Nmisha
Debian 10 only mono sound instead stereo (analog)
Wed Jul 28, 2021 12:05 am
I installed debian 10, but I have trubles with sound.
In VLC I see only one mono sound interface. It hasn't hdmi output. And I don't know how change to stereo. Maybe anybody know how I can fix it?
$ cat /proc/asound/cards
0 [vc4hdmi0 ]: vc4-hdmi - vc4-hdmi-0
vc4-hdmi-0
1 [vc4hdmi1 ]: vc4-hdmi - vc4-hdmi-1
vc4-hdmi-1
2 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
bcm2835 ALSA
Re: Debian 10 only mono sound instead stereo (analog)
Wed Jul 28, 2021 12:59 am
vc4-hdmi-0
vc4-hdmi-1
bcm2835 ALSA
Maybe running the supported Raspberry Pi (Raspbian) with Desktop Operating System would be beneficial ?
https://www.raspberrypi.org/software
Take what I advise as advice not the utopian holy grail, and it is gratis !!
Nmisha
Wed Jul 28, 2021 8:28 am
May be. But Raspberry pi os is officially unsupported by HomeAssistant. And I had some troubles with it, because trying debian.
I suggest that udev incorrect detect sound card and set profile. But I have driver snd_bcm2835.
If I disable mono sound profile in pulse audio (workaround) I got stereo sound output (analog output), but I havn't hdmi sound output. I think it is bad way for solution
Wed Jul 28, 2021 9:02 am
HomeAssistant, well that was not mentioned in your Original Post, therefore whoever compiled whatever version of Debian should support, if HomeAssistant are not willing.
Debian themselves do not Officially Support.
Nmisha
Wed Jul 28, 2021 9:20 am
I see that debian is supported platform.
Supported Operating System, System dependencies and versions
Debian Linux Debian 10 aka Buster (no derivatives)
https://www.home-assistant.io/installation/linux#install-home-assistant-supervised
However, I didn't find manual for transform debian to raspberian :) And as I understood, debian image created for RPi and should be working. :)
Offtopic. For Bluetooth I found driver and got it:
sudo wget https://github.com/RPi-Distro/bluez-fir ... 4345C0.hcd /lib/firmware/brcm
May I should find another files for sound, power, ... etc
P.S. I got debian image from https://raspi.debian.net/tested-images/
Wed Jul 28, 2021 9:40 am
It would appear Home Assistant offer an .IMG file specifically for the Raspberry Pi:
https://www.home-assistant.io/installation/raspberrypi
https://github.com/home-assistant/opera ... m/releases
Nmisha
Wed Jul 28, 2021 10:11 am
Yes, but it's closed debian-based OS without access ("blackbox" HA on rpi) or restricted HA without supervised option. I don't know why HA finished support raspberrypi os for supervised installation.
LTolledo
Wed Jul 28, 2021 11:36 am
please test audio with your ears... not with eyes....
this is what is reported by my system (for my eyes to see)
asound command output.jpg (42.69 KiB) Viewed 757 times
if I attach a headphone to the RPi4B's audio jack and play a stereo encoded media via VLC...
my ears hear stereo (separate left and right channels)
confirmed by my eyes and ears after watching this:
https://www.youtube.com/watch?v=hTvJoYnpeRQ
it wouldn't hurt trying out.... would it....?
Some people be like:
Nmisha
Wed Jul 28, 2021 11:52 am
My ears hearing mono sound. If I implemented workaround (disable mono profile) then stereo.
And I didn't see hdmi output when hdmi connected.
Nmisha
Wed Jul 28, 2021 2:36 pm
I setup log-level debug for pulse audio
And I have
/var/log/syslog:Jul 28 14:23:11 mihomepi pulseaudio[1601]: I: [pulseaudio] module-udev-detect.c: Card /devices/platform/soc/fef05700.hdmi/sound/card1 (alsa_card.platform-fef05700.hdmi) failed to load module.
/var/log/syslog:Jul 28 14:23:10 mihomepi pulseaudio[1601]: E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="0" name="platform-fef00700.hdmi" card_name="alsa_card.platform-fef00700.hdmi" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1""): initialization failed.
pyavitz
Wed Jul 28, 2021 8:45 pm
To force pulse audio to default to stereo edit the following file: /usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf
Example: L104 to L109
https://github.com/pyavitz/rpi-img-buil ... .conf#L104
Nmisha
Thu Jul 29, 2021 6:44 am
This is working workaround. But I haven't hdmi audio output and in original raspberian mono profile is uncommented. I think this is not right way.
Return to “Debian”
