel graphics stolen memory at 0x7f800000-0x7fffffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] e820: [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @f3f28000 s34752 r0 d22592 u57344
[ 0.000000] pcpu-alloc: s34752 r0 d22592 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519634
[ 0.000000] Kernel command line: BOOT_IMAGE=/live/vmlinuz1 boot=live components quiet splash plymouth.ignore-serial-consoles persistence initrd=/live/initrd1.img
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000375fe:0007f520)
[ 0.000000] Initializing Movable for node 0 (00000000:00000000)
[ 0.000000] Memory: 2020780K/2085624K available (4624K kernel code, 523K rwdata, 1452K rodata, 660K init, 460K bss, 64844K reserved, 1178760K highmem)
[ 0.000000] virtual kernel memory layout:
fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
pkmap : 0xff600000 - 0xff800000 (2048 kB)
vmalloc : 0xf7dfe000 - 0xff5fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf75fe000 ( 885 MB)
.init : 0xc1675000 - 0xc171a000 ( 660 kB)
.data : 0xc148473c - 0xc1673c80 (1981 kB)
.text : 0xc1000000 - 0xc148473c (4625 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f3808000 soft=f380a000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3391.653 MHz processor
[ 0.008014] Calibrating delay loop (skipped), value calculated using timer frequency.. 6783.30 BogoMIPS (lpj=13566612)
[ 0.008020] pid_max: default: 32768 minimum: 301
[ 0.008037] ACPI: Core revision 20140424
[ 0.016168] ACPI: All ACPI Tables successfully acquired
[ 0.016203] Security Framework initialized
[ 0.016217] AppArmor: AppArmor disabled by boot time parameter
[ 0.016219] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.016247] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.016251] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.016582] Initializing cgroup subsys memory
[ 0.016592] Initializing cgroup subsys devices
[ 0.016606] Initializing cgroup subsys freezer
[ 0.016613] Initializing cgroup subsys net_cls
[ 0.016621] Initializing cgroup subsys blkio
[ 0.016628] Initializing cgroup subsys perf_event
[ 0.016632] Initializing cgroup subsys net_prio
[ 0.016667] CPU: Physical Processor ID: 0
[ 0.016670] CPU: Processor Core ID: 0
[ 0.016678] mce: CPU supports 4 MCE banks
[ 0.016689] CPU0: Thermal monitoring handled by SMI
[ 0.016693] process: using mwait in idle threads
[ 0.016703] Last level iTLB entries: 4KB 64, 2MB 64, 4MB 64
Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64, 1GB 0
tlb_flushall_shift: 6
[ 0.016877] Freeing SMP alternatives memory: 20K (c171a000 - c171f000)
[ 0.020009] ftrace: allocating 20830 entries in 41 pages
[ 0.028116] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.028499] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.069743] smpboot: CPU0: Intel(R) Pentium(R) 4 CPU 3.40GHz (fam: 0f, model: 04, stepping: 09)
[ 0.072000] APIC calibration not consistent with PM-Timer: 808ms instead of 100ms
[ 0.072000] APIC delta adjusted to PM-Timer: 1246873 (10075329)
[ 0.072000] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.072000] ... version: 0
[ 0.072000] ... bit width: 40
[ 0.072000] ... generic registers: 18
[ 0.072000] ... value mask: 000000ffffffffff
[ 0.072000] ... max period: 0000007fffffffff
[ 0.072000] ... fixed-purpose events: 0
[ 0.072000] ... event mask: 000000000003ffff
[ 0.072000] CPU 1 irqstacks, hard=f3948000 soft=f394a000
[ 0.072000] x86: Booting SMP configuration:
[ 0.072000] .... node #0, CPUs: #1
[ 0.012000] Initializing CPU#1
[ 0.012000] CPU1: Thermal monitoring handled by SMI
[ 0.081427] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.083498] x86: Booted up 1 node, 2 CPUs
[ 0.083503] smpboot: Total of 2 processors activated (13566.61 BogoMIPS)
[ 0.084158] devtmpfs: initialized
[ 0.084446] PM: Registering ACPI NVS region [mem 0x7f536000-0x7f5fffff] (827392 bytes)
[ 0.085885] pinctrl core: initialized pinctrl subsystem
[ 0.086006] NET: Registered protocol family 16
[ 0.086215] cpuidle: using governor ladder
[ 0.086220] cpuidle: using governor menu
[ 0.086320] ACPI: bus type PCI registered
[ 0.086324] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.086452] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.086455] PCI: Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub with MMCONFIG support
[ 0.086461] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.086463] PCI: Using MMCONFIG for extended config space
[ 0.086465] PCI: Using configuration type 1 for base access
[ 0.100141] ACPI: Added _OSI(Module Device)
[ 0.100141] ACPI: Added _OSI(Processor Device)
[ 0.100141] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.100141] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.104757] ACPI: Interpreter enabled
[ 0.104776] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20140424/hwxface-580)
[ 0.104797] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.104801] ACPI: Using IOAPIC for interrupt routing
[ 0.104843] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.146491] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.146500] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.146508] ACPI BIOS Error (bug): \_SB_.PCI0._OSC: Excess arguments - ASL declared 5, ACPI requires 4 (20140424/nsarguments-189)
[ 0.146599] \_SB_.PCI0:_OSC evaluation returned wrong type
[ 0.146602] _OSC request data:1 1f 0
[ 0.146608] acpi PNP0A03:00: _OSC failed (AE_TYPE); disabling ASPM
[ 0.149212] PCI host bridge to bus 0000:00
[ 0.149217] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.149221] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.149224] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.149227] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[ 0.149230] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.149233] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.149235] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.149238] pci_bus 0000:00: root bus resource [mem 0x80000000-0xfebfffff]
[ 0.149241] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed40fff]
[ 0.149244] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.149258] pci 0000:00:00.0: [8086:2770] type 00 class 0x060000
[ 0.149413] pci 0000:00:02.0: [8086:2772] type 00 class 0x030000
[ 0.149429] pci 0000:00:02.0: reg 0x10: [mem 0xd0100000-0xd017ffff]
[ 0.149437] pci 0000:00:02.0: reg 0x14: [io 0x30c0-0x30c7]
[ 0.149445] pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff pref]
[ 0.149453] pci 0000:00:02.0: reg 0x1c: [mem 0xd0180000-0xd01bffff]
[ 0.149595] pci 0000:00:02.1: [8086:2776] type 00 class 0x038000
[ 0.149607] pci 0000:00:02.1: reg 0x10: [mem 0x00000000-0x0007ffff]
[ 0.149783] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.149805] pci 0000:00:1b.0: reg 0x10: [mem 0xd01c0000-0xd01c3fff 64bit]
[ 0.149892] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.149951] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.150033] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.150123] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.150185] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.150268] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[ 0.150352] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.150413] pci 0000:00:1c.1: System wakeup disabled by ACPI
[ 0.150496] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.150543] pci 0000:00:1d.0: reg 0x20: [io 0x3000-0x301f]
[ 0.150640] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.150720] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.150767] pci 0000:00:1d.1: reg 0x20: [io 0x3020-0x303f]
[ 0.150862] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.150941] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.150987] pci 0000:00:1d.2: reg 0x20: [io 0x3040-0x305f]
[ 0.151082] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.151160] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.151206] pci 0000:00:1d.3: reg 0x20: [io 0x3060-0x307f]
[ 0.151300] pci 0000:00:1d.3: System wakeup disabled by ACPI
[ 0.151387] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.151410] pci 0000:00:1d.7: reg 0x10: [mem 0xd03c4000-0xd03c43ff]
[ 0.151505] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.151564] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.151644] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.151749] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.151831] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[ 0.151924] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.151934] pci 0000:00:1f.0: can't claim BAR 13 [io 0x1000-0x107f]: address conflict with ACPI CPU throttle [io 0x1010-0x1015]
[ 0.151941] pci 0000:00:1f.0: quirk: [io 0x1180-0x11bf] claimed by ICH6 GPIO
[ 0.151950] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 4 PIO at 0800 (mask 00ff)
[ 0.152099] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x010180
[ 0.152117] pci 0000:00:1f.2: reg 0x10: [io 0x0000-0x0007]
[ 0.152127] pci 0000:00:1f.2: reg 0x14: [io 0x0000-0x0003]
[ 0.152137] pci 0000:00:1f.2: reg 0x18: [io 0x0000-0x0007]
[ 0.152147] pci 0000:00:1f.2: reg 0x1c: [io 0x0000-0x0003]
[ 0.152157] pci 0000:00:1f.2: reg 0x20: [io 0x30b0-0x30bf]
[ 0.152177] pci 0000:00:1f.2: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.152179] pci 0000:00:1f.2: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.152182] pci 0000:00:1f.2: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.152185] pci 0000:00:1f.2: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.152209] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.152332] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.152390] pci 0000:00:1f.3: reg 0x20: [io 0x3080-0x309f]
[ 0.152632] pci 0000:02:00.0: [8086:108c] type 00 class 0x020000
[ 0.152665] pci 0000:02:00.0: reg 0x10: [mem 0xd0080000-0xd009ffff]
[ 0.152685] pci 0000:02:00.0: reg 0x14: [mem 0xd0000000-0xd007ffff]
[ 0.152705] pci 0000:02:00.0: reg 0x18: [io 0x4000-0x401f]
[ 0.152873] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.152975] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.152989] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.152995] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ 0.153000] pci 0000:00:1c.0: bridge window [mem 0xd0000000-0xd00fffff]
[ 0.153087] pci 0000:00:1c.1: PCI bridge to [bus 04]
[ 0.153093] pci 0000:00:1c.1: bridge window [io 0x0000-0x0fff]
[ 0.153098] pci 0000:00:1c.1: bridge window [mem 0x00000000-0x000fffff]
[ 0.153106] pci 0000:00:1c.1: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 0.153186] pci 0000:0a:09.0: [135c:0020] type 00 class 0x070200
[ 0.153203] pci 0000:0a:09.0: reg 0x10: [io 0x5400-0x547f]
[ 0.153214] pci 0000:0a:09.0: reg 0x14: [io 0x5480-0x549f]
[ 0.153260] pci 0000:0a:09.0: reg 0x30: [mem 0x00000000-0x000007ff pref]
[ 0.153346] pci 0000:0a:0a.0: [11c1:0620] type 00 class 0x078000
[ 0.153368] pci 0000:0a:0a.0: reg 0x10: [io 0x5000-0x50ff]
[ 0.153454] pci 0000:0a:0a.0: PME# supported from D3hot D3cold
[ 0.153562] pci 0000:00:1e.0: PCI bridge to [bus 0a] (subtractive decode)
[ 0.153568] pci 0000:00:1e.0: bridge window [io 0x5000-0x5fff]
[ 0.153577] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.153581] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.153584] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.153587] pci 0000:00:1e.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.153589] pci 0000:00:1e.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.153592] pci 0000:00:1e.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.153595] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xfebfffff] (subtractive decode)
[ 0.153598] pci 0000:00:1e.0: bridge window [mem 0xfed40000-0xfed40fff] (subtractive decode)
[ 0.153601] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.153623] pci_bus 0000:00: on NUMA node 0
[ 0.153943] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.154050] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.154154] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.154259] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 *9 10 11 12 14 15)
[ 0.154367] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.154478] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 *9 10 11 12 14 15)
[ 0.154586] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 *9 10 11 12 14 15)
[ 0.154694] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.166623] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.166623] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.166623] vgaarb: loaded
[ 0.166623] vgaarb: bridge control possible 0000:00:02.0
[ 0.168009] PCI: Using ACPI for IRQ routing
[ 0.175155] PCI: pci_cache_line_size set to 64 bytes
[ 0.175218] e820: reserve RAM buffer [mem 0x0009f800-0x0009ffff]
[ 0.175221] e820: reserve RAM buffer [mem 0x7f520000-0x7fffffff]
[ 0.175575] hpet clockevent registered
[ 0.175580] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.175585] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.175591] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.177026] Switched to clocksource hpet
[ 0.188268] pnp: PnP ACPI init
[ 0.188293] ACPI: bus type PNP registered
[ 0.188637] system 00:00: [io 0x04d0-0x04d1] has been reserved
[ 0.188643] system 00:00: [io 0x0200-0x0207] has been reserved
[ 0.188647] system 00:00: [io 0x0800-0x080f] has been reserved
[ 0.188650] system 00:00: [io 0x0810-0x0865] has been reserved
[ 0.188654] system 00:00: [io 0x0880-0x08ff] has been reserved
[ 0.188658] system 00:00: [io 0x1000-0x107f] could not be reserved
[ 0.188661] system 00:00: [io 0x1100-0x111f] has been reserved
[ 0.188665] system 00:00: [io 0x1180-0x11bf] has been reserved
[ 0.188668] system 00:00: [io 0xe000-0xe00f] has been reserved
[ 0.188672] system 00:00: [io 0xfe00] has been reserved
[ 0.188675] system 00:00: [io 0xfe10-0xfe11] has been reserved
[ 0.188680] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.188684] system 00:00: [mem 0xfebffc00-0xfebfffff] has been reserved
[ 0.188687] system 00:00: [mem 0xfed13000-0xfed13fff] has been reserved
[ 0.188691] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.188694] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.188698] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.188701] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.188705] system 00:00: [mem 0xfed50000-0xfed8ffff] has been reserved
[ 0.188708] system 00:00: [mem 0xfef00000-0xfeffffff] has been reserved
[ 0.188714] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.188788] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.189120] pnp 00:02: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.189221] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.189360] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.195245] pnp 00:05: [dma 2]
[ 0.197176] pnp 00:05: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.203239] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.212654] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.221591] pnp 00:08: [dma 1]
[ 0.224052] pnp 00:08: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.226423] pnp 00:09: Plug and Play ACPI device, IDs NSC1200 (disabled)
[ 0.226464] pnp: PnP ACPI: found 10 devices
[ 0.226466] ACPI: bus type PNP unregistered
[ 0.226474] PnPBIOS: Disabled by ACPI PNP
[ 0.265412] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000
[ 0.265428] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 04] add_size 1000
[ 0.265433] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04] add_size 200000
[ 0.265437] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff] to [bus 04] add_size 200000
[ 0.265454] pci 0000:00:1f.0: BAR 13: [io 0x1000-0x107f] has bogus alignment
[ 0.265460] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.265463] pci 0000:00:1c.1: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.265467] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.265470] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.265485] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80000000-0x801fffff 64bit pref]
[ 0.265493] pci 0000:00:1c.1: BAR 14: assigned [mem 0x80200000-0x803fffff]
[ 0.265503] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref]
[ 0.265509] pci 0000:00:1e.0: BAR 14: assigned [mem 0x80600000-0x806fffff]
[ 0.265514] pci 0000:00:02.1: BAR 0: assigned [mem 0x80700000-0x8077ffff]
[ 0.265522] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.265527] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.265531] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ 0.265537] pci 0000:00:1c.0: bridge window [mem 0xd0000000-0xd00fffff]
[ 0.265542] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff 64bit pref]
[ 0.265549] pci 0000:00:1c.1: PCI bridge to [bus 04]
[ 0.265553] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.265559] pci 0000:00:1c.1: bridge window [mem 0x80200000-0x803fffff]
[ 0.265564] pci 0000:00:1c.1: bridge window [mem 0x80400000-0x805fffff 64bit pref]
[ 0.265573] pci 0000:0a:09.0: BAR 6: assigned [mem 0x80600000-0x806007ff pref]
[ 0.265577] pci 0000:00:1e.0: PCI bridge to [bus 0a]
[ 0.265581] pci 0000:00:1e.0: bridge window [io 0x5000-0x5fff]
[ 0.265586] pci 0000:00:1e.0: bridge window [mem 0x80600000-0x806fffff]
[ 0.265596] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.265599] pci_bus 0000:00: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.265602] pci_bus 0000:00: resource 6 [mem 0x000d0000-0x000d3fff]
[ 0.265605] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff]
[ 0.265607] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff]
[ 0.265610] pci_bus 0000:00: resource 9 [mem 0x000dc000-0x000dffff]
[ 0.265613] pci_bus 0000:00: resource 10 [mem 0x80000000-0xfebfffff]
[ 0.265616] pci_bus 0000:00: resource 11 [mem 0xfed40000-0xfed40fff]
[ 0.265619] pci_bus 0000:00: resource 12 [io 0x0d00-0xffff]
[ 0.265622] pci_bus 0000:02: resource 0 [io 0x4000-0x4fff]
[ 0.265625] pci_bus 0000:02: resource 1 [mem 0xd0000000-0xd00fffff]
[ 0.265627] pci_bus 0000:02: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
[ 0.265631] pci_bus 0000:04: resource 0 [io 0x2000-0x2fff]
[ 0.265633] pci_bus 0000:04: resource 1 [mem 0x80200000-0x803fffff]
[ 0.265636] pci_bus 0000:04: resource 2 [mem 0x80400000-0x805fffff 64bit pref]
[ 0.265639] pci_bus 0000:0a: resource 0 [io 0x5000-0x5fff]
[ 0.265642] pci_bus 0000:0a: resource 1 [mem 0x80600000-0x806fffff]
[ 0.265645] pci_bus 0000:0a: resource 4 [io 0x0000-0x0cf7]
[ 0.265648] pci_bus 0000:0a: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.265650] pci_bus 0000:0a: resource 6 [mem 0x000d0000-0x000d3fff]
[ 0.265653] pci_bus 0000:0a: resource 7 [mem 0x000d4000-0x000d7fff]
[ 0.265656] pci_bus 0000:0a: resource 8 [mem 0x000d8000-0x000dbfff]
[ 0.265658] pci_bus 0000:0a: resource 9 [mem 0x000dc000-0x000dffff]
[ 0.265661] pci_bus 0000:0a: resource 10 [mem 0x80000000-0xfebfffff]
[ 0.265664] pci_bus 0000:0a: resource 11 [mem 0xfed40000-0xfed40fff]
[ 0.265667] pci_bus 0000:0a: resource 12 [io 0x0d00-0xffff]
[ 0.265735] NET: Registered protocol family 2
[ 0.266038] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.266058] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.266089] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.266128] TCP: reno registered
[ 0.266133] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.266141] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.266219] NET: Registered protocol family 1
[ 0.266245] pci 0000:00:02.0: Video device with shadowed ROM
[ 0.268248] PCI: CLS 32 bytes, default 64
[ 0.268336] Unpacking initramfs...
[ 1.201678] Freeing initrd memory: 39672K (f4f40000 - f75fe000)
[ 1.201800] Simple Boot Flag at 0x35 set to 0x1
[ 1.202005] microcode: CPU0 sig=0xf49, pf=0x10, revision=0x3
[ 1.202018] microcode: CPU1 sig=0xf49, pf=0x10, revision=0x3
[ 1.202121] microcode: Microcode Update Driver: v2.00 <[email protected]>, Peter Oruba
[ 1.202569] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 1.202622] audit: initializing netlink subsys (disabled)
[ 1.202654] audit: type=2000 audit(1490195365.200:1): initialized
[ 1.203130] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.203155] zbud: loaded
[ 1.203297] VFS: Disk quotas dquot_6.5.2
[ 1.203323] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.203407] msgmni has been set to 1722
[ 1.203871] alg: No test for stdrng (krng)
[ 1.203908] bounce: pool size: 64 pages
[ 1.203933] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.204019] io scheduler noop registered
[ 1.204027] io scheduler deadline registered
[ 1.204085] io scheduler cfq registered (default)
[ 1.204465] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[ 1.204568] pcieport 0000:00:1c.1: enabling device (0000 -> 0003)
[ 1.204767] pcieport 0000:00:1c.1: irq 41 for MSI/MSI-X
[ 1.204914] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.204948] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.205022] GHES: HEST is not enabled!
[ 1.205054] isapnp: Scanning for PnP cards...
[ 1.558164] isapnp: No Plug & Play device found
[ 1.558292] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.578736] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.599203] 00:07: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[ 1.620134] 0000:0a:09.0: ttyS2 at I/O 0x5480 (irq = 21, base_baud = 921600) is a 16550A
[ 1.640561] 0000:0a:09.0: ttyS3 at I/O 0x5488 (irq = 21, base_baud = 921600) is a 16550A
[ 1.640752] Linux agpgart interface v0.103
[ 1.640911] agpgart-intel 0000:00:00.0: Intel 945G Chipset
[ 1.640934] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 1.641241] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.641408] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
[ 1.641662] i8042: PNP: PS/2 Controller [PNP0303:KBC] at 0x60,0x64 irq 1
[ 1.641665] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.642268] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.642462] mousedev: PS/2 mouse device common for all mice
[ 1.642542] rtc_cmos 00:01: RTC can wake from S4
[ 1.642712] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.642742] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.642767] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.643544] TCP: cubic registered
[ 1.643595] NET: Registered protocol family 10
[ 1.643933] mip6: Mobile IPv6
[ 1.643939] NET: Registered protocol family 17
[ 1.643948] mpls_gso: MPLS GSO support
[ 1.644263] Using IPI No-Shortcut mode
[ 1.644472] registered taskstats version 1
[ 1.644966] rtc_cmos 00:01: setting system clock to 2017-03-22 15:09:26 UTC (1490195366)
[ 1.645075] PM: Hibernation image not present or could not be loaded.
[ 1.645493] Freeing unused kernel memory: 660K (c1675000 - c171a000)
[ 1.645548] Write protecting the kernel text: 4628k
[ 1.645604] Write protecting the kernel read-only data: 1456k
[ 1.645606] NX-protecting the kernel data: 3564k
[ 1.661598] systemd-udevd[60]: starting version 215
[ 1.662646] random: systemd-udevd urandom read with 0 bits of entropy available
[ 1.669833] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.688391] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/PNP0C0C:00/input/input1
[ 1.688405] ACPI: Power Button [PWRB]
[ 1.692595] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.692607] ACPI: Power Button [PWRF]
[ 1.695817] ACPI: bus type USB registered
[ 1.695908] usbcore: registered new interface driver usbfs
[ 1.695943] usbcore: registered new interface driver hub
[ 1.696534] pps_core: LinuxPPS API ver. 1 registered
[ 1.696540] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 1.697777] PTP clock support registered
[ 1.697966] [drm] Initialized drm 1.1.0 20060810
[ 1.699668] usbcore: registered new device driver usb
[ 1.700798] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.701592] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.701633] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[ 1.701638] e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
[ 1.701986] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.702006] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 1.702019] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.702068] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00003000
[ 1.702194] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.702201] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.702206] usb usb1: Product: UHCI Host Controller
[ 1.702210] usb usb1: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[ 1.702214] usb usb1: SerialNumber: 0000:00:1d.0
[ 1.702543] hub 1-0:1.0: USB hub found
[ 1.702562] hub 1-0:1.0: 2 ports detected
[ 1.705834] e1000e 0000:02:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.705879] e1000e 0000:02:00.0: irq 42 for MSI/MSI-X
[ 1.705942] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.705959] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[ 1.705971] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.706020] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00003020
[ 1.706121] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.706126] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.706130] usb usb2: Product: UHCI Host Controller
[ 1.706133] usb usb2: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[ 1.706137] usb usb2: SerialNumber: 0000:00:1d.1
[ 1.709199] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.709206] ACPI: Thermal Zone [THM0] (60 C)
[ 1.709656] hub 2-0:1.0: USB hub found
[ 1.709678] hub 2-0:1.0: 2 ports detected
[ 1.710499] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.710514] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[ 1.710526] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.710575] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00003040
[ 1.710691] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.710697] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.710701] usb usb3: Product: UHCI Host Controller
[ 1.710705] usb usb3: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[ 1.710709] usb usb3: SerialNumber: 0000:00:1d.2
[ 1.711041] hub 3-0:1.0: USB hub found
[ 1.711058] hub 3-0:1.0: 2 ports detected
[ 1.713216] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.713240] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 4
[ 1.713257] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 1.713309] uhci_hcd 0000:00:1d.3: irq 16, io base 0x00003060
[ 1.713431] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.713437] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.713443] usb usb4: Product: UHCI Host Controller
[ 1.713447] usb usb4: Manufacturer: Linux 3.16.0-4-686-pae uhci_hcd
[ 1.713451] usb usb4: SerialNumber: 0000:00:1d.3
[ 1.714638] hub 4-0:1.0: USB hub found
[ 1.714658] hub 4-0:1.0: 2 ports detected
[ 1.718485] ehci-pci: EHCI PCI platform driver
[ 1.719455] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.719469] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 5
[ 1.719488] ehci-pci 0000:00:1d.7: debug port 1
[ 1.723429] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported
[ 1.723549] ehci-pci 0000:00:1d.7: irq 23, io mem 0xd03c4000
[ 1.723714] FDC 0 is a National Semiconductor PC87306
[ 1.728113] SCSI subsystem initialized
[ 1.731956] libata version 3.00 loaded.
[ 1.732047] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.732210] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.732217] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.732223] usb usb5: Product: EHCI Host Controller
[ 1.732227] usb usb5: Manufacturer: Linux 3.16.0-4-686-pae ehci_hcd
[ 1.732231] usb usb5: SerialNumber: 0000:00:1d.7
[ 1.732689] hub 5-0:1.0: USB hub found
[ 1.732711] hub 5-0:1.0: 8 ports detected
[ 1.756166] hub 1-0:1.0: USB hub found
[ 1.756191] hub 1-0:1.0: 2 ports detected
[ 1.760420] e1000e 0000:02:00.0: Warning: detected DSPD enabled in EEPROM
[ 1.780207] hub 2-0:1.0: USB hub found
[ 1.780231] hub 2-0:1.0: 2 ports detected
[ 1.804172] hub 3-0:1.0: USB hub found
[ 1.804193] hub 3-0:1.0: 2 ports detected
[ 1.823659] e1000e 0000:02:00.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:15:58:df:1c:16
[ 1.823665] e1000e 0000:02:00.0 eth0: Intel(R) PRO/1000 Network Connection
[ 1.823680] e1000e 0000:02:00.0 eth0: MAC: 2, PHY: 2, PBA No: FFFFFF-0FF
[ 1.828162] hub 4-0:1.0: USB hub found
[ 1.828186] hub 4-0:1.0: 2 ports detected
[ 1.829710] [drm] Memory usable by graphics device = 256M
[ 1.829716] [drm] Replacing VGA console driver
[ 1.830390] Console: switching to colour dummy device 80x25
[ 1.830886] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.830891] [drm] Driver supports precise vblank timestamp query.
[ 1.831007] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.849633] [drm] initialized overlay support
[ 1.949642] fbcon: inteldrmfb (fb0) is primary device
[ 1.965823] Console: switching to colour frame buffer device 200x56
[ 1.971596] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 1.971599] i915 0000:00:02.0: registered panic notifier
[ 1.988046] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 1.988109] ata_piix 0000:00:1f.2: version 2.13
[ 1.988400] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[ 2.044028] usb 5-1: new high-speed USB device number 2 using ehci-pci
[ 2.145628] scsi0 : ata_piix
[ 2.145834] scsi1 : ata_piix
[ 2.145952] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x30b0 irq 14
[ 2.145958] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x30b8 irq 15
[ 2.177607] usb 5-1: New USB device found, idVendor=0bda, idProduct=8176
[ 2.177613] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.177617] usb 5-1: Product: 802.11n WLAN Adapter
[ 2.177620] usb 5-1: Manufacturer: Realtek
[ 2.177624] usb 5-1: SerialNumber: 00e04c000001
[ 2.200036] tsc: Refined TSC clocksource calibration: 3391.499 MHz
[ 2.308493] ata2.00: ATAPI: HL-DT-STDVD-ROM GDR8164B, 0M20, max UDMA/33
[ 2.318545] ata1.00: ATA-8: WDC WD1600AAJS-08WAA0, 58.01D58, max UDMA/100
[ 2.318550] ata1.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.324295] ata2.00: configured for UDMA/33
[ 2.332476] ata1.00: configured for UDMA/100
[ 2.332652] scsi 0:0:0:0: Direct-Access ATA WDC WD1600AAJS-0 1D58 PQ: 0 ANSI: 5
[ 2.336403] scsi 1:0:0:0: CD-ROM HL-DT-ST DVD-ROM GDR8164B 0M20 PQ: 0 ANSI: 5
[ 2.352370] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 2.352496] sd 0:0:0:0: [sda] Write Protect is off
[ 2.352502] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.352550] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.357122] sda: sda1
[ 2.357681] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.359128] sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[ 2.359133] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.359430] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.360705] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.360804] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.864030] usb 5-7: new high-speed USB device number 6 using ehci-pci
[ 3.000610] usb 5-7: New USB device found, idVendor=18a5, idProduct=0302
[ 3.000616] usb 5-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.000621] usb 5-7: Product: STORE N GO
[ 3.000625] usb 5-7: Manufacturer: Verbatim
[ 3.000629] usb 5-7: SerialNumber: 070A67C558CCB819
[ 3.003436] usb-storage 5-7:1.0: USB Mass Storage device detected
[ 3.003549] scsi2 : usb-storage 5-7:1.0
[ 3.003727] usbcore: registered new interface driver usb-storage
[ 3.112029] usb 5-8: new high-speed USB device number 7 using ehci-pci
[ 3.200087] Switched to clocksource tsc
[ 3.244854] usb 5-8: New USB device found, idVendor=0781, idProduct=5575
[ 3.244860] usb 5-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.244864] usb 5-8: Product: Cruzer Glide
[ 3.244868] usb 5-8: Manufacturer: SanDisk
[ 3.244872] usb 5-8: SerialNumber: 20042605611B01805E59
[ 3.245500] usb-storage 5-8:1.0: USB Mass Storage device detected
[ 3.245655] scsi3 : usb-storage 5-8:1.0
[ 3.484047] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[ 3.611838] ntfs: driver 2.1.30 [Flags: R/W MODULE].
[ 3.661100] usb 2-1: New USB device found, idVendor=0461, idProduct=0371
[ 3.661106] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=8
[ 3.661110] usb 2-1: Product: USB Scanner
[ 3.661118] usb 2-1: Manufacturer: Primax
[ 3.661121] usb 2-1: SerialNumber: RTS8801C2-004
[ 3.680385] ntfs: volume version 3.1.
[ 3.680393] ntfs: (device sda1): load_system_files(): Unsupported volume flags 0x4000 encountered.
[ 3.680397] ntfs: (device sda1): load_system_files(): Volume has unsupported flags set. Will not be able to remount read-write. Run chkdsk and mount in Windows.
[ 3.908027] usb 2-2: new full-speed USB device number 3 using uhci_hcd
[ 4.001766] scsi 2:0:0:0: Direct-Access Verbatim STORE N GO PMAP PQ: 0 ANSI: 6
[ 4.002372] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 4.003895] sd 2:0:0:0: [sdb] 30289920 512-byte logical blocks: (15.5 GB/14.4 GiB)
[ 4.004499] sd 2:0:0:0: [sdb] Write Protect is off
[ 4.004505] sd 2:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 4.005115] sd 2:0:0:0: [sdb] No Caching mode page found
[ 4.005120] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 4.010513] sdb: sdb1 sdb2
[ 4.244514] scsi 3:0:0:0: Direct-Access SanDisk Cruzer Glide 1.27 PQ: 0 ANSI: 6
[ 4.245092] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 4.247004] sd 3:0:0:0: [sdc] 30316544 512-byte logical blocks: (15.5 GB/14.4 GiB)
[ 4.247995] sd 3:0:0:0: [sdc] Write Protect is off
[ 4.248001] sd 3:0:0:0: [sdc] Mode Sense: 43 00 00 00
[ 4.248994] sd 3:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 4.254137] sdc: sdc1
[ 4.258125] sd 3:0:0:0: [sdc] Attached SCSI removable disk
[ 4.303096] usb 2-2: New USB device found, idVendor=067b, idProduct=2305
[ 4.303103] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.303106] usb 2-2: Product: IEEE-1284 Controller
[ 4.303110] usb 2-2: Manufacturer: Prolific Technology Inc.
[ 4.544047] usb 3-2: new low-speed USB device number 2 using uhci_hcd
[ 4.698078] usb 3-2: New USB device found, idVendor=04b3, idProduct=310b
[ 4.698084] usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.702912] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.717682] usbcore: registered new interface driver usbhid
[ 4.717688] usbhid: USB HID core driver
[ 4.719202] input: HID 04b3:310b as /devices/pci0000:00/0000:00:1d.2/usb3/3-2/3-2:1.0/0003:04B3:310B.0001/input/input3
[ 4.719385] hid-generic 0003:04B3:310B.0001: input,hidraw0: USB HID v1.00 Mouse [HID 04b3:310b] on usb-0000:00:1d.2-2/input0
[ 5.133379] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 5.155360] random: nonblocking pool is initialized
[ 5.364244] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 5.365488] ISO 9660 Extensions: RRIP_1991A
[ 5.376560] aufs: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.378134] aufs 3.16-20140908+setfl
[ 5.394034] loop: module loaded
[ 5.416750] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 5.436363] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 10.911281] ntfs: volume version 3.1.
[ 10.911290] ntfs: (device sda1): load_system_files(): Unsupported volume flags 0x4000 encountered.
[ 10.911295] ntfs: (device sda1): load_system_files(): Volume has unsupported flags set. Mounting read-only. Run chkdsk and mount in Windows.
[ 11.436282] FAT-fs (sdc1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 12.694658] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
[ 13.884858] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 13.885096] systemd[1]: Detected architecture 'x86'.
[ 13.995548] systemd[1]: Inserted module 'autofs4'
[ 14.006315] systemd[1]: Set hostname to <raspberrypi>.
[ 14.437455] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[ 14.438472] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 14.438601] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 14.438624] systemd[1]: Starting Remote File Systems (Pre).
[ 14.438750] systemd[1]: Reached target Remote File Systems (Pre).
[ 14.438813] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 14.439030] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 14.439055] systemd[1]: Starting Encrypted Volumes.
[ 14.439132] systemd[1]: Reached target Encrypted Volumes.
[ 14.439170] systemd[1]: Starting Swap.
[ 14.439253] systemd[1]: Reached target Swap.
[ 14.439276] systemd[1]: Starting Root Slice.
[ 14.439378] systemd[1]: Created slice Root Slice.
[ 14.439399] systemd[1]: Starting User and Session Slice.
[ 14.439518] systemd[1]: Created slice User and Session Slice.
[ 14.439539] systemd[1]: Starting Delayed Shutdown Socket.
[ 14.439643] systemd[1]: Listening on Delayed Shutdown Socket.
[ 14.439664] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 14.439786] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 14.439809] systemd[1]: Starting Journal Socket (/dev/log).
[ 14.439956] systemd[1]: Listening on Journal Socket (/dev/log).
[ 14.440001] systemd[1]: Starting udev Control Socket.
[ 14.440147] systemd[1]: Listening on udev Control Socket.
[ 14.440187] systemd[1]: Starting udev Kernel Socket.
[ 14.440289] systemd[1]: Listening on udev Kernel Socket.
[ 14.440328] systemd[1]: Starting Journal Socket.
[ 14.440476] systemd[1]: Listening on Journal Socket.
[ 14.440529] systemd[1]: Starting System Slice.
[ 14.440685] systemd[1]: Created slice System Slice.
[ 14.440719] systemd[1]: Starting system-getty.slice.
[ 14.440948] systemd[1]: Created slice system-getty.slice.
[ 14.441019] systemd[1]: Starting Increase datagram queue length...
[ 14.442149] systemd[1]: Starting Nameserver information manager...
[ 14.443472] systemd[1]: Mounting POSIX Message Queue File System...
[ 14.448205] systemd[1]: Mounting Huge Pages File System...
[ 14.475259] systemd[1]: Started Set Up Additional Binary Formats.
[ 14.475316] systemd[1]: Starting udev Coldplug all Devices...
[ 14.476587] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 14.521891] systemd[1]: Starting Load Kernel Modules...
[ 14.523041] systemd[1]: Mounting Debug File System...
[ 14.524678] systemd[1]: Starting live-config contains the components that configure a live system during the boot process (late userspace)....
[ 14.525944] systemd[1]: Starting Slices.
[ 14.526096] systemd[1]: Reached target Slices.
[ 14.566987] systemd[1]: Started udev Coldplug all Devices.
[ 14.659804] systemd[1]: Started Increase datagram queue length.
[ 14.662440] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 14.698318] systemd[1]: Mounted Debug File System.
[ 14.699034] systemd[1]: Mounted Huge Pages File System.
[ 14.699564] systemd[1]: Mounted POSIX Message Queue File System.
[ 14.744402] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 14.746063] systemd[1]: Starting Syslog Socket.
[ 14.746276] systemd[1]: Listening on Syslog Socket.
[ 14.746338] systemd[1]: Starting Journal Service...
[ 14.747575] systemd[1]: Started Journal Service.
[ 14.934547] fuse: Unknown symbol setattr_prepare (err 0)
[ 15.977939] systemd-udevd[849]: starting version 215
[ 16.756807] snd_hda_intel 0000:00:1b.0: irq 43 for MSI/MSI-X
[ 16.795471] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 16.811755] sound hdaudioC0D0: autoconfig: line_outs=1 (0x5/0x0/0x0/0x0/0x0) type:line
[ 16.811765] sound hdaudioC0D0: speaker_outs=1 (0x7/0x0/0x0/0x0/0x0)
[ 16.811771] sound hdaudioC0D0: hp_outs=1 (0x6/0x0/0x0/0x0/0x0)
[ 16.811776] sound hdaudioC0D0: mono: mono_out=0x0
[ 16.811781] sound hdaudioC0D0: inputs:
[ 16.811786] sound hdaudioC0D0: Mic=0x8
[ 16.811791] sound hdaudioC0D0: Line=0x9
[ 16.820735] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/hdaudioC0D0/input4
[ 16.823205] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 16.823314] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 16.823417] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 16.823524] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 16.888911] parport_pc 00:08: reported by Plug and Play ACPI
[ 16.889001] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 16.975507] intel_rng: FWH not detected
[ 16.984237] tpm_tis 00:09: [irq 5]
[ 16.984254] tpm_tis 00:09: [mem 0xfed40000-0xfed40fff]
[ 16.984518] tpm_tis 00:09: activated
[ 16.984985] tpm_tis 00:09: 1.2 TPM (device-id 0xFE, rev-id 3)
[ 17.008461] tpm_tis 00:09: TPM is disabled/deactivated (0x6)
[ 17.090689] ACPI Warning: SystemIO range 0x0000000000003080-0x000000000000309F conflicts with OpRegion 0x0000000000003080-0x0000000000003097 (\_SB_.PCI0.SMBS.SMB0) (20140424/utaddress-254)
[ 17.090705] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 17.323004] input: PC Speaker as /devices/platform/pcspkr/input/input9
[ 17.345382] usblp 2-2:1.0: usblp0: USB Bidirectional printer dev 3 if 0 alt 1 proto 2 vid 0x067B pid 0x2305
[ 17.345436] usbcore: registered new interface driver usblp
[ 17.349415] ACPI Warning: SystemIO range 0x0000000000001028-0x000000000000102F conflicts with OpRegion 0x0000000000001000-0x000000000000102F (\_SB_.PCI0.LPC0.PMIO) (20140424/utaddress-254)
[ 17.349430] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 17.349436] ACPI Warning: SystemIO range 0x0000000000001180-0x00000000000011AF conflicts with OpRegion 0x0000000000001180-0x00000000000011AF (\_SB_.PCI0.LPC0.GPOX) (20140424/utaddress-254)
[ 17.349445] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 17.349502] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 17.397307] leds_ss4200: no LED devices found
[ 17.602686] ppdev: user-space parallel port driver
[ 17.615619] iTCO_vendor_support: vendor-support=0
[ 17.638278] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 17.638339] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x1060)
[ 17.639016] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 21.979156] systemd-journald[778]: Received request to flush runtime journal from PID 1
[ 22.779645] cfg80211: Calling CRDA to update world regulatory domain
[ 23.133099] e1000e 0000:02:00.0: irq 42 for MSI/MSI-X
[ 23.236110] e1000e 0000:02:00.0: irq 42 for MSI/MSI-X
[ 23.236765] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 23.237188] cfg80211: World regulatory domain updated:
[ 23.237194] cfg80211: DFS Master region: unset
[ 23.237198] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 23.237204] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.237210] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 23.237214] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.237218] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 23.237224] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 23.237228] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 23.237233] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.237237] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 60.148503] fuse: Unknown symbol setattr_prepare (err 0)
[ 71.066811] FAT-fs (sdc1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 77.500337] Bluetooth: Core ver 2.19
[ 77.500670] NET: Registered protocol family 31
[ 77.500675] Bluetooth: HCI device and connection manager initialized
[ 77.500687] Bluetooth: HCI socket layer initialized
[ 77.500694] Bluetooth: L2CAP socket layer initialized
[ 77.500718] Bluetooth: SCO socket layer initialized
[ 77.544474] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 77.544481] Bluetooth: BNEP filters: protocol multicast
[ 77.544494] Bluetooth: BNEP socket layer initialized
ShiftPlusOne
Wed Mar 22, 2017 4:48 pm
I can't help but think that the blacklist files have something to do with it, but I can't figure out how they could be having an affect if you've removed them.
wjmeso
Wed Mar 22, 2017 6:59 pm
I had previously just deleted the single line out of each file, but I have now removed(deleted) entirely the 2 files and after re-boot it still does not have network connectivity.
wjmeso
Sat Mar 25, 2017 1:46 pm
In the "blacklist" I had made a backup copy of the 2 files with an "X" as the starting of the names before editing to remove data line and secondly before deleting the files, problem is, renamed files had extension of "conf", so they were being picked up and being used to blacklist the rtl8_____devices.
Mistake caused by "newbie" to linux operation.
Wasn't aware that startup reads the entire "/etc/modprobe.d" folder looking/executing anything with an extension of ".conf".
Network does connect if there is NO BLACKLIST for the RTL8192cu in the modprobe.d file!.
Am I operating safely removing the blacklist items should they return in future updates? OR, should I trash this old Lenovo, keep the monitor and get a new pi-3? Thanks for all the time/help as I learned a few new things.
Believe post can be closed....thanks again shift-plus-one.
ShiftPlusOne
Sat Mar 25, 2017 4:55 pm
wjmeso wrote:Network does connect if there is NO BLACKLIST for the RTL8192cu in the modprobe.d file!.
Future updates should not bring those files back, so you should be okay.
Return to “Debian”
