KZhan
Apache Fails to Start
Wed Aug 01, 2012 6:14 am
Hey Everyone,
I am really really green and I've been following the instructions posted and youtube videos outlining getting apache up and running however I cannot get it up and running. Whenever i try to start with
sudo services apache2 start
i get:
Starting web server: apache2Illegal instruction
Action 'start' failed.
The Apache error log may have more information.
failed!
I've checked the logs at /var/logs/apache2 and they are both empty. Does anyone have any clue whats wrong? I've also checked netstat -apn and nothing seems to be using port 80 as was suggested on other forums.
KZhan
Re: Apache Fails to Start
Sun Aug 05, 2012 5:46 am
bump?
joan
Sun Aug 05, 2012 7:39 am
Which distribution are you using?
On Debian Wheezy all you need to do to install Apache is
sudo apt-get install apache2
KZhan
Sun Aug 05, 2012 7:44 am
Hi joan,
I am indeed using debian wheezy and I have used apt-get install apache2. However I keep on. Getting the error listed in the original post
joan
Sun Aug 05, 2012 2:25 pm
All I can suggest is trying
sudo apt-get purge apache2
followed by
SirLagz
Sun Aug 05, 2012 3:09 pm
Sounds like you used the wrong sources and installed a ARMv7 version of apache rather than the Raspbian version - assuming that you're using Raspbian.
What's in your /etc/apt/sources.list ?
Choubani.h
Fri Oct 12, 2012 3:12 pm
Hi KZhan,
I am facing the same problem as you.
did you find a solution?
can you help please?
in my source.list :
deb http://ftp.de.debian.org/debian/ wheezy contrib main non-free
Choubani.h
Fri Oct 12, 2012 3:32 pm
Is it possible that i installed the debian version, so it wont start in the Raspberry pi?
Choubani.h
Mon Oct 15, 2012 11:18 am
The problem is solved:
i changed Source.list to :
deb http://archive.rasbian.org/raspbian/ wheezy contrib main non-free rpi
Blindfreddy
Mon Oct 19, 2015 9:03 am
This error occurred overnight (actually around 3AM last night) on my pi. I can't see any reason, nothing in error log except 'segmentation fault'. Perhaps the binary was somehow corruped. Anyway, I solved it by purging ALL apache2 packages - just purging apache2 did not suffice. So this worked: sudo apt-get purge apache2* followed by sudo apt-get install apache2
Also had to reinstall php apache module: sudo apt-get install libapache2-mod-php5 to get php to work again.
Hope this helps someone.
PeterO
Mon Oct 19, 2015 9:46 am
Do you really think it is likely to be the same problem as people were having three years ago ?
PeterO
Return to “Debian”
