nikkon
Contact: Yahoo Messenger
reduce GPU ram allocation
Fri Aug 03, 2012 7:55 am
Hi people,
Is there any option/posibility to reduce the actual RAM allocation for the GPU.
I'm not using it and i need more RAM.
@ the moment it uses 32MB
thanks
itimpi
Re: reduce GPU ram allocation
Fri Aug 03, 2012 9:05 am
You cannot completely eliminate any RAM being allocated to the GPU as it is critical to the running of the system.
Having said that if you have the latest firmware updates there is an option to reduce the RAM used by the GPU to 16MB (i.e. 240MB free for system use).
nikkon
Fri Aug 03, 2012 9:12 am
not sure if i have the lates one.
how can i check for this option?
LeroyZ84
Fri Aug 03, 2012 9:13 am
i see in /boot:
root@rpi:/boot# ls -l
total 34960
-rwxr-xr-x 1 root root  2053296 Aug  2 17:52 arm128_start.elf
-rwxr-xr-x 1 root root  2053296 Aug  2 17:52 arm192_start.elf
-rwxr-xr-x 1 root root  2053296 Aug  2 17:52 arm224_start.elf
-rwxr-xr-x 1 root root   628592 Aug  2 17:52 arm240_start.elf
how to enable the arm240_start.elf?
simply by copying it to start.elf?
nikkon
Fri Aug 03, 2012 9:19 am
it seems i don't have it
root@IronHide:/boot# ls -l
total 34512
-rwxr-xr-x 1 root root 2051056 Jul 15 18:10 arm128_start.elf
-rwxr-xr-x 1 root root 2051056 Jul 15 18:10 arm192_start.elf
-rwxr-xr-x 1 root root 2051056 Jul 15 18:10 arm224_start.elf
felix123
Fri Aug 03, 2012 9:27 am
nikkon wrote:it seems i don't have it
total 34512
do rpi-update first
nikkon
Fri Aug 03, 2012 9:39 am
root@IronHide:/boot# rpi-update
-bash: rpi-update: command not found
root@IronHide:/boot# apt-get install rpi-update
Reading package lists... Done
Building dependency tree
E: Unable to locate package rpi-update
LeroyZ84
Fri Aug 03, 2012 9:40 am
for installation, please see:
http://www.raspberrypi.org/archives/1195
RaTTuS
Contact: Twitter YouTube
Fri Aug 03, 2012 9:43 am
Covfefe
nikkon
Fri Aug 03, 2012 9:46 am
Thanks alot
Works fine now !
LeroyZ84
Fri Aug 03, 2012 11:57 am
             total       used       free     shared    buffers     cached
Mem:           231        141         89          0          9        104
-/+ buffers/cache:         27        204
Swap:           99          0         99
:D
nikkon
Fri Aug 03, 2012 12:02 pm
root@IronHide:~# free -m
Mem: 231 219 11 0 7 160
-/+ buffers/cache: 50 180
Swap: 100 0 100
root@IronHide:~#
root@IronHide:~# cat /proc/swaps
Filename Type Size Used Priority
/myswap file 796 20 -1
/var/swap file 102396 0 -2
root@IronHide:~#
The question is why i can't see the fileswap under free ?
Return to “Debian”
