MrSamNC
How-To: Pi with TightVNC and Fing for Network Monitoring
Tue Jul 23, 2013 4:02 pm
Follow the below steps to setup and configure your Raspberry Pi as a network sentinel with Fing (aka Fingbox or Overloook Fing) and to install/configure TightVNC so you can access your Pi remotely from the network. The below steps (mainly the raspi-config section) apply to users in U.S.A. in the EST timezone, but will work for you as long as you change the "Internationalisation Options" to match your location.
How to Setup a Raspberry Pi with TightVNC and Fing to Monitor a Network
1. Using a SD card with NOOBS, Install the Raspbian OS
Raspberry Pi Software Configuration Tool (raspi-config)
1. Expand the File System
2. Enable Boot to Desktop
3. Internationalisation Options:
a. Change Locale to: en_US ISO-8859-1, en_US
b. Change Timezone to: US, Eastern
c. Change Keyboard Layout to: Generic 104-key PC, Other, English (US), English (US), The default..., No compose key, No
4. Advanced Options
a. Change Hostname
b. Enable SSH
c. Update
5. Finished
6. Reboot the Pi Now? YES
Install and Configure Tight VNC Server
1. Launch LXTerminal
2. Type: sudo apt-get update
3. Type: sudo apt-get install tightvncserver
4. Say YES to continue
5. Type: vncserver :1
6. Set the VNC password
7. Say NO to view-only password
8. Type: cd /home/pi
9. Type: cd .config
10. Type: mkdir autostart
11. Type: cd autostart
12. Type: nano tightvnc.desktop
13. Enter the following lines:
[Desktop Entry]
Type=Application
Name=TightVNC
Exec=vncserver :1
StartupNotify=false
14. Press Ctrl-X, then Y, then Enter to Save and Exit
15. Close LXTerminal
Install and Configure Fing
1. Launch NetSurfer Web Browser
2. Go to: http://www.overlooksoft.com/getfing4arm
3. Click the DEB Package for ARM link to download the file, click Save, close the web browser
4. Close NetSurfer Web Browser
5. Launch LXTerminal
6. Type: sudo dpkg -i overlook-fing-2.2.deb
7. Type: sudo apt-get install libpcap-dev
8. Say YES to continue
9. Type: sudo fing --interactive
10. Type F to setup your Fingbox account
11. Launch File Manager
12. Click on Tools, then Open Current Folder as Root
13. Go to: /usr/lib/fing/int.d and COPY fingbox-sentinel.raspberry and fingbox-sentinel
14. Go to: /etc/int.d and PASTE fingbox-sentinel.raspberry and fingbox-sentinel
15. Close File Manager
16. Launch LX Terminal
17. Type: sudo apt-get install chkconfig
18. Type: sudo chkconfig --add fingbox-sentinel
19. Type: sudo chkconfig --add fingbox-sentinel.raspberry
Reboot the Pi and verify:
1. You can access the Pi via VNC (IP address + :1)
2. Fingbox is running (check fingbox.com for your newly added network monitor to show up)
petros015
Re: How-To: Pi with TightVNC and Fing for Network Monitoring
Sat Oct 29, 2016 3:40 pm
the new link for fing is
https://www.fing.io/wp-content/uploads/ ... ng-3.0.deb
so the related instructions are
6 sudo dpkg -i overlook-fing-3.0.deb
7 sudo apt-get install libpcap-dev
Sat Oct 29, 2016 3:45 pm
petros015 wrote:the new link for fing is
The ancient post you are replying to is 3 years old and Raspbian Wheezy which is end of life, it would be better to write an up-to-date guide for the current Raspbian Jessie with Pixel :D
Asus ChromeBox 3 Celeron is my other computer.
jtp
Sun Jun 25, 2017 7:00 pm
Anyone else unable to connect their Pi to their Fing.io account? I am positive that I have the right email and password, but it won't log in. Quite frustrating. I am wondering if this might have to do with the depreciation of fingbox.com in favor of fing.io.
flyskimmy
Wed Aug 23, 2017 5:06 pm
I am having the same issue you are. I tried changing platforms to see if it was just the raspberry pi version that wasn't working, but I am seeing the same issue on linux and windows.
pederses
Fri Aug 25, 2017 6:54 pm
I am having the same problem with being unable to connect to the fing account. Has anyone got this working?
Martah
Mon Feb 12, 2018 3:43 pm
Has anyone found a new method?
B.Goode
Mon Feb 12, 2018 5:38 pm
Have you considered asking the Fing/Fingbox team via one of the contact addresses on their own website:
https://www.fing.io/contact/
Return to “Teaching and learning resources”
